Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
08-11-2022, 05:34 PM | #1 |
Drives: 2016 Toyota 86
Experience with no brake dust shields long term?
I was planning to use the PP dust shields for the Brembo GT kits I picked up. However, it is not currently possible to purchase the dust shields because they are back ordered with no ETA. They may have even possibly been discontinued.
I got the brakes from @CounterSpace Garage and they are suggesting to just completely remove the front dust shields and cut the shield faces off the rears. Does anyone have experience driving their car with no dust shields? Any issues with daily driving without the shields? How much more brake dust gets on your wheels? |
08-11-2022, 05:44 PM | #2 |
Drives: Subaru BRZ
I recently removed both front and rear heat shields so not long term feedback yet.
The rears can be removed in an elegant way and you can look through the thread to see how I heat wrapped some ball joints and lines. Last edited by Code Monkey; 08-11-2022 at 08:13 PM. |
The Following User Says Thank You to Code Monkey For This Useful Post: | Mike_ZN6 (08-11-2022) |
08-13-2022, 03:13 AM | #3 |
Drives: Toyota 86 GTS
I have STI brembos and my mechanic chose to just remove the dust shields rather than trim them. He doesn’t seem to think there’s any real need to have it.
No issues so far but yea the barrels of the wheels have a lot of brake dust even though I ceramic coated my wheels. |
The Following User Says Thank You to Sam86 For This Useful Post: | Mike_ZN6 (08-14-2022) |
08-13-2022, 04:46 PM | #4 |
Drives: 10 RX-8 Spt, 20 BRZ Ltd, 21 Rubicon
I took the fronts off my 2016 track rat. As others noted, lots more dusting. I also ran like this through winters and rain, so every couple/few months I hit things with brake kleen, steel wool, and wire brushes then finished with some penetrating lube after more brake clean and a wipe down to mitigate water and winter grime corrosion. Obviously keep the latter lube off the pads, rotors and near areas. Drove this car just over five years like this and all held up well. No oil cooler either but that’s for other threads.
The Following User Says Thank You to DrinkenBRZ For This Useful Post: | Mike_ZN6 (08-14-2022) |
08-13-2022, 09:11 PM | #5 |
¯\_(ツ)_/¯
Drives: '15 ultramarine
Take them off, you'll be fine..
08-14-2022, 05:14 PM | #6 | |
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | Mike_ZN6 (08-14-2022) |
08-14-2022, 07:01 PM | #7 |
Drives: 2013 Subaru BRZ
I think you'll find them available at Amayama
The Following User Says Thank You to clio For This Useful Post: | Mike_ZN6 (08-14-2022) |
08-14-2022, 09:09 PM | #8 |
Thanks for letting me know. I just put an order in with them. Hopefully they approve it. I would prefer to keep this car more street than race car. If they cancel the order, I will probably remove the fronts and remove the whole shield from the rears like @Code Monkey. |
08-15-2022, 09:35 AM | #9 | |
They serve a purpose but as long as you maintain the areas around them you can get away without them. If you just leave things then you will run into issues (both with the brakes and surrounding parts) down the road.
08-15-2022, 12:26 PM | #10 | |
Drives: 2018 Subaru BRZ
Also, spraying the wheels with something like graphene wax makes cleaning much easier and could prevent some buildup. Ever since I've been using it on mine I haven't had to go thru so many steps or better yet, spend more than 30 seconds per wheel when washing the car.
The Following User Says Thank You to spcmafia For This Useful Post: | Tcoat (08-15-2022) |
Similar Threads | ||||
Changing rear brakes dust shields | larryt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 04-05-2023 07:53 PM |
Brake dust or rail dust? Dealership bs? | Muskokan | Issues | Warranty | Recalls / TSB | 12 | 12-21-2013 09:30 AM |
long term and short term | brichard0625 | Engine, Exhaust, Transmission | 7 | 08-26-2013 08:56 AM |
Fuel Trims - Long term and short term | victorb | Engine, Exhaust, Transmission | 6 | 03-27-2013 02:18 PM |
Short Term and Long Term Fuel Trims | naikaidriver | Engine, Exhaust, Transmission | 3 | 03-18-2013 09:55 PM |
