08-08-2022, 12:55 AM | #239 |
Drives: 2014 BRZ
Did anyone end up needing the T'eyes Power Filter? I get severe feedback as soon as my amp is connected. There is an alternator wine as well.
My amp setup had a black wire that was spliced into the black wire of the 10-pin harness. I reproduced this setup with the new harness, but it didn't make any difference.
08-22-2022, 02:06 PM | #240 | |
I know you don't feel like installing the new camera that came with the HU but I strongly suggest you do. I was lazy and reused my OEM camera at first but then did a quick test fit outside the car just to see what the Teyes camera looked like and was blown away by the differance. It's well worth it to install the new camera. It's really that much better. |
08-23-2022, 02:22 PM | #241 |
Drives: 2014 BRZ
The power filter improved the interference. I don't hear any alternator wine anymore. I do still get a high pitched sound when turning on my headlights, but that fades out in 10 to 15 seconds.
I still seem to have some sort of grounding issue though. About one in 10 times that I start the car, I get a pop sound and either the front or back speakers won't work. Powering the head unit off and back on resolves. I have the gain dialed in, and everything sounds great. No other interference. I hate to ask for general audio advice here, but does anyone have any tips? I've confirmed that the amp is still properly grounded, and tried splicing an additional ground wire into the harness. I don't see any exposed wiring. Nothing was changed other than the HU.
08-24-2022, 08:57 PM | #242 | |
Drives: Asphalt FR-S
Sent from my Pixel 6 Pro using Tapatalk |
08-29-2022, 04:09 PM | #243 |
Drives: 2015 FR-S
Hey guys, I want to use CarPlay for maps/navigation with my iPhone but also would like to see OBD data. Do I just need to buy the OBD2 BT adapter or would I also need to root the device and install the torque App and switch between CarPlay and Torque App? is there a TEYES native app that shows all the OBD2 data?
Anyone see a difference in performance with the 3G+32GB version vs the 6G+128GB version? Which one does everyone have Looks like they also have a new FW update for august 2022 https://www.teyes.com/pages/normal-c...-2022-firmware Last edited by FrickingReallySlow; 08-29-2022 at 05:34 PM. |
08-29-2022, 10:29 PM | #244 | |
Drives: 86 GTS
I am having a similar problem. It does not sit flush and securely in the dash with the trim provided. There were no clips provided by Teyes, which was disappointing for a $650 AUD HU. I am finding that OEM clips are too loose on the trim provided, they are almost impossible to take off on the original trim but come off easily on the Teyes trim. I have lost about 10 clips in the dash because they are loose. The HU has come off loose and fallen a couple of times while driving. Any suggestions how to fix the issue? Last edited by Here2rock; 08-29-2022 at 10:43 PM. |
08-30-2022, 04:17 PM | #245 | |
Drives: 2015 FR-S
Did you order recently from teyes website? Seems most people says it’s too snug. Maybe contact them for a replacement trim
08-30-2022, 08:30 PM | #246 |
Drives: 86 GTS
Yes I did order directly from Teyes, mine is too loose with the OEM clip. It is pain in the back side to return and ask for a replacement.
09-26-2022, 07:38 PM | #247 |
Drives: 2014 BRZ
Well, this has been nothing if not frustrating. I never got rid of the feedback, and later experimentation with the gain on my amp has made me wonder if I even ever improved it at all. The popping issue continued, and upon trying Apple Carplay, I started noticing strange screen discoloration. The discoloration only affects certain screen elements, and generally disappears when navigating to another app. (Image below is edited to remove street names).
In addition to the power filter, I tried RCA caps and several different grounds. Eventually, I gave up and brought it to a shop. They confirmed that the issue was the unit itself. I suppose there could be other possibilities such as incompatibility with my amp or something, but the only route I see now is T'eyes support. Needless to say, I'm bracing myself for more frustration. Anyone have any tips?
10-06-2022, 05:19 PM | #248 |
Drives: 2014 BRZ
I set up a return with AliExpress, but all I really want is to exchange the tablet.
T'eyes referred me to the AliExpress seller, who in turn referred me to their "engineer" via WhatsApp. That inquiry has been unanswered for the better part of a week. I'm running out of time in the return window, so I guess I'm ripping all the wiring out tonight. I'm hesitant to repurchase the same unit, but I wonder if the OBD2 dongle I got would work with a similar unit from a different manufacturer.
10-13-2022, 04:34 PM | #249 |
This is a CarPlay issue that effects all CarPlay headhunts, including CarPlay that comes OEM in the GR86. If you look on Reddit r/CarPlay you will see people complain about this all the time. It doesn't happen to me that often so I don't worry about it much. I suspect it's due to packet lose over the WiFi connection which probably wouldn't happen if I connected via USB but I've never bothered to try.
10-13-2022, 07:32 PM | #250 | |
Drives: 2014 BRZ
In my case, the problem was pretty severe. It inevitably looked like that after about 10 minutes.
10-14-2022, 10:27 AM | #251 | |
The Following User Says Thank You to ermax For This Useful Post: | TheBRZsKnees (10-14-2022) |
11-02-2022, 02:01 AM | #252 |
Drives: 2014 BRZ
I've returned the T'eyes unit and purchased a 9" Joying Android 10 unit instead. The Joying system has been so smooth by comparison. The harness took a bit more figuring out, but the audio is clear and powerful. No visual artifacts in Carplay. And the Joying unit has a volume knob, which is way more of a benefit than expected.
Seems I was just unlucky with the CC3 since I'm not seeing many similar experiences. I wouldn't go back to T'eyes though. Anyway, I have an unused T'eyes OBD II dongle that I'll sell cheap if anyone wants it...
Similar Threads | ||||
Android based stereo vs. stereo w/ Android auto | redlined600 | Electronics | Audio | NAV | Infotainment | 12 | 02-24-2019 02:53 AM |
200mm android head unit with android lollipop | rsingh | Electronics | Audio | NAV | Infotainment | 3 | 05-23-2016 08:48 PM |
WTB: Android HU | tonypalomo | Want-To-Buy Requests | 0 | 01-12-2015 03:00 PM |
Help|Best Android based HU | redsuns03 | Electronics | Audio | NAV | Infotainment | 14 | 07-28-2013 08:30 AM |
Android vs iOS vs BB os...which is best? | Raiden | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 02-02-2011 10:37 PM |
