05-19-2014, 10:32 AM | #1401 |
05-19-2014, 10:38 AM | #1402 |
How much you suggest?
I forgot to say that I have OEM sway bars, but front and rear cusco tower bar (if this may affect in someway)
05-19-2014, 10:49 AM | #1403 |
See if you like what you have now.
- Andy |
05-19-2014, 10:58 AM | #1404 |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
So I autocrossed yesterday with my new suspension, Bilstein B8 shocks with RCE Tarmac springs. Front camber is 0 and the rear is -1.8-2.0 with stock wheels and rubber.
I noticed a significant amount of understeer; I believe a decent amount of that is due to no camber in the front. This leads me to two questions for you guys. 1) I daily drive this car in addition to autocross; what is a good compromise in terms of front camber to be decent at both driving aspects? 2) How much will adding negative camber to the front reduce oversteer / increase oversteer? Thanks in advance! Sent from my SCH-I535 using Tapatalk
05-19-2014, 11:03 AM | #1405 |
0 camber is no bueno.
1. You could easily go -1.5 to -2.0 up front without worrying about tire wear depending on your commute, especially with very little or no toe. Think about how much your rear has right now/from the factory, and the front needs it even more. I'd expect worse and more uneven wear with 0 camber to be honest. 2. The change will be pretty huge. You need that camber bad! - Andy |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Turkish (05-19-2014) |
05-19-2014, 11:34 AM | #1406 | |
Drives: MT WRB BRZ Limited, 2007 911s
The Following 2 Users Say Thank You to was385 For This Useful Post: | Racecomp Engineering (05-19-2014), Turkish (05-19-2014) |
05-19-2014, 11:47 AM | #1407 | |
Drives: 2013 Subaru BRZ
The Following 2 Users Say Thank You to andrew20195 For This Useful Post: | Racecomp Engineering (05-19-2014), Turkish (05-19-2014) |
05-19-2014, 12:42 PM | #1408 |
Drives: 2022 BRZ Limited
newbie question @Racecomp Engineering @CSG Mike
after I installed my coilovers, I took my car to the alignment shop after I drop the car about 1.5" all around the guy told me I got -2.5 and -2.8 in the rear and around -1.5 and -1.2 at front wheels so I asked him to give me more camber by adjusting the camber plates and I was able to see -3.0 on front L/R afterwards, after I attended the track event I think my ride height dropped a little bit maybe it settled a bit or the camber plates ( since it changed the angle a bit) or the combination of both.. so my question is Can I raise the car a little bit and if I do, Do I have to take it for another alignment? I assume I might lose some camber in the front but I am looking for 1.5" drop all around and it's almost 2" now Thanks in advance
05-19-2014, 01:43 PM | #1409 | |
As for if you need another alignment after raising it back up a half inch...it depends how anal you are. I'd do it, and I'd get some rear LCAs and sort out your rear camber while you're in there and then I'd be happy. - Andy |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | glamcem (05-19-2014) |
05-19-2014, 04:45 PM | #1410 | |
05-19-2014, 04:55 PM | #1411 | |
- Andy |
05-19-2014, 05:37 PM | #1412 | |
thanks
05-20-2014, 05:50 AM | #1414 |
Drives: 2014 Whiteout Monogram Frs
would you guys recommend rce yellow/ swift springs on bilstein b8? or with rce tarmac/swift spec r? why?
and what is a basic coilover that can be fitted with swift springs from the factory? |
Similar Threads | ||||
Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
