go_a_way1, MisterSheep
Old 11-17-2020, 09:02 AM   #22583
He who smelt it...
Well, OK, thanks for explaining that. I wonder why they put a two piece driveshaft in the car to start with? -
I reckon my OEM driveshaft isn't all that bad. It doesn't do all these things:
"There's no more of that hop when coasting in first gear, all the clunk-clunking is gone, the shifting is sooo nice now, and the power transfer is much more direct."
Mine either.
Tcoat is online now   Reply With Quote
humfrz (11-17-2020)
Old 11-17-2020, 01:47 PM   #22584
humfrz
Maybe cause you've driven some real clunkers before, this one seems smooth to you
Also could be that all the various inserts and bushings I have really magnify all the audible umm... features.
You callen ma old 1937 Chevrolet pickup a clunker? -
Well, of course any driveline sounds will be transmitted to the cabin, if you weld all the parts of the drivetrain to the body of the car -
humfrz is online now   Reply With Quote
Old 11-17-2020, 03:02 PM   #22585
StraightOuttaCanadaEh
Wes
Drives: 2017 Toyota 86
Yep I've done that to meself, first one to admit it. But now I bought the thing to fix the problem I created
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
humfrz (11-17-2020)
Old 11-17-2020, 03:06 PM   #22586
humfrz
Old 11-17-2020, 07:30 PM   #22587
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Got a Perrin inlet tube on sale 20% off.
Wanted black but would have needed to special order.
Happy to be rid of all the sound generator crap.
The Following 5 Users Say Thank You to RToyo86 For This Useful Post:
DarkPira7e (11-17-2020), FLIPDADY (11-18-2020), MJones_RB (11-18-2020), mrg666 (11-17-2020), Tcoat (11-19-2020)
Old 11-17-2020, 09:15 PM   #22588
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
There are many reasons for a piece.
1. Less chance of bending/flexing at high-rpms.
2. The critical speed (failure) limit is greatly reduced.
3. Less vibration when not optimal condition... dirty/offroading due to the bushing/carrier assembly.
4. #1 means they can have tighter tolerances of the tunnel so lower floor and more passenger room.
5. Having a joint midway means less of the driveshaft (only the rear 1/2) is usually hanging lower to meet the rear diff, meaning more clearance to the road.
6. Less tubing length means they can make the diameter smaller. With a long 1 piece aluminum drive shaft you need to increase the diameter to increase the strength.
With 1 piece you get all the things enthusiast want. A more direct feeling and faster response due to lighter rotating parts. The mod is very comparable pros and cons list-wise to doing a lightweight flywheel or stiffer bushings and engine mounts. Not something the everyday consumer and OEM want or notice. If your the type that can notice the effects of lightened rotating mass then this is your kind of mod.
It's because the stock drive shaft is 2 piece instead of 1. I noticed the exact same things when I switched. I bought it because of the weight but I'd get it just for the driving feel/comfort of I was doing it again
If you ever get the chance to swing it their carbon drive shaft is another step up as it is even lighter with even less vibrations.
The Following 3 Users Say Thank You to Kiske For This Useful Post:
Cephas (11-18-2020), humfrz (11-17-2020), Wally86 (11-18-2020)
Old 11-17-2020, 09:19 PM   #22589
Ashikabi
Ashikabi's Avatar
I'm running a steel one piece now cuz I have an LS engine. The aluminum would have taken up too much room in the tunnel
The Following User Says Thank You to Ashikabi For This Useful Post:
Kiske (11-17-2020)
Old 11-18-2020, 06:37 AM   #22590
FLIPDADY
FLIPDADY's Avatar
Drives: 2015 Subaru BRZ Sport Tech
I need that red manifold!
Sent from my LM-G900 using Tapatalk
FLIPDADY is offline   Reply With Quote
The Following User Says Thank You to FLIPDADY For This Useful Post:
RToyo86 (11-19-2020)
Old 11-19-2020, 09:22 PM   #22591
RToyo86
RToyo86's Avatar
Had my tires rebalanced after feeling vibration in the highway. They're still vibrating. Just checked and two of my plastic centric rings are cracked. I think they balanced them with the rings on
Old 11-19-2020, 10:13 PM   #22592
He who smelt it...
Got my snows on!
Dadhawk (11-19-2020)
Old 11-20-2020, 04:39 AM   #22593
beltax90
beltax90's Avatar
Drives: 2010 corolla
beltax90 is offline   Reply With Quote
The Following 3 Users Say Thank You to beltax90 For This Useful Post:
LancePower (11-20-2020), MJones_RB (11-20-2020), weederr33 (11-20-2020)
Old 11-20-2020, 09:31 PM   #22594
Ultramaroon
hey, skipper
Ultramaroon's Avatar
Checked the plug on the battery tender.
Tcoat (11-20-2020)
Old 11-20-2020, 09:32 PM   #22595
He who smelt it...
Was it OK?
Old 11-20-2020, 09:37 PM   #22596
Ultramaroon
hey, skipper
Was it OK?
Did not unplug.
Oops wrong thread
HaXx (11-30-2020), Tcoat (11-20-2020)
Search this Thread:
Advanced Search
Got my VIN today... Enemies BRZ First-Gen (2012+) -- General Topics 63 04-12-2012 11:19 PM
Copyright ©2000 - 2022, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
