Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
07-03-2019, 07:17 PM | #15 | |
07-03-2019, 07:20 PM | #16 |
Drives: 2014 GT86
I'd rather go with function then form. If people say that geometry gets worsened lowering past inch and if people say that cv joints fail sooner when owerlowering, i'd better be safe then sorry. I'd also prefer to not buy extra parts to fix that. Are that slightly more lowering THAT important to you?
(of course in my case i prefer not to lower any below stock (but i also don't have coilovers that were designed for some lowering with recommended lowered height). Twins are not that high and don't have that much shock travel to begin with. I already scrape bumper here and there at stock height, why make it even worse. Especially if it will make handling worse and or increase failure chance). |
07-03-2019, 07:27 PM | #17 | |
Drives: '13 Scion FR-S & '17 Toyota 86
I installed Flex A's on my FRS last week and didn't make any adjustments to the height. Their website states that the out of the box drop for the FRS is 1.2 inches in the front and rear. I run a 255/40/17 tire and have 0 rubbing issues at full lock. -Sam |
The Following 2 Users Say Thank You to eastendraceshop For This Useful Post: | smg1138 (07-03-2019), strat61caster (07-13-2019) |
07-03-2019, 07:45 PM | #18 |
Drives: 2014 GT86
eastendraceshop: but what do you call as "not observed issues"? Do you track car a lot to tell impact on handling from geometry changes? Have you already went many 10K miles and CV joints still last ok? Former might matter less for those into looks only, as i've often see for sake looks people doing silly things, simply different priorities, and later .. not that immediate failure, simply increased load/wear reducing life out of parts. But i also wouldn't write it off as completely non-issue.
07-03-2019, 07:47 PM | #19 |
Drives: 2013 Raven FR-S
You guys are making me want to raise my coilovers now. I've been at -1.5" for a while but the rough ride and scraping has gotten me thinking about going back up some.
The Following 2 Users Say Thank You to smg1138 For This Useful Post: | strat61caster (07-13-2019), timurrrr (07-05-2019) |
07-03-2019, 07:50 PM | #20 | |
Drives: Crapcan
I do notice some bump steer but it does not make the car undrivable or anything. And I am talking about taking curb at speed with inside tires off the ground. (RIP TH West Turn 3) I also have about 80K miles now on my car and a bunch of track days. I have yet to have a CV fail. I am not saying it is ideal and everyone should do it, but the concerns about it seem a little overblown from my experience. |
The Following User Says Thank You to NoHaveMSG For This Useful Post: | timurrrr (07-05-2019) |
07-03-2019, 07:58 PM | #21 | |
I can update you if I ever have any issues with anything, but so far the car drives great and nothing has broken. The car was lowered 2 inches for the last 2.5 years on Meister Zeta CRD coilovers. -Sam Last edited by eastendraceshop; 07-03-2019 at 08:00 PM. Reason: left my name out |
07-03-2019, 09:59 PM | #22 |
Damn that's crazy...
Drives: 2015 BRZ
If people who only daily drive their cars only need to lower about an inch, would it be better to just get lowering springs? Or would it be better to go with affordable coilovers (like Megan Racing EZ Street, Tein Flex Zs) to eliminate the wheel gap?
07-04-2019, 01:59 AM | #23 |
Drives: 2014 GT86
Will BRZ: Depends. Stock shocks imho are not ideal also from daily driving comfort standpoint, though i heard that improved since MY2015 twins (and of course on 2017 restyle).
Usually lowering springs are also stiffer to compensate reduced travel. If one adds also shocks to springs, eg. bilstein b6 or koni, price is not that far from coilovers. I guess my choice for reasonably lowered but only dailydriven twin would be something like CSG Flex A, RCE SS1, (and who knows, maybe 949R Xidas with softer springs set, when it will be released). Don't know much about MR EZ Street, but heard that Flex Z is rather good at that entry level pricepoint. I wouldn't look at cheap chinese/taiwanese shocks at that budget, as imho quality will be compromised. |
The Following User Says Thank You to churchx For This Useful Post: | Will BRZ (07-12-2019) |
07-12-2019, 12:19 PM | #24 |
Drives: 2019 BRZ / E36 325is
Just drive your damn cars and stop worrying about ride height lol. Adjust them accordingly to your driving style. The manufacturer just sets a standard height, it doesn't always necessarily means its the best optimal setup for YOU. Just go out there and drive and feel it out...
23 GR86 Halo MT Prem - Racecomp Engineering SS-2 - Sayber Designs - Voltex - RE71RS - Project Mu |
07-12-2019, 12:53 PM | #25 | |
I guess since I replied to you in the other thread you already probably know my position, but to answer this specific question that under a certain budget a good quality lowering spring on the stock Showa dampers (or better yet on PP Sachs dampers) will be better ride quality for a given ride height than cheap coilovers. This will affect both daily drivability and performance. Damper quality is absolutely critical to suspension performance, both in daily driving and on a racetrack, and cheap coilovers have bad dampers. Meanwhile the factory dampers are actually pretty decent. If you want an improvement over factory dampers you should get Bilsteins (preferred) or Konis (better than stock, but okayish) w/ lowering springs. You can get the Bilsteins as a kit valved specifically for Eibach lowering springs with the Pro-Kit springs included: Bilstein B12 Pro-Kit which is $1100 off Tire Rack and better than any coilover you could buy for $1100 or less. |
Similar Threads | ||||
Help installing dash cam (front and rear) | wild03 | Electronics | Audio | NAV | Infotainment | 10 | 09-08-2018 11:08 PM |
Lower front more than the rear on coilovers? | stlgrym3 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 06-01-2018 02:21 AM |
FS: Rear upper and lower arms, BC Racing Coilovers | Drull | Brakes, Suspension, Chassis | 38 | 02-23-2018 04:15 PM |
Rear Suspension Sitting Lower Than Front. | Zeuseidon | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 38 | 12-06-2016 06:20 PM |
BC coilovers, Hawk Pads, SPC rear lower control arms, P&L brake lines | twincamRob | Brakes, Suspension, Chassis | 10 | 12-28-2013 10:03 AM |
