Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
03-01-2014, 01:25 PM | #43 |
Drives: GBS BRZ AT
Bit too loud for my taste but, I think it sounds amazing lol
The Following User Says Thank You to Clint520 For This Useful Post: | Anthony (03-01-2014) |
03-01-2014, 01:49 PM | #44 |
Drives: 2013 swp brz
so there's absolutely no going back? I guess if you bought a new bumper you could reverse this, right? Looks great, definitely thinking about doing it to mine.
The Following User Says Thank You to lp87 For This Useful Post: | Anthony (03-01-2014) |
03-01-2014, 05:12 PM | #45 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Oh yeah, you can always replace it. But it's one solid piece, so once you saw it off, it's done. You could always zip tie-stitch it back if you wanted, but as far as making it look untouched... nope.
I think a new bumper cover is about $300-350, and then it would have to be painted. So it would definitely be less than $1,000 to totally undo it. Probably about $600, I'm guessing. I don't really know paint prices.
03-01-2014, 06:53 PM | #46 | |
also could probably just ask somebody if they wanted to trade yours+cash for their stock one. Definitely people who would want this. What is that cusco brace called? |
03-01-2014, 09:21 PM | #47 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I don't get it.
Any of it. |
The Following 2 Users Say Thank You to slicktop For This Useful Post: | Jive Turkey (05-14-2014), Koa (12-24-2014) |
03-02-2014, 12:26 AM | #48 |
also did you remove anything besides the plastic diffuser and tail light? I don't see the rear bumper bar
03-02-2014, 11:19 AM | #49 |
Weight Nazi
Rear crossmember brace.
Explaining it any more clearly is beyond my abilities. Yes. See post #2 in my build thread.
03-02-2014, 07:53 PM | #51 |
BOXER FR
Drives: WRB BRZ Limited
Not to thread jack.. But I am working on this if you guys are interested...
http://www.ft86club.com/forums/showthread.php?t=59202
Build Thread of the "STI theme BRZ"http://www.ft86club.com/forums/showthread.php?t=61522
05-13-2014, 03:48 AM | #52 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
It's an easy fix using the stock reverse lights temporarily until something more permanent is decided on. Aluminum angle piece drilled for the top mounting holes in the reverse light and the two center hole locations on the rear of the stock muffler heat shield location and....walla...street legal. Cable tie harness to bumper beam and other areas as needed and done.
Mine, until I finalize the setup (touch up trim the plastic on the rear bumper [I wasn't sure if I wanted to make a cover or not for the bumper beam so left the extra material in case], rework rear bumper beam to trim off the lower flange and spot weld flush, rework exhaust to center exit and tucked up higher for diffusor clearance, go with an LED back up light solution, and make easily removable for maintenance yet fully functional custom diffusor system): My asphalt without its parachute and with interim solution reverse lights... Aero does seem better than with the factory "diffusor" section on there - seems better at higher speeds. Slims up the rear and will look even better once everything is all reworked and diffusor is in place.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
The Following User Says Thank You to Vracer111 For This Useful Post: | Anthony (05-13-2014) |
05-13-2014, 08:50 AM | #53 |
Weight Nazi
Yeah, that's probably exactly what I would have done if street legality was a concern for me.
05-13-2014, 09:41 AM | #54 |
Drives: SWP BRZ Limited Manual. 2014
Why not just buy a new set of taillights have reverse built in?
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|] |
05-13-2014, 01:05 PM | #55 |
Drives: 13 White MT FR-S
The rocket bunny v1 kit came with a piece that replaced the part you cut off. How do you attach that back. I want to do this, but only if I can reverse it.
05-13-2014, 01:55 PM | #56 |
Weight Nazi
There's no going back, unless you count replacing your bumper cover. I think it's only like $300 though.
The Following User Says Thank You to Anthony For This Useful Post: | sklimo (05-13-2014) |
Similar Threads | ||||
FT-86 SpeedFactory Exhaust Hole Deletes - Now you can look good single. | FT-86 SpeedFactory | Cosmetic Modification (Interior/Exterior/Lighting) | 47 | 01-30-2015 09:12 AM |
Another project teaser. Exhaust hole covers for single exit exhaust! | Wonderbar | Cosmetic Modification (Interior/Exterior/Lighting) | 57 | 05-30-2014 01:46 AM |
Single exit rear diffuser/valance? | gabeg86 | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 02-20-2014 05:14 PM |
For Those of Us with a Single-Exit Exhaust | naikaidriver | Engine, Exhaust, Transmission | 12 | 09-05-2013 01:20 PM |
Single exit diffuser poll | adprokid | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 11-08-2012 10:03 PM |
