02-11-2017, 05:57 PM | #15723 |
Drives: Asphalt 2013 FRS
Diff fluid, Oil and Oil filter changed. tires rotated.
Now time for video games |
The Following User Says Thank You to auryn79 For This Useful Post: | ToyotaFan84 (02-14-2017) |
02-11-2017, 07:05 PM | #15724 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
haha I've gotta have some style
The Following User Says Thank You to weederr33 For This Useful Post: | humfrz (02-11-2017) |
02-11-2017, 08:28 PM | #15725 |
02-11-2017, 08:40 PM | #15726 |
Drives: 2013 Supercharged BRZ, E85, Ohlins
SRP Racing Pedals for non-slip footing and better heel & toe...
Installation notes for dead panel: [a] removing dead pedal is a PITA. Pop out the large circles first,they are actually push-in connectors (like bumper connectors). I used a pick. [b] cut along underside of all four edges with razor blade or exacto blade. Take you time, go slowly, separate the glue from the oem pedal. You will lose a little carpet but that's fine, it will be hidden. [c] You will end up with the OEM hole on the carpet, plus whatever extra you cut away in the removal process. This hole should be smaller than your new dead pedal. Under this is a small wedge of Styrofoam that will absolutely get in your way and will complicate drilling the new holes. I recommend tossing it, your choice. [d] Depending on how much the appearance matters to you, you can cover the carpet hole with some wide black tape (I had Gorilla tape handy). [e] mark new hole locations and drill in two increments, start with a small bit such as 1/16" per SRP instructions. Then go up to your larger size. I used a 9/64" final size after measuring the screws provided by SRP. [f] Clutch and brake pedal covers come with inexplicably long bolts and jam nuts. You may need to shorten one or more of the bolts to clear the arm of the pedal. 5/8" length on the bolts was plenty for clutch and brake covers. [g] optional: I sourced some 3/4" black screws in a compatible diameter from my local hardware store ( yes they stock black machine screws, who knew) because the screws furnished by SRP felt really short ( 1/2") and i wanted more screws and more grabbing threads, especially on the gas pedal. The 3/4" screws gave more confidence than the shorties provided by SRP. Last edited by canyons; 02-14-2017 at 08:58 PM. Reason: details |
The Following 3 Users Say Thank You to canyons For This Useful Post: |
02-11-2017, 08:43 PM | #15727 | |
Drives: 2013 Scion FR-S 10 series
Sent from my SM-G920F using Tapatalk |
The Following 2 Users Say Thank You to Eman For This Useful Post: | Ashikabi (02-11-2017), OrangeGuitar (02-11-2017) |
02-11-2017, 09:30 PM | #15728 |
Drives: 2015 Scion FRS
Swapped out my Berk dual exit muffler delete for a Greddy Revolution RS system last night. Love it.
Sent from my SAMSUNG-SM-G928A using Tapatalk |
The Following 3 Users Say Thank You to mpross For This Useful Post: |
02-11-2017, 10:12 PM | #15729 |
I am thinking about starting.
When I take the granddaughters to school and back, there is this soccer mom it a PT Cruiser that keeps beating me to the best spots in the pickup/drop off zone.......so, I may start with some power and suspension mods. humfrz |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | finch1750 (02-12-2017), ToyotaFan84 (02-14-2017) |
02-12-2017, 12:28 AM | #15730 |
The struggle is real
The Following 2 Users Say Thank You to Ashikabi For This Useful Post: | ToyotaFan84 (02-14-2017), wulfstan (03-02-2017) |
02-12-2017, 12:39 AM | #15731 |
02-12-2017, 02:14 AM | #15732 |
02-12-2017, 05:33 AM | #15733 |
Drives: frs
I guess memebers will be excited if you create a build thread
The Following User Says Thank You to Teseo For This Useful Post: | humfrz (02-12-2017) |
02-12-2017, 11:51 AM | #15734 |
Yep, I was thinking that I would stay NA ..... no "blower", cause it would stand too high.
I figure to port & polish the intake manifold and heads; a high lift cam; mill the heads; electronic ignition; headers; cherry bomb mufflers; dual 4 barrel Holley carbs. Also, a 4 speed close ratio transmission; beefed up clutch; 4:11 rear end and traction masters for the rear springs. Now, THAT should allow me to blow that PT Cruiser right out of the parking lot ...... humfrz |
02-12-2017, 12:06 PM | #15735 | |
02-12-2017, 12:16 PM | #15736 | |
Drives: frs
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
