Old 02-21-2018, 04:17 PM   #43
shadowsnkx
Drives: 2015 BRZ
I have the C6, C7, and BRZ. The C7 Z51 is one of the most well balanced platforms I have ever used. If you pull the trigger, get the magnetic ride suspension and PDR.
shadowsnkx is offline   Reply With Quote
The Following 6 Users Say Thank You to shadowsnkx For This Useful Post:
Dadhawk (02-21-2018), Hades (02-21-2018), Leonardo (02-21-2018), rennlistuser3 (01-27-2023), Summerwolf (02-21-2018), Tcoat (02-21-2018)
Old 02-21-2018, 04:20 PM   #44
toast
Drives: 14 BSP Edelbrock BRZ
You plan to track it.
Do you need to set very fast times or enjoy the car?
If you need fast times get the Vette?
If you want to enjoy the car and work on getting to be a better driver the 86 is the way to go. Either a JSRC or Edelbrock kit will allow you to not feel like it is gutless in the straights, add an oil cooler for longevity and your only requirements are tires and pads for the track.
I sold an 08 STI when I got the BRZ. Bigger intercooler, turbo, exhaust, tune, blah blah blah. Car was stupidly quick, handled great and the first time I drove a BRZ I forgot about all that, they are just such a great driver's car. Some cars just speak to you when you drive them. Find someone with a C7 and drive it. If it gives you the same feeling as the BRZ I would buy it, if not you already own the car you need.
toast is offline   Reply With Quote
The Following 2 Users Say Thank You to toast For This Useful Post:
Hades (02-21-2018), Tcoat (02-21-2018)
Old 02-21-2018, 04:21 PM   #45
toast
Here is someone you should listen to...
Old 02-21-2018, 04:25 PM   #46
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Originally Posted by mrg666 View Post
Nope. But I read the reviews, I am sure it drives great. I admit it looks good too. I would buy a Corvette if I had the extra money. But if I can have only one, it is 86 for me. Even love the FA20 engine that some others swap with LS. No regrets or second thoughts.
Ahh.... so, invalid.
Old 02-21-2018, 04:29 PM   #47
ls1ac
ls1ac's Avatar
Are you racing wheel to wheel? Probably not.
Are you going for the fastest lap time bragging rights? There is always someone faster.
Are you at the track to learn what you and your car can do? probably.
If you are asking "that" question, then you can learn from any platform. After many hours of perfecting the same line lap after lap getting consistent times close to the best in you group, it is time to move up to more HP. It is faster learning and much safer in our cars, even stock. Remember at the limit means you will be taking agricultural excursions from time to time, better at 100 than 160.
Run a stock BRZ or Miata to learn then get a C7. A couple of trips off track in a C7 would have bought you a BRZ, well you get the idea.
Track days are kind of like golf, every corner is a new challenge and it is played against your self.
The Following 3 Users Say Thank You to ls1ac For This Useful Post:
Hades (02-21-2018), Summerwolf (02-21-2018), Tcoat (02-21-2018)
Old 02-21-2018, 04:29 PM   #48
shadowsnkx
Drives: 2015 BRZ
So how much cash have you put into the 86 after the purchase? Total investment?
Old 02-21-2018, 09:04 PM   #49
Hades
Hades's Avatar
Drives: 2013 Scion FRS
Yup. The 86 is a great learner's tool for sure.
Hades is offline   Reply With Quote
Old 02-21-2018, 10:18 PM   #50
Harey
Drives: 2013 Toyota 86
Originally Posted by fatoni View Post
It's faster in the turns too but it's hard to beat the argument that it's what you want to drive.
Faster in the turns if both have the same speed before the corner? (ie when the 86 is not restricted by straight line power)
I would have thought the lighter weight of the 86 would have a higher corner speed assuming same level of modifications/tyres etc.
Harey is offline   Reply With Quote
Old 02-21-2018, 10:35 PM   #51
Summerwolf
Panda Trueno
Summerwolf's Avatar
So, a full racecar 86 vs a stock corvette? Corvettes are not heavy to begin with and they carry a 50/50 weight distribution. The 86 would take a decent amount of modifications to even fit stock size corvette tires as well. A base.....BASE c7 pulls 1.08g on a skidpad.
The Following 5 Users Say Thank You to Summerwolf For This Useful Post:
Dadhawk (02-22-2018), fatoni (02-21-2018), Hades (02-23-2018), Spuds (02-22-2018), Yardjass (02-22-2018)
Old 02-21-2018, 11:17 PM   #52
Harey
I mean mid corner speed.
Mid corner speed should not change with more power (unless you are coming out from another sharper corner and in the lower powered car you havent had the chance to build up enough speed to max out the corner). That was all I meant.
Same modification level, lets say stock vs stock, same tire compound etc.
Old 02-21-2018, 11:36 PM   #53
fatoni
Yeah the corvette will still be faster imo
Drive upgrades. Don't buy them.
The Following User Says Thank You to fatoni For This Useful Post:
Old 02-22-2018, 07:31 AM   #54
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
I own an FRS and have driven a few C7's. The FRS's smaller size and lower cost of consumables are better than the C7, but the C7 is an otherwise well-sorted beast "out of the box".
I vote C7 in this case.
Twinz is offline   Reply With Quote
The Following 3 Users Say Thank You to Twinz For This Useful Post:
Dadhawk (02-22-2018), Hades (02-23-2018), rennlistuser3 (01-27-2023)
Old 02-22-2018, 07:54 AM   #55
Summerwolf
Panda Trueno
Summerwolf's Avatar
Corvette still would be faster. It has much more tire area in a stock for stock same compound scenario.
That's why I was saying you'd need quite an upgraded 86 to even come close to a stock corvettes capabilities.
The Following User Says Thank You to Summerwolf For This Useful Post:
Old 02-22-2018, 08:45 AM   #56
ZDan
ZDan's Avatar
Drives: '23 BRZ
An 86 on 215s has the same tire width per weight as a C7 on 245/285 tires...
4.56/4.88 FD Supercharged? azynneo Forced Induction 1 11-09-2015 10:03 AM
RGM Supercharged 86 GeeTee86 AFRICA 63 08-16-2015 09:07 AM
my supercharged brz zenny Member's Car Journals 17 04-29-2014 08:46 AM
My Supercharged GTS Aussie Willy Member's Car Journals 23 07-12-2013 06:06 PM
My 07 tC, Supercharged HunterGreene Member's Car Journals 21 12-12-2012 12:52 PM
