Old 10-01-2012, 01:28 PM   #15
Tirewarmer
Any update on the projected ship date?
Tirewarmer is offline
Old 10-01-2012, 08:27 PM   #16
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Mid October Eibach says for release.
FT-86 SpeedFactory is offline
Old 07-24-2017, 12:14 AM   #17
n0thing
Drives: Subaru BRZ
pardon for bumping an old thread. im looking for some clarification on the front & rear specs, as i found two different sets of numbers from eibach's own website. i suppose numbers from the newer date supersedes the old ones?
http://eibach.com/america/en/eibach-...anti-roll-kits
FRONT:
OE bar: 18 mm (0.71 in) solid
OE measured bar rate: 24.7 N/mm (141 lbs/in)
OE bar weight: 2.7 kg (6.0 lbs)
Eibach bar: 25mm (1.0 in) tubular, adjustable
Eibach measured bar rate: 2 position adjustable
P1 = 66 N/mm (376 lbs/in) +167 %
P2 = 86 N/mm (488 lbs/in) +248 %
Eibach bar weight: 3.4 kg (7.5 lbs)
Bushings: New urethane bushings with grease grooves.
End Link: OE
Approximate installation time: 1.5 hr
REAR:
OE bar: 14 mm (0.55 in) solid
OE measured bar rate: 19.8 N/mm (113 lbs/in)
OE bar weight: 1.6 kg (3.5 lbs)
Eibach bar: 19 mm (0.75 in) tubular, adjustable
P1 = 38 N/mm (217 lbs/in) +92%
P2 = 50 N/mm (283 lbs/in) +153%
Eibach bar weight: 3.2 kg (7.1 lbs)
End Link: OE
Friday, September 14, 2012
http://eibach.com/america/en/eibach-...-roll-kit-2013
FRONT:
OE bar:
Eibach bar: 25 mm (1.0 in) tubular, adjustable
P1 = 88 N/mm (500 lbs/in) +255%
P2 = 103 N/mm (585 lbs/in) +314%
End Link: OE
REAR:
OE bar:
P1 = 45 N/mm (255 lbs/in) +126%
P2 = 60 N/mm (338 lbs/in) +200%
End Link: OE
Tuesday, July 30, 2013
n0thing is offline
Old 07-24-2017, 12:29 AM   #18
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
What spring rates would you be using with these arb?
I had the early set fitted with 6k/6k springs and the cross talk was quite noticeable at the front. The guy I gave them to had them briefly on with oem springs but they didn't stay on for long for the same reason. Would have been worse with the softer springs.
Captain Snooze is offline
Old 07-24-2017, 02:14 AM   #19
n0thing
Drives: Subaru BRZ
kwv3 4k/5k, so softer than yours and if i have the newer set, it'll be worse? any stiffer-than-oem arb will reduce suspension independence anyways
n0thing is offline
Old 07-24-2017, 04:55 AM   #20
Captain Snooze
Drives: Red Herring
Yep.
Search this Thread:
Advanced Search
Roll stiffness: Springs vs anti-roll bars? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 07-24-2012 05:44 PM
is it necessary to change anti-roll bar? yuli8466 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-25-2012 10:58 AM
Press/Blog Release on FR-S Price (no BeSpoke Audio) Dadhawk Scion FR-S / Toyota 86 GT86 General Forum 44 04-20-2012 01:41 AM
Production Subaru BRZ Revealed! (Press Release + Photos) Zaku BRZ First-Gen (2012+) — General Topics 231 12-13-2011 09:28 AM
Official FT-86 II Concept Press Release, Press Photos, Videos Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 126 05-18-2011 01:27 AM
