02-04-2016, 06:53 PM | #519 |
Drives: 2013 BRZ Limited M/T
Stop now, just take my money
02-05-2016, 12:08 AM | #520 |
Drives: 2015 Firestorm Scion FRS
I want a front splitter buuuut I probably damage the front splitter and endplate by accidently pulling too close to the curb on the first week...😂
My velox front wheel wind deflectors took a beating and snapped off so many times after I dropped my car an inch. I don't even know how the top corner at the outer edge on the drivers side got mangled so awkwardly. Need to take it off and bash the metal flat again. At least it's durable! |
02-08-2016, 01:38 PM | #521 | |
Drives: BRZ, STI, GT350R, Supra, 987.2
Endplates are in, double checking everything and then they'll be available at FT86 SpeedFactory. Informative post coming in the next few days. |
02-08-2016, 06:34 PM | #522 | |
The Following 3 Users Say Thank You to Bramick For This Useful Post: |
02-08-2016, 10:41 PM | #523 |
Drives: 2018 BRZ tS
Is it bad that I want everthing you guys make?...
The Following User Says Thank You to Nab33 For This Useful Post: | VerusEric (02-14-2016) |
02-15-2016, 09:51 AM | #524 |
Data/photos/CFD pictures are located here for the endplates: http://www.ft86club.com/forums/showthread.php?t=101577
02-25-2016, 09:47 PM | #525 |
Drives: '13 Argento MT FR-S
Happy with the front end aero. I added the endplates and front wheel air deflectors Monday, to bring my splitter up to "current spec". Haven't had a lot of time driving but my initial impressions are positive. Can feel the aero balance shift forward, and front end grip is definitely increased. I also moved the plastic from the fender liner to between the CF and fender, was concerned it could pull over the BHCS/washers.
The Following User Says Thank You to Kwaziekeller For This Useful Post: | VerusEric (02-26-2016) |
02-25-2016, 11:00 PM | #526 |
too much is never enough.
Drives: 2015 FR-S RS1.0, 2005 Corolla XRS
Has this setup been test fitted or installed on an RS1.0 yet?
Too much is never enough.......
2016 Colorado Z71 Trailboss, 2005 Corolla XRS, 1987 Cavalier RS Wagon Nanako's Mod Thread |
02-26-2016, 11:39 AM | #527 |
The Following User Says Thank You to VerusEric For This Useful Post: | Crashdummy (02-26-2016) |
02-26-2016, 11:50 AM | #528 |
Drives: Asphalt 2013 FR-S
When I got my splitter we put it underneath my friends TRD lip as he was curious if this would work. We discovered a few things - the splitter doesnt stick nearly that far out in the front so you honestly may not even really notice it, this also causes issues with where the front rods would connect.
Build Thread: http://www.ft86club.com/forums/showthread.php?t=87104 // Save the fenders
The Following User Says Thank You to BDotG For This Useful Post: | VerusEric (02-26-2016) |
02-26-2016, 02:49 PM | #529 | |
How was the side to side width?
02-26-2016, 03:23 PM | #530 |
Wasn't super amazing either. I can't remember how much farther down the trd lip makes the bumper but I would have some concerns about it all being super low + splitter not sitting flush to bottom of the bumper (might be fine if you had longer bolts + spacers when needed). Maybe velox can cut you a splitter that sticks out a little farther
The Following User Says Thank You to BDotG For This Useful Post: | Crashdummy (02-26-2016) |
02-26-2016, 04:56 PM | #531 | |
thanks much!
03-03-2016, 12:17 PM | #532 |
Are there any plans to produce one for the RS1.0 front end?
Similar Threads | ||||
Just Added APR front splitter and side splitter | Pekingduck | Cosmetic Modification (Interior/Exterior/Lighting) | 42 | 08-31-2016 10:22 AM |
What front splitter? | Takumi788 | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 04-30-2014 06:20 PM |
Perrin Oil Cooler - Impressions, Pics, and Data | swift996 | Engine, Exhaust, Transmission | 36 | 04-29-2014 09:03 AM |
BRZ Front Splitter | Jive Turkey | Cosmetic Modification (Interior/Exterior/Lighting) | 43 | 01-26-2014 03:29 PM |
Front Air Splitter | sw20kosh | Tracking / Autocross / HPDE / Drifting | 6 | 02-17-2013 05:41 PM |
