Forced Induction Turbo, Supercharger, Methanol, Nitrous |
08-17-2020, 01:24 AM | #43 | |
Drives: Q5 + BRZ + M796
Do that race!
08-17-2020, 01:00 PM | #44 | |
Drives: 2017 Toyota 86
08-17-2020, 01:16 PM | #45 | |
Drives: 2017 toyota 86
I bet from a dig you pull on him pretty hard (assuming you have traction) and then he slowly reels you in and passes you around 100mph and pulls away. From a 40 roll you値l get the jump but he値l pass you sooner around 60-70mph and then keep pulling away on you. Got any POV speedo 0-60+ pulls? |
08-17-2020, 02:27 PM | #46 | |
Sent from my GM1915 using Tapatalk |
08-17-2020, 02:28 PM | #47 | |
The Following 2 Users Say Thank You to BlOody_BoOger For This Useful Post: | 86TOYO2k17 (08-17-2020), airrick (08-18-2020) |
08-18-2020, 03:20 PM | #48 |
Drives: TRD R.S. 1.0 FRS
08-18-2020, 04:58 PM | #49 | |
Drives: 2013 FR-S Argento
Sent from my SM-G965U using Tapatalk |
08-19-2020, 12:35 AM | #50 | |
Software Hobbiest
Drives: 2015 FRS
That is my first idea but wouldn't it scoop up water with that placement |
08-19-2020, 01:08 AM | #51 | |
08-19-2020, 07:26 AM | #52 |
Drives: FR-S,GTI
08-19-2020, 03:26 PM | #53 |
My IATs run about 21 degrees over ambient on the Edelbrock supercharger.
08-23-2020, 02:59 PM | #54 |
So quick update.....I did a few things to try and bring temps down. Now while I really didn't make my charge temps lower I did notice operating temps went down roughly 5 degrees. So before during normal driving after driving around town temps would sit right around 130 (stoplight) at idle then while cruising go down to about 115 and under boost go back up to 120. This time around in similar 95-100 degree weather I noticed idle temps were around 125 would drop to around 110 and under boost go up to 115.
In 75 degree weather. Idle temps sat around 105 drop to 95 under cruising and back up to 109 under boost. Now in comparison with other conventional boost applications. 120 charge temps seems to be normal and for me on hot summer days seems to be my max given without an intercooler. So it's safe to safe I'm good to run without one. So a few of the things I did was wrap the pipes with gold heat wrap. Added a filter heat shield to the in bay filter. Added a heatsink on the maf sensor. And installed these fin pipes in place of where an intercooler would sit. those pipes act almost like a large heatsink. Sent from my GM1915 using Tapatalk |
10-07-2020, 07:47 PM | #55 | |
Drives: 2013 Toyota 86
Sent from my SM-N975F using Tapatalk |
10-07-2020, 07:57 PM | #56 | |
Sent from my IN2017 using Tapatalk |
Similar Threads | ||||
OFT FORCED INDUCTION | lilred | Software Tuning | 6 | 03-13-2019 06:10 AM |
going forced induction | ft86me | Forced Induction | 14 | 02-05-2014 08:23 AM |
Forced induction for ATs? | Lokutus | Forced Induction | 10 | 02-26-2013 03:42 PM |
6AT (+) Forced Induction | RYU | Forced Induction | 18 | 09-09-2012 11:14 PM |
Forced Induction | Primo86 | Engine, Exhaust, Transmission | 11 | 05-29-2012 07:50 PM |
