#827 | |||
Drives: '17 BRZ PP
2. With greater displacement, probably need to gear a bit taller for mpg For me, shorter (numerically "higher") gearing is more of a drag-strip or "zero-to-XXmph" thing. Once you're rolling, you're still free to rev each gear out up to 7400rpm if you want. I remember serious sportbikes from the 90s, the "R" track-oriented versions would have *taller* final-drive (sprocket) gearing, with closer transmission ratios. The idea being who cares how you're geared below minimum corner speeds... Quote:
The Following User Says Thank You to ZDan For This Useful Post: | Tcoat (11-24-2020) |
#828 |
Drives: 2017 Toyota 86 (860 SE)
True damn story. Made them a bear to launch, if you did want to go drag racing. If I remember right, the K5 GSXR1k was the first bike to have a 100mph first gear. Madness.
#829 | |
After that it was Evos and SRT4s. |
#830 | |
He who smelt it...
Ya the regs are all leaning in one way and sometimes put the other vehicles in a tight spot. They could probably use their fleet carbon credits to offset some of requirements but they like to hang onto those for their heavy hitter bigger volume vehicles.
#831 | |
Drives: 2013 pearl white FR-S
#832 | |
The Following User Says Thank You to Cephas For This Useful Post: | Opie (11-30-2020) |
#833 |
Nissan made some of the best 6 cylinder motors of all time.. the RB motors in the past and the more recent VQ motors.. those motors are solid... maybe they were not as good with 4 cylinder motors haha
The Following User Says Thank You to DarkSideFRS For This Useful Post: | JesseG (11-24-2020) |
#834 | |
Drives: 2016 Scion iM, 2017 BMW X1
#835 |
I mean, sure, but the electrical problems are ubiquitous across their fleet. I'm mildly surprised the Leaf didn't spontaneously burst into flames.
#836 | |
Drives: '17 BRZ PP
The CAFE standards are based on a vehicle’s size, or footprint,8 where every size vehicle has a fuel economy target. Generally, the larger the vehicle footprint, the lower the corresponding vehicle fuel economy target. 8 Essentially, the space between the points at which the tires touch the ground. https://www.cargroup.org/wp-content/...US-Economy.pdf Footprint Standard The new fuel economy regulations include a vehicle footprint standard. The standard assigns different fuel economy targets to vehicles based on individual footprint, which is equivalent to the vehicle width multiplied by the wheelbase.25 Vehicles with a smaller footprint are assigned a more stringent fuel economy standard than vehicles with larger footprints. Researchers have suggested that a footprint-based CAFE standard incentivizes automakers to increase the size of the vehicles they produce.26 |
#837 | |
He who smelt it...
I did have a catastrophic failure but it was my own fault for thinking "I am double the recommended schedule to change the timing belt but it is still fine so I will wait a bit more". Turned the head into a piece of modern art with the valves. Wasn't the car's fault though.
#839 | |
He who smelt it...
The DOHC could take it. My 91 Talon TSi dyno'd out just shy of 400hp and it was trouble free (until I ignored the timing belt). We are also talking about a compression ratio of 8.something:1 so there was loads of room for boost without getting knock.
#840 | |
Drives: ‘16 4Runner, ‘19 Corolla HB
For funsies I did the chart with the new engine and 3.9. It puts almost identical torque down as the 86/BRZ with the 4.3 with the exception of getting to 60 without shifting into 3rd. That would be depressing if they chased a 0-60 magazine number and effectively nullified the engine’s torque increase, but I could definitely see it happen since that will boost fuel economy rating, too. If that happens, I would snatch up a used 86 instead. I’d get the same performance and pay a lot less money. Sent from my iPhone using Tapatalk |
2022 Subaru WRX Spy Shots via Car and Driver | R_E_L | Other Vehicles & General Automotive Discussions | 28 | 10-23-2020 09:02 PM |
2017 BRZ Hig Res - Courtesy Subaru Global Media | Trap63 | BRZ First-Gen (2012+) -- General Topics | 10 | 07-11-2016 10:53 AM |
Subaru global brz web page | Gaen | BRZ First-Gen (2012+) -- General Topics | 4 | 06-15-2012 02:32 AM |
Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show | C-Bone | BRZ First-Gen (2012+) -- General Topics | 39 | 03-24-2011 10:22 AM |
FT-86 makes UK debut at Goodwood Moving Motor Show | Hachiroku | Photos, Videos, Wallpapers, Gallery Forum | 28 | 07-09-2010 03:57 PM |
