Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
07-12-2014, 09:57 PM | #1 |
Drives: 2010 WRX (sold) 2013 brz
Damaged my apr splitter
Hit a speed bump and damaged my splitter. Anybody have an idea on how I should go about fixing this?
07-12-2014, 09:59 PM | #2 |
The splitter itself is ok except for the clear coat. I need a new rod and the rubber seal that goes on the front. Could a body shop fix the clearcoat?
07-12-2014, 10:12 PM | #3 |
Super 86
Drives: Red 86 GTS
If you're sure that only the clearcoat is damaged then yes a body shop could probably fix it. Contact APR to get replacement parts for the other stuff.
Next time slow down and avoid the bumps, the girl might be legal age by the time you get there.
230rwhp/184ftlb on 98RON/93AKI
Build thread Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can |
The Following 14 Users Say Thank You to Khorne For This Useful Post: | Andrew025 (07-12-2014), Atropine (07-23-2014), BMA (07-13-2014), cdrazic93 (07-13-2014), CrazyWookiee (07-14-2014), FR-SBPK93 (07-13-2014), husker741 (07-13-2014), kavanagh (07-13-2014), Marchy (07-13-2014), Octoman (07-13-2014), raven1231 (07-13-2014), sklimo (07-13-2014), Surok (07-16-2014), unsurety (07-13-2014) |
07-12-2014, 10:49 PM | #4 |
Take the splitter off for street use. Its a functional aero item for track only. You will likely need to replace it, unless body shop can cut it and reclear but thats going to cost your probably $200
07-13-2014, 12:16 PM | #5 |
that stinks put some clear nail polish in the cracks to prevent water from soaking the fiber. man the stabilizer threads hit the bumper.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
The Following User Says Thank You to charged86 For This Useful Post: | SkAsphalt (07-15-2014) |
07-13-2014, 01:05 PM | #6 |
Drives: Black BRZ
ill buy it for 3.50
07-13-2014, 01:32 PM | #7 | |
How do I know for sure the splitter isn't damaged? If you take the rubber off the splitter is ok. And I don't see anything cracked underneath. So my best guess it's only the clear coat. It appears that the impact was mostly absorbed by the rod. |
07-13-2014, 02:50 PM | #8 |
Car is totaled. Get rid of it
07-13-2014, 03:49 PM | #9 |
Drives: 2013 Whiteout Scion FR-S 6MT
07-13-2014, 04:39 PM | #10 |
I'll go to $13.00 cuz relevant
07-13-2014, 05:03 PM | #11 |
Fat on Corn Syrup
I thought it was $15.00 now?
Sent from a secret volcano base using trained sharks |
The Following User Says Thank You to kavanagh For This Useful Post: | sklimo (07-14-2014) |
07-13-2014, 06:49 PM | #12 |
The speedfactory one is ok but it doesn't look good in my opinion. You have to consider my car is lowered.
07-13-2014, 07:02 PM | #13 | |
My guess is the carbon fiber is damaged at the connection point, and will probably need to be patched up or (lazy, maybe cheaper solution) have a metal plate or something installed for the rod to connect to. |
07-13-2014, 07:10 PM | #14 |
Drives: 2019 Mazda Miata RF
Switch to cables, instead of stay rods, to allow the splitter to move up when it makes contact, but it still holds it up from aero loads.
As for repair...you could try just having it clear coated, which may help cosmetically. Structurally, I'd say you'd have to cut out a pocket, install a new hard point, and relaminate...won't be as pretty then though. A good composite shop could do it for you. |
Similar Threads | ||||
Just Added APR front splitter and side splitter | Pekingduck | Cosmetic Modification (Interior/Exterior/Lighting) | 42 | 08-31-2016 10:22 AM |
Already damaged paint... | ktulu7 | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 05-09-2013 07:13 AM |
clear bra damaged | triwoody | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 4 | 03-17-2013 03:10 AM |
Wind Damaged BRZ's | thermobox | BRZ First-Gen (2012+) -- General Topics | 6 | 08-25-2012 10:25 AM |
Wind damaged BRZ's | thermobox | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 08-24-2012 04:23 PM |
