04-06-2021, 08:03 PM | #76749 |
chicken tonight
Who knows? It might not suck.
The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
04-06-2021, 08:08 PM | #76750 | |
chicken tonight
The Following User Says Thank You to Ultramaroon For This Useful Post: | Tcoat (04-06-2021) |
04-06-2021, 09:14 PM | #76751 | |
Drives: 2016 Ford Focus RS
Both of your understandings of these circuits are far beyond mine, so if this is self-evident then I'm embarrassed, but would the steering column replacement that they suggested negate all of the 30+ failure scenarios that you saw it could potential be, and be far enough into 'starting from scratch ' that the replacement of the entire column will likely resolve my issue completely? Or is it still somewhat likely to error after the steering column replacement? Sent from my SM-G998U using Tapatalk
2016 Ford Focus RS (Nitrous Blue) Hatchback
2013 Subaru BRZ Coupe 2003 Ford E250 Cargo Van 1996 Mazda B4000 Pick-Up Truck 1987 Bertone X1/9 Convertible |
04-06-2021, 11:19 PM | #76752 |
helmholtz resonator
Drives: '15 ultramarine
Reminds me of my last night in Bangkok. |
The Following User Says Thank You to Sapphireho For This Useful Post: | Ultramaroon (04-07-2021) |
04-06-2021, 11:46 PM | #76753 | |
Guilt free parts vulture!
Drives: 2013 FR-S - Asphalt 6MT
In Bangkok, things are not always as they appear...
The Following User Says Thank You to nextcar For This Useful Post: | Ultramaroon (04-07-2021) |
04-07-2021, 12:57 AM | #76754 | |
chicken tonight
04-07-2021, 01:13 AM | #76755 | |||
ProCrastinationConsultant
https://smile.amazon.com/3M-3614-15/...+moldin&sr=8-3 In hardware stores, it's 3m extreme https://smile.amazon.com/3M-Scotch-E...+extre&sr=8-10 Same stuff, main differences is the extreme comes in 1" width and up to 33' long, where the molding tape tends to be differing amounts under 1" wide, and never more than 5'-15' long per package. Quote:
Get it. You'll like it.
The Following 3 Users Say Thank You to soundman98 For This Useful Post: |
04-07-2021, 07:06 AM | #76756 | |
From the looks of the manual there are at least 6 different sensors involved with the steering. Each of those sensors have between 2 and 6 possible failure modes. Add all the wiring, the control module and actual moving parts into the mix and an intermittent failure is almost impossible to identify through guess work. To go back to what has been said I do not think you can diagnose this without capturing the failure codes with Techstream. There is just so much going on. For example "DESCRIPTION The power steering ECU assembly receives vehicle speed signals from the skid control ECU via CAN communication. The power steering ECU assembly provides appropriate assisting force in accordance with the vehicle speed, based on the signals." Your problem could be anyplace between a wheel speed sensor and the steering column. Even a loose or slightly corroded wire could be the issue. The only way to narrow it down would be to get the codes. There was a big recall for the steering in Australia and all that was happening was that the position of some wires could cause small amounts of debris to create interference in the signal and the steering would cut out. No this does not apply to your car but that is how little it takes for the system to screw up. https://www.toyota.com.au/news/toyot...ted%20vehicles. What I am confident in saying is that in all probability the motor is not the issue. Now that you have everybody's attention we should probably take this discussion back to your failure tech thread so that if an answer is found it is not lost to posterity in the wastelands that are random thoughts.
04-07-2021, 10:23 AM | #76757 |
Junior Senior with Cheese
Drives: 15 BRZ
The Following 5 Users Say Thank You to ScoobsMcGee For This Useful Post: | bcj (04-07-2021), NoHaveMSG (04-07-2021), Spuds (04-07-2021), Ultramaroon (04-07-2021), wolffbite (04-07-2021) |
04-07-2021, 11:10 AM | #76758 |
Site Moderator
Drives: ichi 86 Project
Bracing myself that member classified section will start to go crazy due to official announcement of GR86 & BRZ...
The Following 5 Users Say Thank You to ichitaka05 For This Useful Post: | p1l0t (04-07-2021), ScoobsMcGee (04-07-2021), spike021 (04-07-2021), Spuds (04-07-2021), wolffbite (04-07-2021) |
04-07-2021, 12:54 PM | #76759 |
The Following User Says Thank You to p1l0t For This Useful Post: | ichitaka05 (04-07-2021) |
04-07-2021, 12:57 PM | #76760 |
Why would it go crazy now? Be moths away if at all.
04-07-2021, 01:16 PM | #76761 |
Site Moderator
Because, a lot of owner wanna change it back to stock to get the funds quickly before it comes out. When that happens, there will be a lot more ppl selling it.
At least that's how I see it. But I could be wrong |
The Following User Says Thank You to ichitaka05 For This Useful Post: | Tcoat (04-07-2021) |
04-07-2021, 01:31 PM | #76762 |
Oh and the flood of parts and cars will result in all the whining of "Why is my $5,000 turbo set up only worth $1,000 now. Damn lowballers" and "All of a sudden my car really dropped in value what a rip off"
The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
Similar Threads | ||||
Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random Rubber Part | OoLong | BRZ First-Gen (2012+) -- General Topics | 8 | 01-28-2014 10:31 AM |
Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
