Old 07-16-2019, 04:03 PM   #21015
Pooponwindows
Drives: 13 frs
Originally Posted by Jordanwolf View Post
This seems like such a wide open track with very big corners.
Gingerman raceway if you want to look at the layout
Pooponwindows is offline   Reply With Quote
Old 07-16-2019, 04:07 PM   #21016
Pooponwindows
Drives: 13 frs
Originally Posted by LancePower View Post
I've never been on a track, so you've got me beat.
You should change that
Old 07-16-2019, 05:59 PM   #21017
Carsnguitars
Drives: 2014 FR-S
Washed, waxed & fresh tire grease...
Carsnguitars is offline   Reply With Quote
Old 07-16-2019, 07:40 PM   #21018
humfrz
I like the red stripes. Usually, I don't like stuff like that, but on your car, they look good -
humfrz
Old 07-17-2019, 01:29 AM   #21019
orz
orz's Avatar
Drives: Halo
Installed a Rexspeed A pillar, Defi oil pres, and water temp with some random parts.
Upgraded to a set of these Eyes of Mega Tron LEDs. Had Sylvania ZXE's that lasted 25k miles.
These have a 6k color temp and is brighter than my future. Has a built in cooling fan and adjustable beam pattern. The cut off is nice and sharp.
Everything seems to work like factory.
Bleed the coolant system using this pretty neat funnel.
The sensor required a 1/8pt fitting.
I tapped into the gallery plug using a subaru adapter and crush washer. torqued it to 18.1ft-lbs.
I used these add a fuses to keep things simple. I used: stop(12v), radio(12v ign), panel(lighting), screw(ground)
Hope you enjoy these pics. The project 86 is done for now. Next time, payoff car loan.
orz is offline   Reply With Quote
Old 07-17-2019, 02:45 PM   #21020
RickyBobby
Drives: 2013 Firestorm FR-S AT
I replaced my very old TomTom XL N14644 4.3 inch screen GPS with a Garmin DriveSmart 61 NA LMT-S 6.95" GPS refurb from BuyDig for $99. shipped with coupon code July19. https://www.buydig.com/shop/product/...-Year-Warranty Currently selling new for $189.99 at Amazon.
I received it yesterday. It looks brand new. It came with the suction cup mount, power cable, USB cable, and the Quick Start manual. The full manual can be downloaded here: http://static.garmin.com/pumac/Drive...1_61_OM_EN.pdf
The 6.95" screen is huge compared to the TomTom. Updated its software and maps with the free Garmin Express software. Good deal for $99. with a 1 year warranty, lifetime map updates, bluetooth, wifi, and voice command.
RickyBobby is offline   Reply With Quote
Old 07-19-2019, 06:14 PM   #21021
Decep
Drives: 2013 FR-S Series 10
New TOB, verus forged clutch fork, new clutch/flywheel. Also the perrin rear shifter bushing. That bushing is great, transmission feel is so solid now.
But holy crap the increase in vibration can be intense in certain situations.
*edit* could actually be the new clutch breaking in too.
Old 07-19-2019, 06:41 PM   #21022
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Mounted/balanced 2 tires for my stock wheels, and 1 tire for my Weds.
Stupid discount tire. Charged me dismount x3, mount x 3, and balance x3 because i brought outside tires. $105.
Would have been half the price if I bought their own tires.
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 07-19-2019, 08:17 PM   #21023
Ashikabi
Ashikabi's Avatar
Obviously too late for you but maybe someone else can use it... I saw a hydraulic slave/throw out bearing combo(one unit) for the ft86 chassis somewhere. It was expensive but eliminates the clutch fork entirely. Would replace your slave and throw out bearing. This was functionally identical to those used on LS engines/transmissions
Old 07-19-2019, 10:53 PM   #21024
jflogerzi
jflogerzi's Avatar
Bet it's the clutch. I had the same problem with light load and 2 high of gear.
2013 Series 10 FRS #553
Old 07-19-2019, 11:19 PM   #21025
Decep
thats actually when i hear and feel it. little bit heavier load, low rpm in the next gear. like getting out of 1st gear @ 10 mph and trying to accelerate a bit too much in 2nd. im assuming it should go away as everything wears in
Old 07-19-2019, 11:20 PM   #21026
Decep
i remember that thread, pretty cool.
Old 07-19-2019, 11:50 PM   #21027
jflogerzi
jflogerzi's Avatar
I think it does. I am about at 2000 miles on my new clutch. I will test and report back
Old 07-20-2019, 01:21 AM   #21028
Steveiam
Drives: 86
Car got hit by a wood panel that fell off a truck in front of me going 70 on the highway. Didn't want to brake and get rear ended so the front bumper took the hit. Luckily, the only damage was loose grille and a few barely noticeable scratches.
Got home and clipped the grille back on and good as new! Kind of bummed out as I've only had the car for about 3 weeks. On the other hand, the wood piece didn't fly through the windshield.
Steveiam is offline   Reply With Quote
Search this Thread:
Advanced Search
