Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
08-04-2020, 12:50 AM | #1 |
Drives: White GTS then Black GTS
re-alignment after rear height adjustment
I recently have the whiteline rear subframe bushes installed and notice the rear ride height increase a bit, like 5mm. I want to lower the rear height from my coilover by 5mm. Do I need alignment at all given the rear camber is not adjustable for our car?
08-04-2020, 01:49 AM | #2 |
Drives: 2014 GT86
Obviously, every time one unbolts/tightens something in suspension more then probably alignment gets out of whack and realignment is needed (including those bushes install). Unadjustable camber with stock LCAs aside, there is toe. Toe settings out of whack can introduce lot of handling issues/artifacts. Only time when you don't need alignment is changing wheels.
The Following User Says Thank You to churchx For This Useful Post: | Tcoat (08-04-2020) |
08-04-2020, 05:46 AM | #3 |
Drives: '13 FRS - STX
Lowering the rear by 5mm will introduce a very slight amount of toe in, for a Street driven car you should be fine to not go to a shop imho.
08-04-2020, 06:40 AM | #4 | |
08-04-2020, 07:09 AM | #5 |
You don't have to touch the alignment at all when moving the spring perches a modest amount evenly, the impacts are negligible to daily drivers.
Edit: looked at my notes, going from 26" top of fender arch down to 24.4" top of fender arch introduced a whopping 1mm of toe in for the rear. OP is probably moving his 5mm within that range and won't notice much of a difference. |
The Following User Says Thank You to strat61caster For This Useful Post: | Icecreamtruk (08-12-2020) |
08-04-2020, 08:00 AM | #6 |
Drives: 2014 GT86
There is chance that some part upgrades change alignment evenly .. but there still is problem of some play/slack is in most connections, and unbolting/retightening to install/change those parts that by themselves should be changing "evenly", also can fsck up alignment at extremes of that play. I had some alignment caused handling issues in past, fixed by realignment, later had desired handling changes on track, via alignment .. in my book/experience importance of proper alignment in car that is "driver's car" is placed high enough and imho not worth slight savings by not doing. If anything, uneven tire wear and due that spent more money on tires can offset alignment job costs, even if not valuing in money satisfaction of properly running car not needing any driver input workarounds.
08-04-2020, 12:04 PM | #7 |
Y'all clearly don't adjust your own ride heights...
The Following User Says Thank You to strat61caster For This Useful Post: | e1_griego (08-04-2020) |
08-05-2020, 12:04 AM | #8 |
Seņor Member
As mentioned above, for 5mm drop you could get by without an alignment. That said if you changed subframe bushes chances are the alignment of the rear subframe changed also. If it were me, I would get an alignment. They are cheap and will give you peace of mind.
1974 TA22 Celica
2013 86 GT |
08-05-2020, 01:20 AM | #9 | |
08-05-2020, 02:24 AM | #10 | |
Seņor Member
1974 TA22 Celica
2013 86 GT |
Similar Threads | ||||
Clutch height adjustment | Hugo | AUSTRALIA | 13 | 04-30-2020 01:12 PM |
Height Adjustment stuck? | v86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 06-11-2018 12:22 AM |
Height Adjustment | Jeremehh | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 30 | 01-11-2018 01:40 PM |
Seat Height Adjustment | Norman Tyler | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 11-30-2014 07:26 AM |
Clutch pedal height adjustment, just do it | Suberman | CANADA | 0 | 10-24-2013 06:00 PM |
