12-26-2012, 11:41 PM | #729 |
Drives: 2013 Raven FR-S, 2005 Dodge Ram
[QUOTE=ill86;627575]A fine selection.
Thanks for the input. So with that set up, 18x8.5 and 18x9.5 +45, I can run them with the stock suspension with no problems (rub)? And how will it line up, I'm not wanting any poke.
2013 FRS 6AT in Raven! |
12-27-2012, 12:04 AM | #730 |
wheel gap
Drives: whiteout frs, 04 xrs
i run 18x8.5 +30 rear, +42 front with 215/40 with some camber, my ride height is pretty low.
i have really grown to enjoy driving my setup, i like the tail happiness of a stiffer / lower ride setup. will only get better with a better alignment, rear control arms and toe arms are on my list next.
The Following User Says Thank You to Jesse For This Useful Post: | ill86 (12-27-2012) |
12-27-2012, 12:43 AM | #731 | |
VehicleDynamicsSpecialist
Drives: iG FR-S
With a little camber front and rear it will most likely be what you are after. Only gets better with age. :-) Too many other factors (actual tire width, alignment, etc) to be more precise. There's a little wiggle room, but you're still playing it safe/conservative. |
The Following User Says Thank You to ill86 For This Useful Post: | FRSGT86 (12-27-2012) |
12-28-2012, 05:54 AM | #732 |
Drives: 86
Hi all,
I have purchased some 18 x 9.5 +35 rims and looking to fit very shortly - I have also got some Eibach Pro Kit springs ready to go for a (hopefully) 1 inch drop all round.... Just wondering on tire sizes which would be suitable to clear guards/fender etc with no rubbing? I have seen a few setups which have coils and thus clear, but not so sure on springs, thats all... From reading up, my guess is 235/40/18 all round to be ok,, but just trying to double check before I go ahead! In my state tto stay legal , your total wheel diameter cannot go increasing by more than 26mm from standard, so the above tire size is what fits the bill here,,, Many thanks! |
12-28-2012, 09:39 AM | #733 | |
Drives: iG FR-S
12-28-2012, 09:51 AM | #734 |
Suspension: Tein S-Tech or Eibach Sportlines
Front: 18x8.5 +45, 235/40 Rear: 18x9.5 +45, 265/35 Thoughts on fitment?
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm.. |
12-28-2012, 10:01 AM | #735 |
Drives: iG FR-S
The Following User Says Thank You to ill86 For This Useful Post: | itdansharpe (12-28-2012) |
12-28-2012, 10:00 PM | #736 |
Would these tires fit on my stock wheels?
Dunlop Wintersport 3Ds, 235/45 17". The stock wheels are 17" but the stock tires are 215/45 17".
12-28-2012, 10:13 PM | #737 |
Drives: 13 whiteout scion frs
Yes they will. Wrong section btw
12-28-2012, 11:32 PM | #738 |
Site Moderator
Drives: Stuff
Dunlop specs 7.5-9.0" wheels, so in theory the OEM wheels are too narrow.
A better question for the OP is why go wider for winter tires? You want narrower, not wider. 235s on a 7" wheel will be very hard to mount (tire guy may refuse) and will ballon like a mofo.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
12-28-2012, 11:38 PM | #739 |
Make me a mod please!! Lol
12-29-2012, 01:32 AM | #740 |
Drives: 2013 86 GTS - Pegasus White
Maximum tyre width (for rear wheels)
Hey Guys,
I'm thinking of going for a staggered setup on my 86 (tyres only, not wheels). The rims I like are 18/8.75/35+ (front/rear). I'm getting 235s for the fronts and just want to know how wide I can go for the rear? Thanks. |
12-29-2012, 06:17 AM | #741 |
Drives: Red FRS
depends on how far you're willing to go to make it fit.
http://www.ft86club.com/forums/showthread.php?t=24694 You should specify if you want to keep the fenders as they are, or roll them and if you're on stock suspension / springs / coils |
12-29-2012, 07:50 AM | #742 |
Prefer not to touch the fenders. Just want to know how much tyre you can fit in the arch as per stock. I should add that I'm also looking to drop about 1".
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Similar Threads | ||||
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
