Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
09-29-2023, 03:29 AM | #15 | |
Proud of BOXER
Drives: Subaru Boxer
Add me to the list of who this is happening to now. 2014 with 67k. Same exact symptoms as the OP, where it whines & makes a friction-y metallic whirring/grinding noise regardless of if the clutch is depressed or not (but the sound changes/gets louder when clutch pedal is pressed in) while the car is cold, and goes away when warmed up.
I've already ordered this TOB kit with fork and pivot, just waiting for it to come in so I can get it installed: https://shop.battlegarage-rs.com/pro...earing-upgrade
The Following User Says Thank You to Clipdat For This Useful Post: | blsfrs (09-30-2023) |
09-29-2023, 03:48 AM | #16 |
Yes, I did read it, that’s why I’m asking for an update and not just opinions. Subarus are known to have clunky clutches.
09-29-2023, 03:26 PM | #17 |
義理チョコ
All of us in this thread have replaced our TOBs. It's going to be either that, or the accessory belt squeaking over the alternator pulley. You can unplug the control connector from your alternator while it's squeaking. If it suddenly stops when the load is removed, it's your belt.
You can also reach back and pull the top of the clutch fork forward to lift the bearing from the pressure plate. If the squeaking stops there, then it's your TOB.
The Following User Says Thank You to Ultramaroon For This Useful Post: | blsfrs (09-30-2023) |
09-30-2023, 02:09 PM | #18 | |
ProCrastinationConsultant
my clutch doesn't make any noises, other than some squeaking during activation(think that's the pivot, not the bearing), but just doesn't feel as rosy as it did when i first bought the car...
The Following User Says Thank You to soundman98 For This Useful Post: | Ultramaroon (09-30-2023) |
Tags |
clutch whine |
Similar Threads | ||||
Clutch Engage Whine? | PDM 2 | Issues | Warranty | Recalls / TSB | 12 | 10-25-2016 03:11 AM |
The dreaded clutch whine | RichardsFRS | Issues | Warranty | Recalls / TSB | 10 | 06-08-2016 06:44 AM |
Clutch Rattle at cold start | shellslinger | Issues | Warranty | Recalls / TSB | 16 | 10-11-2015 01:45 PM |
RPM varies, cold start, clutch in and out | 00NissanNinja | Issues | Warranty | Recalls / TSB | 8 | 03-04-2014 11:40 PM |
White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
