03-25-2014, 02:27 PM | #4089 | |
Road Warrior
Drives: Toyota 86 Satin Pearl White
The Following User Says Thank You to Ryan86 For This Useful Post: | Calum (03-25-2014) |
03-25-2014, 02:44 PM | #4090 |
PhoneFlash by EcuTeK
FYI for everyone,
Being this is a fairly big update I do not mind getting logs to review. I have gone through quite a few from already a few customers, so if we need to dial things in a little more for better fuel (that most of you lucky dogs have), we can do so. Cheers, William Knose |
03-25-2014, 02:51 PM | #4091 | |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
03-25-2014, 02:52 PM | #4092 | |
Road Warrior
Witches brew which is 50% Toluene, 25% Methanol, 25% Xylene. This is used in conjunction with 95 (in a 25% Brew to 75% 95 mix) to produce a 102 octane fuel. |
03-25-2014, 02:59 PM | #4093 |
Grip>Slip
is it safe to run a tune that is not calibrated for wideband o2 input via rear o2 sensor on a car that is wired as such? I want to give 8.5.1 a try but not badly enough to rewire that sensor, and I definitely don't want to bug bill more than I already have.
03-25-2014, 04:30 PM | #4094 |
That Guy
Drives: 2013 asphalt FRS MT
The Following User Says Thank You to Calum For This Useful Post: | Dustin (03-25-2014) |
03-25-2014, 04:55 PM | #4095 |
NASA SpecE30 Racer
Nope. Die In Fire or @Visconti .
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
03-26-2014, 09:27 PM | #4096 | |
Grip>Slip
Feels VERY strong. Gonna have to head to the dyno soon. As soon as i get a copy of Delicious' 8.5.1 tune that will work with my wideband via rear o2 input i'll provide my thoughts of how they compare, but really don't want to unwire/rewire my wideband every time i swap maps, so for now that's on hold. |
The Following User Says Thank You to xjohnx For This Useful Post: | mikalem (03-26-2014) |
03-27-2014, 12:30 AM | #4097 |
Road Warrior
[QUOTE=xjohnx;1628741]just filled up on E85 w/ 70mm, IC, Nameless header and mike's latest tune (which hasn't been tweaked yet), but DAMN.
Feels VERY strong. Gonna have to head to the dyno soon. As soon as i get a copy of Delicious' 8.5.1 tune that will work with my wideband via rear o2 input i'll provide my thoughts of how they compare, but really don't want to unwire/rewire my wideband every time i swap maps, so for now that's on hold.[/ What's the purpose of running 2 tunes from 2 top tuners? Just curious? |
03-27-2014, 06:57 AM | #4098 |
Drives: Red '12 GT 86
@Rayan86 just want to know since your in the same country as i am how hard was it to get to the 200 wkw spec ? keep in mind i am in pretoria and couple hundred feet above you? my dads 86 went in this week for the kit intall just wandering what to expect....
Any one here with an auto with the kit installed? Last edited by Styx; 03-27-2014 at 07:09 AM. |
03-27-2014, 07:45 AM | #4099 |
Grip>Slip
I did the same when I was NA. I wanted to see what what the other option was like, so I went for it. The cost for the tune alone isn't really all that much since you already have the license and cable at that point.
The Following User Says Thank You to xjohnx For This Useful Post: | Ryan86 (03-27-2014) |
03-27-2014, 08:13 AM | #4100 |
Drives: 2013 WRB BRZ Limited
Anyone have a normal cruise log they would be willing to share? I'd like to know what would be considered "normal" adjustments when driving/cruising along on the highway. Are some -1 knock correction/ignition adjustments (fine) considered "normal"? Advance Multiplier only seems to fall some of the time - usually it spends it's time in the .85 - 1 range. Just curious on getting input from the others running the kit. Any logs on e85 or 93 would be great.
Thanks! |
03-27-2014, 08:18 AM | #4101 |
Drives: 2013 SWP BRZ
03-27-2014, 08:25 AM | #4102 | |
I have absolutely nothing against mike's ability - this is just my first time with a FI car and I'm probably being WAY too picky - just looking to the group for someone with some more knowledge than me to let me know what they would consider "normal". (Side note - we've been fighting some issues with the car - I started out with the OMNI 4Bar - switched that out last night for the stock MAP sensor, so far with a similar tune just scaled for the sensor I'm noticing less what I would call negative events - I'm just paranoid is all ) |
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
