Old 10-21-2012, 02:38 AM   #155
fergbruz
Drives: white 86 gt manual
Will there be any issues fitting up 18x7.5 et45 all round?
fergbruz is offline   Reply With Quote
Old 10-21-2012, 10:18 AM   #156
djliquidsteele
Drives: Scion FR-S
Loking at these in 18 x 8.5 and 18 x 9. http://www.forgestar.com/v2/wheelsf14.php
What size tire would be best for these?
djliquidsteele is offline   Reply With Quote
Old 10-21-2012, 10:48 PM   #157
Agnostik
Drives: 2013 Whiteout FR-S
Originally Posted by JoeBoxer View Post
That tire is just over an inch taller in overall diameter than 215/45R17 so they should fit if you aren't lowered. Do you have 16" 5x100 wheels?
Ok, looked into my rims. Far as I can tell they are EMR 400s (they say Panther on the center caps...).
They appear to have the two bolt patterns 5x100/5x114.3. Far as I can tell they have a +38 offset and some other stat, CH, of 73.
They appear to be 16x7 size rims.
So will these fit? You had said earlier that they would be a bit over an inch taller than the stock tires, what kind of effect should I expect? Would it be better to go with 205/55R16?
And just to review, the tires on the rims are 205/60R16.
Agnostik is offline   Reply With Quote
Old 10-21-2012, 10:56 PM   #158
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Wheels should fit, 73 is a common center bore and may need hub rings but they are cheap. If you have 205/60r16 I would try them and see.
JoeBoxer is offline   Reply With Quote
Old 10-21-2012, 10:59 PM   #159
JoeBoxer
JoeBoxer's Avatar
I would run either 8.5 or 9 all around, no real need to stagger for a half inch. You could run 8.5 with 225/40 or 235/40 or 18x9 with 245/35 or 255/35.
Edit you could run 235/40 on the 9" all around also
Old 10-22-2012, 11:19 AM   #160
bakerr6
Drives: 2013 raven black fr-s
I was thinking about buying the legacy gt mesh wheels from 99 for my winter wheels. Do we know if they would work? The stock 86 wheels outside of the us are 16x6.5 with an offset around +48 I believe, and the legacy wheels are 16x6.5 with a +55 offset.
bakerr6 is offline   Reply With Quote
Old 10-22-2012, 11:45 AM   #161
lastsnare
^_^
Drives: 2013 BRZ Galaxy Blue Silica
I have 255/40 on my 17x8's for my WRX, they are borderline wide for that particular tire model.
But 245/40 is no problem at all on 17x8 (Star Specs fit perfectly when I had them in that size).
8.5 or 9 inch wide wheels should accomodate much wider tires.
If you don't plan to go really wide with tires, a narrower wheel would work, might be cheaper and would probably weigh less as well.
225/40 sounds narrow for that wide of a wheel.
Your rim might be sticking out a bit from the tire (easier to damage it if you accidentally brush up against a curb).
2004 WRX sedan Java Black Pearl (manual)
2013 BRZ Galaxy Blue Silica (manual)
lastsnare is offline   Reply With Quote
Old 10-22-2012, 06:14 PM   #162
cookiesforchristy
Drives: frs,brz
New member here; I'm planning on buying an frs/brz (not sure yet),
and I'd like to purchase a set of used rims.
Since I'm a noobie, (:
I was wondring if the frs/brz bolt patterns were the same?
and would vs-xx(18x9.5+24 ; 18x10.5+20) fit?
thank you
cookiesforchristy is offline   Reply With Quote
Old 10-22-2012, 09:40 PM   #163
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
thank you
Yes, same p.c.d.
Your wheel sizes will fit as far as inner clearance goes, but you'll be outside the guards considerably.
Front extend 56mm over oe spec.
Rear extend 72mm over oe spec.
ie: that's a lot of wheel width. Widebody application, sure. Stock fenders? You'll be adding a lot of negative camber to get that inside the fender..
Not my business, but why do you want to run such wide wheels? Planning on 245-265mm front tire width or 275-305mm rears?? Planning on putting down major power? (turbo)
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 10-22-2012, 09:46 PM   #164
JoeBoxer
JoeBoxer's Avatar
I can't see those works being 5x100 unless they are dual drilled that's a 350z/S14 fitment.
Old 10-22-2012, 11:52 PM   #165
TotsGT86
TotsGT86's Avatar
Drives: Toyota
Question about these since I don't know anything about wheel fitments..
Hi everyone,
I am currently looking at these wheels
http://www.xxrwheels.com/xxr_522_16.shtml#
XXR 522 in chromium black, my friend gave me some fitments but I`m not 100% on them so I was wondering if everyone could help me out!
The fitments he gave me were
18x8.5 +36 front on 225/40/18
18x9.5 +40 rear 245/35/18
I would love for my wheels to be flush with the fenders! If anyone knows please let me know! Thanks!
TotsGT86 is offline   Reply With Quote
Old 10-23-2012, 12:02 AM   #166
itsibarra
itsibarra's Avatar
Drives: Supercharged Car
http://www.ft86club.com/forums/showthread.php?t=7535
Use the charts, look at pics, and see other members wheel ratios with their setups.
Edit: Looks like your wheels should fit pretty flush according to DarrenDrivens sources.
itsibarra is offline   Reply With Quote
Old 10-23-2012, 12:09 AM   #167
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
yeah that fitment is fine
edit: though what you linked to is only 16" in 4 lug. could swear they made these in 5 lug and up to 19's...
dori. is offline   Reply With Quote
Old 10-23-2012, 10:12 AM   #168
bakerr6
they do make them in 5 lug and up to 19s. The wheels come in 2 different series though from what I understand, adn he needs to click on the other series
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Search this Thread:
Advanced Search
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
