Old 07-14-2019, 01:28 AM   #8541
kev0
Drives: '14
Originally Posted by jflogerzi View Post
Picture where the leak is?
Found the leak with air pressurizer and soapy water. Loads of bubbling from the areas circled and probably more below the intake pipe. I believe the gaps were there from over-tightening the hose clamp and caused it to deform overtime.
kev0 is offline   Reply With Quote
Old 07-14-2019, 01:36 AM   #8542
jflogerzi
jflogerzi's Avatar
Call sprintex direct and order the part. I would not drive it. Their number is on thier website.
2013 Series 10 FRS #553
Old 07-14-2019, 01:40 AM   #8543
kev0
Drives: '14
Ok, thanks. Already got in contact with them. They said it'll be $95. Not bad.
Old 07-14-2019, 02:08 AM   #8544
jflogerzi
jflogerzi's Avatar
Get faster shipping.. don't mess with janky fixes.
Old 07-14-2019, 07:33 PM   #8545
kev0
Drives: '14
This is the leak in my intake tube. Pretty big, dont you guys think? Anyways, waiting for Sprintex to send me the invoice. Fingers crossed that this is what is causing my vacuum leak.
Old 07-15-2019, 12:55 AM   #8546
kev0
Drives: '14
Oh jesus...i think I just fixed the problem by cleaning my MAF sensor.. fuel trims are +/- 10% now..
Old 07-15-2019, 02:06 AM   #8547
86TOYO2k17
Drives: 2017 toyota 86
Nice, didn’t I tell you to do that like 3 or 4 times now lol...
I would still get that leak at your intake pipe squared away. But you might finally be good to go now.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
kev0 (07-15-2019)
Old 07-16-2019, 03:53 PM   #8548
kev0
Drives: '14
Welp, pretty sure I found the last major leak in my SC. Anyone know how to fix this..? Preferably something I can do at home and not order a new one.
Old 07-16-2019, 04:19 PM   #8549
86TOYO2k17
If only someone had told you to check that over two weeks ago...
https://www.ft86club.com/forums/show...postcount=8496
Lol at least you found it.
Not much you can do to fix that and reuse it. Just Get a new one. Could try JB weld and tape for a temporary fix. Just don’t mess up the hose if you do.
Old 07-16-2019, 04:23 PM   #8550
kev0
Drives: '14
I appreciate all the help. I have no experience with cars so I don't know where most parts are like 'bypass valve' and evap solenoid is. Hahaha, well I guess this is the opportunity to learn.
Going to just head to O'Reilly's and find a new connector.
Old 07-16-2019, 04:33 PM   #8551
86TOYO2k17
According to sprintex it’s technically called a intake vacuum actuator. But most people will know what your referring to if you say bypass valve.
Definitely a good idea to learn as much as you can about your car and the sprintex system in general as there is a lot more to it then just install/setup but maintaining, troubleshooting, and being able to tell/know if/when an issue happens or is about to happen. A lot more involved then maintaining a stock car.
Fixing that will definitely help those fuel trims a lot.
kev0 (07-16-2019)
Old 07-16-2019, 05:40 PM   #8552
kev0
Drives: '14
Dang. Fixed the tubing and STFT is positive and maxed out on idle. Only thing left to check is my header for leaks. Not sure if a leak can even cause STFT to go that high.. Fuel trims are normal during cold startup but once idle drops down, my STFT maxes out. ughhh
Old 07-16-2019, 05:53 PM   #8553
86TOYO2k17
You fixed the vacuum actuator elbow that cracked?
Did you fix your leak on intake pipe at coupler yet? This should be priority done ASAP.
You also mentioned something about your tuner doing something to compensate for your bad fuel trims, but this was done with several leaks and issues... it’s possible it may need to be reverted or further changed now that the leaks are resolved. No point in changing around tune parameters when you have leaks and issues you need to resolve. Once resolved 100% then get tuned. And until resolved 100% and tuned do not drive it.
Old 07-16-2019, 05:58 PM   #8554
kev0
Drives: '14
Just the black elbow connector was cracked. I replaced that.
I temporarily fixed the coupler leak but moving the metal clamp closer towards the front so it could seal the gap more. Going to try reverting to a base tune to see if that will fix it.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
