Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
06-16-2021, 02:51 PM | #15 | |
Drives: Honda Insight
I suppose next I will call brembo and see if I can get an answer If not I'll move ahead with baking them with the boots in |
06-16-2021, 02:58 PM | #16 | |
Drives: Crapcan
https://www.rockauto.com/en/moreinfo...=1720&jsn=1245 I saw in the G8 forums a guy was able to call brembo USA and was given all the part numbers. Calling may be a good idea.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (06-16-2021) |
06-16-2021, 03:03 PM | #17 | |
義理チョコ
06-18-2021, 02:03 PM | #18 |
Drives: 18 Brz (Sold) / 22 BRZ
I would remove any rubber part from the assembly before doing any paint job to avoid vulcanization of the rubber parts. Also, I would recommend a good wet paint (primer, base and clear) that is less prone for chipping and other related failures instead of powder coating. Being aluminum caliper, it is pretty straightforward for painting.
06-19-2021, 02:50 PM | #19 |
Drives: 16 Silver BRZ, 04 Silver WRX wagon
I agree use paint. I have had good luck with POR15 caliper paint. I put on an insane amount of coats with a brush and the paint levels well and looks like it was coated. Not as good as coated but close. Then I ceramic coated them before I put them on the car.
Similar Threads | ||||
powder coating? | all4spl | Mid-Atlantic | 2 | 04-06-2017 11:36 AM |
Powder Coating in NC? | ChilOut | Southeast | 6 | 06-30-2014 06:04 PM |
Powder coating on LI | klittl06 | NY / NJ / CT / PA | 7 | 06-09-2014 02:11 PM |
Powder Coating | MATTrocity | Hawaii | 3 | 05-07-2014 03:40 PM |
So Cal powder coating | Plxdjake89 | Southern California | 4 | 09-02-2012 04:30 PM |
