Software Tuning Discuss all software tuning topics. |
12-11-2013, 12:19 PM | #85 | |
The Following User Says Thank You to jeebus For This Useful Post: | solidONE (12-11-2013) |
12-11-2013, 05:01 PM | #86 |
Drives: 2013 Scion FRS
I see there is now a v1.40b (beta) map uploaded on openflashtablet.com - any information on what is different with these new beta maps?
12-11-2013, 05:08 PM | #87 | |
Slack Bum
Drives: FT86
release notes : 12/11/13 v1.40 Changes: -Added Stage 1 and Stage 2 map support for ZA1JA01N (Asian market) ROM -In USDM E85 ROMs (Stage 2 E85 ZA1JA01C and Stage 2 E85 ZA1JA01D), we now differentiate between cars with Equal Length (EL) and Unequal Length (UEL) headers. The Stage 2 EL E85 tune is renamed (formerly Stage 2 E85) but unchanged from the v1.34 release. However, the Stage 2 UEL E85 tune is new and completely different. It js highly developed and has only been tested in cars with the OpenFlash UEL header. It is considered Beta status and should be used only be those who are sufficiently comfortable with data-logging and analysis. -Stage 2 EL E85 maps have been approved for use in completely stock vehicles running E85. -All non-USDM and USDM-ZA1JB00C (2014 BRZ/FR-S) tuned ROMs and considered Beta status. -Adjusted checksum values so all ROMs can be opened in RomRaider without displaying checksum error. -Re-enabled diagnostics routines for o2 sensor faults in Stage 2 and Stage 2 E85 maps. If you trigger these faults, it is due to an exhaust leak at your header flanges from not replacing gaskets when you installed your header. |
02-26-2014, 08:07 AM | #88 |
Drives: blk;2dr;rwd;fun
Just got my oft last night, installed the stage 1map...but my question is, do you guys keep the oft plugged in and mounted? Or am i suppose plug it in and unplug it everytime, would rather have it permanently attached to the car if possible and only remove to upload the logs
Life is like taking a dump, sometimes it's easy and other times its hard. But it always stinks
02-26-2014, 09:17 AM | #89 | |
Drives: TIE interceptor; BRZ13
Connect the OpenFlash Tablet to your car's OBD2 diagnostic port. Please be sure that the Tablet is disconnected from you laptop. Select "Tuning". Then select "My Car". Then select "Write". At this time you will see a list of available ECU files. These are the files you uploaded in the previous step. Select the file you wish to load into your ECU, click on the right arrow and then follow the prompts. The writing process takes approximately 4 minutes and involves cycling the ignition ON and OFF a few times. Please do not interrupt this process. Once you are notified that the writing process is complete, you can disconnect the Tablet and start you car. Immediately after writing to the ECU, a low power mode will be triggered momentarily. For this reason, it is recommended to let the engine idle for 30 seconds before driving. After each reflash (or ECU reset), you may notice that your throttle pedal feels unresponsive for the first centimeter of travel. This is normal as the ECU needs to relearn the minimum and maximum throttle position voltages. This will sort itself out after one or two drive cycles" If car is running, keep it on to use datalogging. If you are leaving the car "off" for A short periot of time you can leave the OFT plugged. But for long periods (overnight) you unplugg it so it won't drain your battery. @shiv@vishnu
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
The Following User Says Thank You to TIE Pilot For This Useful Post: | MisterSheep (04-20-2016) |
02-26-2014, 10:09 AM | #90 | |
02-26-2014, 10:24 AM | #91 | |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
Edit: I should note that there is no way to turn the OFT off. |
02-26-2014, 10:50 AM | #92 |
I did say: If you are leaving the car "off" for A short periot of time you can leave the OFT plugged. But for long periods (overnight) you unplugg it so it won't drain your battery.
02-26-2014, 10:55 AM | #93 |
Thanks for the clarification guys
05-24-2014, 07:21 PM | #94 |
Drives: 2014 scion frs
Bumping an old thread. Who is still running the stage 2 uel e85 tune on their stock exhaust system?
Sent from my SAMSUNG-SM-N900A using Tapatalk
2014 Scion FR-S # 73 STX - Philly Region, Norther New Jersey Region Grid Chief, Brandywine Motorsport Club DOY 2017 Chief Course Designer
05-25-2014, 02:58 AM | #95 | |
Edit: I am using the Stage 2 EL e85 tune with the stock header. |
05-25-2014, 04:10 AM | #96 |
Drives: Toyota 86 13'
^ I'm also running the Stage 2 EL E85 tune on stock headers back
A tad rich, no knock. Life's great |
The Following User Says Thank You to tnle For This Useful Post: | jaorocks1 (08-31-2015) |
05-25-2014, 01:20 PM | #97 |
Codename: Stitch
same deal here. running Stage 2 EL E85 tune on mostly stock exhaust. I do have a catless front pipe but everything else is stock.
Last weekend I put my car on a dyno and the results are, +20 HP over stock. My dyno results and further discussion are up on 86DRIVE.com : http://86drive.com/2014/05/18/pmoks-dyno-results/
The Following 2 Users Say Thank You to PMok For This Useful Post: | Lonewolf (05-25-2014), Shiv@Openflash (05-25-2014) |
05-25-2014, 01:30 PM | #98 | |
Drives: 2013 FRS
Similar Threads | ||||
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 | FRSTEVE | Software Tuning | 105 | 08-04-2017 04:48 AM |
FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit | FullBlown | Forced Induction | 414 | 07-14-2014 09:52 PM |
Ecutek stage 2 tune on stock brz | 01s0uljah | Software Tuning | 15 | 10-15-2013 02:52 PM |
Anyone choose zeta stage 1 over stage 2? | BlackyRose | Engine, Exhaust, Transmission | 2 | 07-06-2013 01:32 PM |
>> EcuTek << STAGE 1 / STAGE 2 / E85 - Tunes Available | FT-86 SpeedFactory | Engine, Exhaust, Bolt-Ons | 133 | 05-21-2013 01:39 AM |
