11-11-2016, 02:12 PM | #3781 |
The Rotrex produces significant less heat than most other superchargers. The Jackson Racing kit is the most proven track kit on the market.
11-11-2016, 02:59 PM | #3782 |
It's been tried and proven in the California desert in ambient temps over 120F. I think it will be just fine in AZ; we've done several cars for AZ customers who have either flown a CSG member out, or driven the car to CSG for installation.
11-15-2016, 05:28 PM | #3783 | |
Drives: 2013 BRZ (RIP), now 2017 BRZ
I'm not sure if it's the way the hose is routed or if it is because I put a zip tie through the tab in the headlight bumper support. Anyone know if that tab is functional? I wanted to route the hose behind the charge pipe, but then the hose would dip down like a P trap underneath a sink. Anyway, the gap under the headlight isn't very noticeable unless you are looking for it. I think I would've ordered the S12-12B-WR1 Kraftwerks bottle if I had known. Aside from the minor bumper issue, the supercharger is just what I was looking for. NO heat issues like a turbo and there is no risk of burning or melting anything. I can still use my a/c without the engine overheating. I wasn't looking for crazy HP. The power it has now is just right. I bought my kit directly from Jackson Racing and they have been great! I had an issue where the high performance PCV valve was defective and split in two pieces. Weird right? They shipped a replacement the same day. No hassles. |
11-15-2016, 05:46 PM | #3784 |
Drives: 2015 AOZORA EDITION
anyone kno if the apr brake duct kit for brz will work with the supercharger?
11-15-2016, 10:51 PM | #3785 |
Drives: 2015 supercharged frs
Hey anyone out there get a system running to rich bank 1?
theses are the codes p0172 , p117b, c1201 tried cleaning my maf and it worked fine for a bit but after a while they came back on... any hints? |
11-16-2016, 01:38 AM | #3786 |
11-16-2016, 01:38 AM | #3787 |
11-16-2016, 08:49 AM | #3788 | |
Drives: 2013 BRZ Limited M/T
The Following User Says Thank You to Bramick For This Useful Post: | arren123 (11-17-2016) |
11-16-2016, 05:47 PM | #3789 |
These questions have probably been answered somewhere in this thread but its to long to find everything. I have no experience with SC's so sorry for the newb questions. I have a 2013 FRS AT with OFT and a drop in K&N air filter.
1. How many miles would one expect to get from this SC before it needs a rebuild and how much does that cost? 2. Is this the best one for a DD? I am more worried about reliability than the power it makes since I don't track the car. 3. If there is a catastrophic failure of the SC is there anything in place to save the engine? 4. Everything I have read says all the components in the car can handle up to 300hp. What seems to fail and should I upgrade those components when I have the SC installed to avoid headaches later? 5. Does the OFT i currently have work with the SC or do I need the Ecutech chip? 6. How long does the engine seem to last before it needs to be rebuilt? I drive it hard but don't race it. Just looking for an estimate since i know there are tons of variables that contribute to this. Thanks for the help in advance. |
11-16-2016, 06:05 PM | #3790 | |
Sarcastic SOB
11-16-2016, 09:46 PM | #3791 | |
2. It's the most proven system on the market 3. The entire intercooler system 4. You don't need to upgrade any engine internals for the supercharger it in factory sypplied form. 5. You will need an Ecutek tune. 6. Same as #1. |
The Following User Says Thank You to CSG Mike For This Useful Post: | Riftur (11-19-2016) |
11-28-2016, 12:28 PM | #3792 |
Drives: 2013 Red BRZ Limited
Is it OK to drive after install without a tune? Reason I ask is the tuner I prefer to use is 3 hours away.
11-28-2016, 12:49 PM | #3793 |
Drives: 14 Ultramarine FR-S
Trailer it or just use the CARB tune if you can get your hands on it.
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD |
11-28-2016, 12:57 PM | #3794 |
Similar Threads | ||||
Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
