Old 09-28-2021, 12:33 AM   #1
brkdncr
Drives: 2017 86
Best option to lift: spacers, coil overs, airbags?
I need some height. Half of the year i drive about 6-12 miles per week down a rural road that ends in my driveway. Sometimes the county gets behind and there’s decent mounds of sand and i hear it rubbing against the underside and I get a little bogged down. Sooner or later I’m going to get stuck.
What will work best for me? 1” spacers are cheap and easy and don’t change anything except ride-height. Springs can add some lift but i don’t know how much they change the driving characteristics. Airbags are pricey, but keeps the stock ride height.
Of these options I’m leaning towards spacers, and probably HDPE from Andersen Design and Fab.
brkdncr is offline   Reply With Quote
Old 09-28-2021, 02:26 PM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
https://www.ft86club.com/forums/showthread.php?t=116377
Old 09-29-2021, 10:00 PM   #3
Turdinator
Señor Member
Turdinator's Avatar
Outside of the sandy road to you house, what sort of driving do you normally do?
1974 TA22 Celica
2013 86 GT
Old 09-29-2021, 10:02 PM   #4
brkdncr
Drives: 2017 86
Highway, city, twisties in the mountains. No track use.
I ordered the subtle full set since they have a rear alignment spacer set.
Old 09-29-2021, 10:23 PM   #5
Turdinator
Señor Member
Turdinator's Avatar
You shouldn't need a spacer set for less than a 1.5" lift but it wont hurt. You could also look at the TRD rally springs for an extra 1/2" of compression travel and a bump in spring rates. The matching shocks are softer than stock so probably not what you want for the mountain runs but the stock shocks will work just fine with them.
1974 TA22 Celica
2013 86 GT
Old 09-29-2021, 10:46 PM   #6
brkdncr
Drives: 2017 86
Thanks, I was looking at the TRD springs too and may get those if 1” isn’t enough.
The rural road i typically don’t go fast, it’s just a matter of not getting stuck. I’m also considering getting 16” wheels and bulkier tires if I can find something reasonably priced.
Old 09-29-2021, 10:56 PM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
the only thing 16" wheels would do would allow you to run lower tire pressures to increase flotation.
but considering that 16" wheels really only allow one to run about a 55% sidewall vs. the stock 45% sidewall (and compared to the tires that offroaders use for the technique that usually have at least 90% sidewall), i'm not so sure the effect will be very worthwhile.
but i don't think airing tires up and down all the time is the most desirable way to solve the issue either.
Old 09-29-2021, 11:52 PM   #8
brkdncr
Drives: 2017 86
More sidewall to deal with rocks.
The Following User Says Thank You to brkdncr For This Useful Post:
soundman98 (09-30-2021)
Old 09-30-2021, 01:14 AM   #9
Turdinator
Señor Member
Turdinator's Avatar
Have you seen this thread?
https://www.ft86club.com/forums/showthread.php?t=105692
You can run 215/60R16 tires without rubbing (I run this size) and I believe 215/65R16 will fit with only a small amount of rub and has a number of all terrain tires available. That is if you want to lean into the lifted/safari/outback vibe.
1974 TA22 Celica
2013 86 GT
The Following 2 Users Say Thank You to Turdinator For This Useful Post:
soundman98 (09-30-2021), Stonehorsw (09-30-2021)
Old 09-30-2021, 01:49 PM   #10
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
Lift spacers are the budget way to go. There are 2 common lift springs available (TRD and Chuhatsu Plus Multiroad), with a 3rd in the works (RCE Rally X [I'm waiting on these for the spring rates]). All 3 are roughly .5" lift. The lift springs dont increase total travel, but trade off droop for the extra height. Above .5" lift you start to need rear subframe correction. If you run a combination of springs and spacers, you need the equivalent total height for your rear subframe spacers (1" spacer + .5" spring = 1.5" rear correction). Combine with better shocks for best result (such as Bilstein B6)
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
The Following User Says Thank You to Spawn_Of_Creation For This Useful Post:
Turdinator (09-30-2021)
Old 09-30-2021, 01:58 PM   #11
Spawn_Of_Creation
Human
Can you do this on stock suspension? Or does it require a slight lift? I'm currently on 215/55/16 on 16x7+30 Method MR502 Rally Spec with stock suspension.
Old 09-30-2021, 11:19 PM   #12
Turdinator
Señor Member
Turdinator's Avatar
I've driven with that wheel tire combo both lifted and lowered without rubbing. I haven't at stock height but I'd be pretty confident they wouldn't rub. The only other relevant data points are that my wheels are a +48 offset and I have extra caster from the pedders strut tops. The tire comes closest to rubbing at full lock on the inside wheel's outer edge to the rear part of the wheel arch. With my mudflaps there it clears by just under 1/4".
1974 TA22 Celica
2013 86 GT
soundman98 (10-01-2021), Spawn_Of_Creation (10-01-2021)
Im buying coil overs within the next 2 days i need help deciding what coil overs Anthony7515 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-30-2014 08:47 AM
Im buying coil overs within the next 2 days i need help deciding what coil overs to Anthony7515 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 06-27-2014 01:00 PM
Stance Coil overs or BC coil overs ? tr1x5tuh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 11-26-2013 04:13 AM
XYZ Coil overs??? Juanito08 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-31-2012 09:12 PM
