Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
08-05-2020, 06:16 AM | #29 | |
Drives: 2022 BRZ sport-tech
In regards to the diff, why go lighter in track situations where temps are higher?
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
08-06-2020, 08:25 AM | #30 | |
Drives: Nevermorange FRS
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post: | Petah78 (08-09-2020) |
08-06-2020, 02:41 PM | #31 |
Purist
Drives: 2013 FRS - Hot Lava
Pentosin MTF2 (75w80, GL-4) in the Gearbox, Motul 300 (75w90) in the diff. NOT LSD oil. There are no clutch discs in there.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
09-07-2020, 01:03 AM | #32 |
Drives: 2017 Subaru BRZ
Just wanted to ask if the motul 300 is still recommened on a boosted manual brz? Or would you guys recommend something else?
Sent from my SM-G960W using Tapatalk |
11-12-2020, 09:15 PM | #33 | |
https://www.walmart.com/ip/PENNZOIL-...g-FP/744954333 It needs 3qts for transmission and 1qt for the diff right? Sent from my GM1915 using Tapatalk
2013 Series 10 FRS #553
11-12-2020, 09:41 PM | #34 |
¯\_(ツ)_/¯
Drives: '15 ultramarine
Op, what do you do?
If just normal DD, any brand will do. |
11-13-2020, 02:06 AM | #35 | |
Its a bit over 2 for the trans but DO NOT use it in the diff! It is NOT for use with hypoid gears like a differential, please use a synthetic gl-5 75w-90 in the diff
SCCA T4 - FRS
11-17-2020, 10:03 PM | #36 | |
11-17-2020, 11:04 PM | #37 |
For trans I use a funnel and tube, fill from above. Diff, I use a pump.
SCCA T4 - FRS
11-22-2020, 02:53 AM | #38 |
Drives: 2017 BRZ - WRB
I switched my tranny fluid out with MT-90 and found that it made some things better, and some things worst. On stock fluid, attempting to downshift from 5th to 4th aggressively at 3k+ rmps would lock me out 4th. Other than that, I found the stock fluid to be quite pleasant.
With Redline MT-90, upshifting to 3rd gear would result in a "clanking" sensation and noise, which did happen before, but much more rarely. Going from 1st to 2nd also is a bit more difficult if you shift sloppily, unless you mentally try and slot it in the gear in the perfect angle, then it is very smooth. However, the downshifting lockout issue has been fixed and overall shifts do feel a bit smoother, yet heavier if that makes sense. I'm curious if others experienced similar results as me and do transmission break down and lose viscosity over time? |
01-14-2021, 09:19 PM | #40 |
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Penzoil Synchromax seems to be the leader.
I've used redline MT oil in my 01 Outback 5-speed I bought with 80k on it. It helped with the shifting for sure. 1-2 had a little hitch in it that it eliminated. I never changed it and sold the car at 180k. Thinking back, I'll just go back to Redline. Not sure what flavor of gear oil it was, had a shop put it in. Oxyg3n's comments concern me though, maybe Penzoil is the way to go. Don't see any issues mentioned. |
02-06-2021, 06:29 PM | #41 | |
Drives: 2014 White BRZ
https://www.amazon.ca/gp/product/B00...A2SNKCOWT2PS9P Is it possible to mix this with MT-90? I still have some MT-90 left and hate to waste it. I recall seeing a few people mixing but can't seem to find the post anymore. |
02-06-2021, 07:13 PM | #42 | |
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post: | randomthoughts (02-08-2021) |
Tags |
differential, fluids, maintenance, oil, transmission fluid |
Similar Threads | ||||
Changed Diff/MT Trans Fluid to Motul 300 and super low MPG | jfg5067 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 01-18-2016 09:24 AM |
Trans and Diff fluid change feedback | Freedom | AFRICA | 0 | 08-07-2015 11:52 AM |
Manual Trans./Diff. Fluid Change.?. | westmansweed | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 07-15-2015 08:02 AM |
Replacing Trans & Diff Fluid, Hot vs Cold | BRZNutt | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 12-22-2013 09:04 PM |
Trans/Diff Fluid. | DanoFA20 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 01-11-2013 03:11 PM |
