Old 05-19-2016, 03:00 PM   #15
ze12o
Drives: BRZ 2015 DGM
synchros are a bit jacked on my G35 @ 130K, with Trans fluid changed every ~50K...
ze12o is offline   Reply With Quote
Old 07-10-2017, 06:12 PM   #16
Rinzler_ft86
Rinzler_ft86's Avatar
Drives: 2013 brz limited edition
sorry to open an old thread but has anyone actually ran the cd009 with their 2jz brz? I'm just doing more research to see if it's possible and not over priced to do it.
Sent from my SM-G935T using Tapatalk
Rinzler_ft86 is offline   Reply With Quote
Old 07-11-2017, 12:41 AM   #17
Im_SPEED
Drives: FRS hot lava
I seen on fb the other day someone is making a kit but the only way you can get it is with a new cd009 and it was 4999$ I think. It peaked my interest but I would want just the kit not the new trans especially when they are everywhere for 500-1000$
Im_SPEED is offline   Reply With Quote
Old 07-14-2017, 01:00 PM   #18
SullyStyle
Drives: Hyperblue BRZ 2016
Do you have a link to the page? I'm looking for specific cd009 kit, and couldn't find it anywhere. Thanks
SullyStyle is offline   Reply With Quote
Old 07-14-2017, 02:07 PM   #19
twag4
Drives: frs
HRI tuning. Like them on FB, and you will see the page. Pre order saves $$$. It might be over already though.
twag4 is offline   Reply With Quote
The Following 2 Users Say Thank You to twag4 For This Useful Post:
Savoelh (07-01-2019), SullyStyle (07-17-2017)
Old 07-14-2017, 07:22 PM   #20
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
or just get a gearset and keep the stock trans so you dont have to get adapters or anything......that's what I did and its been fantastic ever since.
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 07-14-2017, 11:13 PM   #21
twag4
Drives: frs
I'm still curious as to how robust the stock box is in the area of thrust loading. I'm not curious about the cd009, it's proven. And I can get it all, bolt in ready, for less than a gear set. It is a complete package, shifter, carbon fiber driveshaft, brand new transmission, bellhousing, and uses stock style or any FRS/BRZ clutch. Much better value in my mind.
Old 07-17-2017, 04:37 PM   #22
SullyStyle
Dont got fb so i messaged on insta. Hopefully they check that once in a while
나의 LG-H900 의 Tapatalk에서 보냄
Old 07-17-2017, 07:14 PM   #23
twag4
Drives: frs
You can also call HRI tuning!
Old 07-17-2017, 08:36 PM   #24
Drakiv
Project Shadow
Drakiv's Avatar
Don't have to worry too much about that when your straight cut
614whp/421tq on E85
Instagram: Drakiv
Old 07-22-2017, 12:58 AM   #25
Rinzler_ft86
so I got a 2jz with cd009 tranny swap on a steal so now I need to find a drive train and mounts for the brz. I also have 350z diff but I don't think will work with current axels correct?
Old 07-01-2019, 08:04 PM   #26
Savoelh
Savoelh's Avatar
Drives: Scion FRS
This is where you can buy it:
https://www.mazworx.com/mazworx-favq...t-frs/brz.aspx
Savoelh is offline   Reply With Quote
Old 07-02-2019, 10:39 AM   #27
wparsons
wparsons's Avatar
Originally Posted by Savoelh View Post
That's for the FA20, not for a 2JZ swapped car.
If you want to know more about 2J swapped cars, I'd suggest messaging pure automotive to see what they've done.
flickr
Transmission swap ChrisD Engine, Exhaust, Transmission 6 04-04-2016 09:27 PM
Is there anyway I can swap out my automatic transmission to a manual Kushbrz13 Engine, Exhaust, Transmission 23 01-02-2016 06:10 PM
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 02:23 PM
transmission swap? VJZNAV Southern California 1 03-26-2014 11:57 PM
Mt transmission fluid swap bdanisi Engine, Exhaust, Transmission 8 02-08-2013 02:09 PM
