Old 05-10-2015, 08:56 PM   #253
alex345
FRS610
alex345's Avatar
Drives: Scion- Frs
Send a message via MSN to alex345
sounds good thank you!
FRS 10-series- OFT,OFH,PerrinOP, Tanabee Fp.Perrin MAF intake,Cusco strut bar,Grimspeed tool tray, invidia Q300, Full JL Audio sound system, YO speed plaque.
Instagram: FRS610
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous #maverick#
alex345 is offline   Reply With Quote
Old 07-06-2015, 03:23 PM   #254
it4brown
Drives: Asphalt FR-S
Just finished mine over the weekend. 4G 2013 N7, no gaps thanks to some 3M tape around the edges. Only issues I've had are it's not quite charging as fast as I had hoped. I currently have the power routed to it from the Sony MEX-N5100BT's USB port.
it4brown is offline   Reply With Quote
Old 07-06-2015, 09:40 PM   #255
crash.1340
BRZ FNG
crash.1340's Avatar
Drives: 00 Civic LX/CWP or GBS BRZ someday
It won't, you'll need a 2.1A or so 12V-5V regulator or hardwired charger. Most head units can only put out enough amperage for a moderately powered phone, not enough for a tablet.
crash.1340 is offline   Reply With Quote
Old 07-07-2015, 09:00 AM   #256
it4brown
Yeah, looking at the output on the HU it's only 1A. I know some folks were running it to a cigarette lighter in their glove box, but I'm not seeing one in mine.
Old 07-07-2015, 11:50 AM   #257
DAEMANO
Time Traveller
The socket is there, its in the back right corner. You might have to use a flashlight the first time because the socket will be covered. It's not in the "box" per se, but if you open the glovebox, get down low, and look high in the right corner you'll see a black plug, remove the plug and there is the socket.
The Following User Says Thank You to DAEMANO For This Useful Post:
Sojhinn (07-07-2015)
Old 07-07-2015, 09:26 PM   #258
it4brown
Found it, thanks! I'll be switching the power over to that tomorrow.
The Following User Says Thank You to it4brown For This Useful Post:
DAEMANO (07-07-2015)
Old 07-07-2015, 09:27 PM   #259
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
R you using timurs rom?
Installed Mods:
Old 07-08-2015, 07:41 AM   #260
it4brown
Yes, I'm running his latest beta. Thinking about eventually adding a backup cam and external HDD to watch movies on the N7.
Old 07-08-2015, 12:16 PM   #261
Sojhinn
Sojhinn's Avatar
Fast charging not working? I'm using 1.1 amps and it's plenty.
Installed Mods:
Old 07-09-2015, 09:26 AM   #262
it4brown
After switching the power to the port behind the glove box fast charging is working as it should. This also seems to have solved my N7 battery drain while in standby. Looks like the head unit was draining it.
Old 10-30-2015, 06:31 AM   #263
graeme02
Drives: Gt 86
Is anybody having intermittent issues with the tablet either not shutting off or the screen not coming on when the car is started?
I have had the setup running well for 6 months but occasionally I have issues where it seems to freak out.
I have the N7 running off the cigarette socket in the glove box (2.1A charging socket) I also have a usb hub connected to the N7. occasionally the N7 does not recognise the hub on startup either.
Anybody have any ideas what could be causing this issues? I have a 2012 n7 with Timur first rom.
Thanks
graeme02 is offline   Reply With Quote
Old 10-30-2015, 08:20 AM   #264
Sojhinn
Sojhinn's Avatar
Thanks
Not sure what's happening. I ended up switching to the 2013 version which timur is currently supporting
Installed Mods:
Old 10-30-2015, 08:26 AM   #265
labskaus
labskaus's Avatar
Drives: Toyota GT86
Please contact the timur Kernel community on reddit
Not a big deal
labskaus is offline   Reply With Quote
Search this Thread:
Advanced Search
Well that was easy... FRyeS Scion FR-S / Toyota 86 GT86 General Forum 17 10-15-2013 11:04 AM
Nexus 7 in FR-S/BRZ DjDATZ Electronics | Audio | NAV | Infotainment 4 06-09-2013 08:10 PM
Nexus 7 Car Audio DIY thejevans Electronics | Audio | NAV | Infotainment 32 05-10-2013 03:55 PM
How easy/difficult is it to keep WRB "clean"? ayau Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 32 06-17-2012 10:17 PM
