09-14-2015, 10:01 AM | #57 | |
Drives: None
Do you track or do any hard driving with the spacers? Sent from my iPad using Tapatalk |
09-14-2015, 11:39 AM | #58 |
Drives: Subaru BRZ
Not tracked but will do. Not aware of any issues related to track use. Interestingly when I was in the process of ordering the spacers I was informed that the European spec is different from the American spec as we drive our cars harder....
09-16-2015, 07:46 PM | #59 |
Drives: FRS 10 Series
I did not get a chance to take mine back to the track after the springs and spacers were installed before I sold the car.
I can say the handling got a little stiffer from the sportline drop but it was not too bad for daily use. The Pro sports didn't have enough drop for me personally, although I would guess those are a more track worthy spring. Overall I was still happy with my purchase. |
09-30-2015, 05:55 PM | #61 |
09-30-2015, 05:58 PM | #62 |
Drives: None
10-12-2015, 10:49 PM | #63 |
got a question.. i currently have extended wheel studs since im using 10mm spacers but i'll be changing back to stock specs (wheels and tires) and i'll be putting those hubcentric spacers
my question is, we only have 20mm hubcentric spacers available locally, can i combine my extended wheel studs and the 10mm spacers then add the 20mm hubcentric spacers? is this possible and safe? otherwise, i'll have to order those 30mm hubcentric spacers if ever this is not possible or safe
2013 Toyota 86
Sterling Silver Metallic IG: @pcuerpo.images |
10-13-2015, 02:21 AM | #64 |
Drives: FRS
'14 Scion FRS
Tein Flex TE37 |
The Following User Says Thank You to PeterFRS For This Useful Post: | Mr.Impreza (01-30-2016) |
01-12-2016, 05:57 AM | #65 |
Drives: Toyota GT86 euro version
My gt86.
With eibach pro kit springs, 20mm eibach front and 30mm eibach rear. |
The Following 2 Users Say Thank You to Paulo86 For This Useful Post: | Astroboy (01-13-2016), Mr.Impreza (02-12-2016) |
01-13-2016, 07:46 PM | #66 |
Drives: None
01-14-2016, 04:20 AM | #67 |
01-30-2016, 11:26 AM | #68 | |
Mr.Fujitsubo
Drives: 2018 STI
Wow looks perfect...I will be doing spacers also for the stock rims, just will need to figure out width
2015 Toyota 86 ~ The Sold Car ~ Build Journal OFT Stage 1 Tune Review |
01-30-2016, 11:39 AM | #69 |
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Any difference in the feel / handling / ride?
I like driving!
02-01-2016, 02:08 PM | #70 |
Drives: 2014 Subaru BRZ
I actually noticed the handling was a little better. The rear end didn't come out so much when I was gunning it around corners, when it normally always would on the stock tires if it was slightly wet outside. It felt nice!
The Following User Says Thank You to PERRIN_Chris For This Useful Post: | Mr.Impreza (02-03-2016) |
Similar Threads | ||||
Best springs+spacers for stock wheels? | retrosmiths | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 09-22-2015 08:52 AM |
Spacers on all 4 corners / stock wheels (20mm/25mm) | zoltiz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 09-14-2015 11:43 AM |
Spacers and stock wheel studs | solidONE | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 08-31-2013 08:55 AM |
Stock Wheels Need Spacers? | theom | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 08-17-2013 11:49 AM |
Spacers with Stock Wheels | Starscream15 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 06-05-2012 01:31 PM |
