BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
06-16-2023, 10:31 AM | #71 |
Drives: 2017 BRZ PP, 2004 WRX
My only experience with adding a bunch of camber at once was with my GD WRX for autocross when I replaced the stock bolts with Whiteline aftermarket bolts. I ended up getting 2.5 degrees up front coming from about 1 degree. I remember that first testing event years later where the car just turned in a lot better. It was a really great feeling - like it just did more what you wanted it to do and easily. I'm sure mid corner it was a lot better too.
.... and now there's me sitting here in street class for autocross with one degree using the OEM allowed camber bolts. I feel like street class rules for the SCCA should allow for one aftermarket camber bolt to be used. I mean, we allow one swaybar, adjustable struts, catbacks, etc... but no real camber adjustment? Other stock cars have camber bolts from the factory and it's a huge advantage. Civic Type R's can get 2.5 degrees up front I believe using stock bolts/parts. I feel allowing this isn't getting away from being a stock or street class. Bolts are like $20 and running 2.5 degees on the street is perfectly fine for tire wear. Can't wait to get to STX eventually and have endless alignment possibilities.
The Following User Says Thank You to cmiovino For This Useful Post: | ruturaj001 (06-17-2023) |
Similar Threads | ||||
SOLD: Raceseng caster + camber - adjustable front camber plates | higrip | Brakes, Suspension, Chassis | 4 | 09-17-2019 01:43 PM |
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 01:10 PM |
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
