02-25-2013, 11:03 PM | #43 | |
I Love custom Turbo kits
Drives: Limited BRZ
02-25-2013, 11:18 PM | #44 |
Drives: Limited BRZ
@chadstyle, @dwx, @Acree I am planning on getting add a circuit tap (see below image)
I will connect both gauges together and tapping them into the spot below (its not used by the car but has 12V ignition power. (See pic below, the fuse spot between DRL and Tail) Thoughts, comments, suggestions? Last edited by Sportsguy83; 02-26-2013 at 02:47 AM. |
03-01-2013, 05:18 AM | #46 | |
Drives: Limited BRZ
Where in the car can I find the Ill+ or Ill- cables? |
03-01-2013, 05:01 PM | #47 |
The Ill+ you can get off the TAIL or PANEL fuse or various other points. Check out the BRZ wiring manual. I'll- off the dimmer switch, radio, etc but its a PWM signal and probably not much use.
03-01-2013, 09:23 PM | #48 |
Drives: Limited BRZ
The Failsafe guague can be calibrate to use either 12V signal or 0V signal, that's why I think the Ill- "might" work. So, if I want to take the Ill+ from the Tail fuse, the way to do it is via Add a fuse correct? (Again, I apologize for the dumb questions, I'm not very educated with car wiring... at all).
03-25-2013, 03:25 AM | #49 |
Drives: 2013 Scion FRS
Hello guys,
I am also looking for the tach rpm signal wire.... so far with no success. I need it for my Racepak G2X rpm signal. On the wiring diagram it says connector A35 pin 15 with a gray/red wire should do, but on my FRS that pin on that connector is empty.... BRZ and FRS dont share the same wiring ?? |
03-25-2013, 07:10 AM | #50 | ||
Drives: Limited BRZ
I spoke yesterday with @King Tut and he has successfully connected it already. I'll do it this weekend.
03-25-2013, 07:39 AM | #51 | |
03-25-2013, 07:41 AM | #52 |
Drives: Limited BRZ
That pin goes to a box close to the ECU. If you can;t find it, I will hook it up next weekend so I'll try to remember to take a pic.
The Following User Says Thank You to Sportsguy83 For This Useful Post: | Lonely Sushi (03-29-2013) |
03-25-2013, 07:44 AM | #53 |
03-25-2013, 03:13 PM | #54 |
NASA SpecE30 Racer
The connector is one of the three that goes to the thin certification ECU box that mounts lower than the ECU does.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
The Following 2 Users Say Thank You to King Tut For This Useful Post: | Lonely Sushi (03-29-2013), Sportsguy83 (03-25-2013) |
03-27-2013, 01:52 AM | #55 |
Hmm... is it possible BRZ and FRS has different wiring?
I looked under there once more and cant find the thin box you mentioned... below is the picture showing the ECU and where I think the "thin box" should be? its just a plastic mount there at the moment... (sorry for the bad cell phone pic...) |
03-27-2013, 04:11 PM | #56 | |
NASA SpecE30 Racer
- King Tut
Tags |
dash, gauge, gaugle cluster, pod |
Similar Threads | ||||
What is that blinking dash light when the car is off? | JayNutter | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-03-2014 10:59 AM |
WTB: FRS instrument cluster | jabbajaw99 | Interior Parts (Incl. Lighting) | 3 | 02-14-2013 01:31 PM |
surprised at how much MORE i like the frs dash cluster | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 12-07-2012 09:09 PM |
Flashing Security Light in Dash? | ravenMTgirl | Electronics | Audio | NAV | Infotainment | 8 | 11-21-2012 03:25 PM |
Scratches on my Cluster. | Superhatch | BRZ First-Gen (2012+) -- General Topics | 5 | 08-21-2012 07:50 AM |
