07-20-2022, 02:25 PM | #323 | |
Drives: None
With FI, as long as you're not trying to make a bunch of torque down low it should live a pretty decent life at 350whp.
The Following 2 Users Say Thank You to RedReplicant For This Useful Post: | FrickingReallySlow (07-20-2022), Irace86.2.0 (07-21-2022) |
07-21-2022, 11:30 AM | #324 | |
Drives: 2017 Hot Lava 86
The Following 3 Users Say Thank You to Ebush For This Useful Post: |
07-21-2022, 05:33 PM | #325 | |
Drives: Q5 + BRZ + M796
And the cost of a built FA20 after buying a replacement motor would have been too expensive like $8-10k with a bigger risk than I wanted if the motor blew again.
The Following 3 Users Say Thank You to Irace86.2.0 For This Useful Post: |
08-14-2022, 02:42 PM | #326 | |
Drives: 2015 FR-S
Would there be a need to use the typeS oil pump since the K24 original one seems to be good to 8K and the WHP is dropping off after 7.5K looking at your dyne plots? maybe just porting the original pump with the balance shafts would be a better option for FI setups? you lose some pressure since you have to feed the balance shafts but some porting work or larger pump gear (6 tooth on type S vs 7 tooth in k24) may get you what you need?
08-14-2022, 03:41 PM | #327 | |
Wears Pants
Drives: 14 FRS K24 swap - SOLD
I was thinking on this a bit today as well even for NA application. The question would really be whether the pump assembly fits with the Kpower oil pan and if so does the baffling work as intended? |
The Following User Says Thank You to captain awesome For This Useful Post: | FrickingReallySlow (08-15-2022) |
08-14-2022, 11:32 PM | #328 | |
https://www.s2ki.com/forums/s2000-fo...1180669/page3/
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | FrickingReallySlow (08-15-2022) |
08-15-2022, 01:10 PM | #329 | |
Drives: 2015 FR-S
Thanks didn't know that the baffle and custom pan and height could be an issue here. Btw what does the return system buy you? just more even fuel pressure at all RPM instead of being regulated? or just ease of tuning
08-15-2022, 05:41 PM | #330 |
More constant pressure and temperature, which makes tuning easier and results in more fuel. A returnless system has unused fuel sitting in the fuel rails heating up, as it waits to get burned, which results in a drop in fuel pressure, I believe, and higher fuel temps. The drop in pressure might be from fuel evaporation leading to micro gas pockets. What I do know if that a boost reference FPR is also needed. This increases the fuel pressure proportional to boost, so 60psi with vacuum will raise to 70psi at 10psi of boost. Why is this necessary? Pressure in the rail is 60psi, but pressure in the manifold is 10psi resisting the fuel from squirting out of the injector, so actual fuel pressure at the injector is 50psi, which means the injector is slowly losing potential with the rise in boost, which is exactly the opposite of what you would want. I was seeing fuel pressures in the mid forties after breaking 10psi, which means my injectors at max duty cycle were inadequate despite other with return systems with a reference FPR making far more power.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | RedReplicant (08-15-2022) |
08-15-2022, 06:47 PM | #331 |
Drives: None
Worth seeing if you can get a writeup out of ML since he repurposed the unused stock line as a return.
08-15-2022, 08:09 PM | #332 | |
Drives: 13 White MT FR-S
my setup is a hybid I guess with a surge tank in the engine bay. So the fuel goes to the surge tank and then there is a return from the surge to the fuel cell (re using one of the stock fuel lines). then from the surge tank it goes to a boost referenced FPR to the fuel rail which i guess from there is considered "returnless"
The Following 3 Users Say Thank You to ML For This Useful Post: |
08-15-2022, 10:19 PM | #333 |
I will probably run -6AN lines to something like this. I'll have to research it more when I am ready to make the changes to a new tranny.
https://fullblownmotorsports.com/ful...frs-subaru-brz
08-16-2022, 07:18 AM | #334 | |
-6 is what I'm running. that kit seems way overpriced though
08-16-2022, 09:30 AM | #335 |
Wears Pants
Just saw that Deatschwerks came out with a dual pump assembly. It's supposedly capable of keeping fuel flow below 1/8th tank plus I think it may flow enough for your application.
https://www.dropbox.com/s/bblxuif0w6...eid=236b735dae Edit: It's expensive. Like really expensive. Also requires return line. |
The Following User Says Thank You to captain awesome For This Useful Post: | ML (08-16-2022) |
08-16-2022, 10:08 AM | #336 | |
thats pretty sweet! you can get it without pumps for $430
Tags |
worst.build.ever. |
Similar Threads | ||||
Irace86.2.0 Build | Irace86.2.0 | Member's Car Journals | 195 | 03-25-2024 12:29 AM |
KPower Industries K24 swap | PulsarBeeerz | Engine Swaps | 1756 | 03-13-2024 01:42 PM |
Turbo or swap | Fastend | Forced Induction | 35 | 06-11-2020 07:12 PM |
Built Turbo K24 Swap? | Calmwhiteguy | Engine Swaps | 31 | 02-13-2018 05:07 PM |
IRACE86's Build | Irace86 | Member's Car Journals | 25 | 01-10-2017 04:35 PM |
