BT, dpfarr
Old 06-20-2018, 09:41 PM   #2815
CSG Mike
CSG Mike's Avatar
Get a quieter catback.
Want peace and quiet? Go with the Touring86.
The Laguna90 is not meant for FI applications.
funwheeldrive (06-22-2018), Proseph (06-20-2018)
Old 06-20-2018, 10:29 PM   #2816
Proseph
Drives: Supercharged 2016 CBS BRZ
Would the Touring86 really make it quiet? even with a 3inch frontpipe?
Proseph is offline   Reply With Quote
Old 06-20-2018, 11:03 PM   #2817
CSG Mike
CSG Mike's Avatar
Catless, it still passes laguna.
Old 06-21-2018, 07:08 AM   #2818
Jrdad
Jrdad's Avatar
Drives: 2013 Scion FR-S 6M Argento
FWIW, I have a Touring86 exhaust with headers, op and an UQFP, but N/A. The exhaust is barely a hum when doing 75mph until you accelerate.
Jrdad is offline   Reply With Quote
Old 06-22-2018, 11:17 AM   #2819
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Also have the touring 86 with ace a350, quiet at cruise, pretty loud on acceleration.
B T is offline   Reply With Quote
Old 06-22-2018, 04:12 PM   #2820
cjopant
cjopant's Avatar
Drives: 2015 Subaru BRZ
I'm running the Touring86 with a catless JDL UEL header, and it's super quiet. Even at WOT, it's pretty subdued. Definitely aggressive, and definitely UEL, but nowhere near as loud as I expected/feared.
cjopant is offline   Reply With Quote
Old 06-24-2018, 04:39 PM   #2821
Teku18
Drives: 2014 WRB BRZ
Do you have a over pipe and front pipe at all?
Teku18 is offline   Reply With Quote
Old 06-25-2018, 01:29 PM   #2822
cjopant
cjopant's Avatar
Stock for now, but likely going dual resonated soon.
Old 06-27-2018, 07:07 AM   #2823
Proseph
How to check if DI seals have gone bad? My tuner is saying this may be the case as it is a common problem with these cars when boosted so I’d like to check.
Old 06-27-2018, 02:15 PM   #2824
CSG Mike
CSG Mike's Avatar
You'll hear a firecracker noise when you blip the throttle.
Unless you have an early 2013, this does not apply to you.
Proseph (06-27-2018)
Old 06-27-2018, 03:12 PM   #2825
Proseph
Now I'm really confused since I have a 2016 BRZ. No idea what it could be then... He says it's either a bad DI seal or a direct injector is not firing from what he can tell through the logs. What would you recommend doing?
Old 06-27-2018, 03:38 PM   #2826
CSG Mike
CSG Mike's Avatar
I recommend paying a second tuner to just review your logs for a second opinion. Perhaps @DeliciousTuning?
Old 06-27-2018, 03:41 PM   #2827
Proseph
That is my tuner, I don't think I would choose anyone else. They are great.
Old 06-27-2018, 03:43 PM   #2828
CSG Mike
CSG Mike's Avatar
Try swapping in different injectors, or getting your injectors cleaned by any injector cleaning service. It's possible for injectors to degrade in flow and spray pattern over time.
Also check for vacuum leaks.
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) -- General Topics 0 05-24-2012 10:09 PM
