GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
08-28-2022, 11:34 AM | #15 |
ProCrastinationConsultant
One ugga dugga
The Following 2 Users Say Thank You to soundman98 For This Useful Post: | Wally86 (08-29-2022), x808drifter (08-28-2022) |
08-29-2022, 05:38 AM | #16 | |
Be Kind
Drives: 2020 86
12ftlb (16nm) allegedly from a quick search around here.
The Following User Says Thank You to Wally86 For This Useful Post: | Mike_ZN6 (08-29-2022) |
08-29-2022, 08:06 AM | #17 | |
^ this right here is correct for those 8mm nuts and bolts. |
The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post: | Mike_ZN6 (08-29-2022), soundman98 (08-29-2022) |
08-30-2022, 02:06 PM | #18 |
Drives: GR86
I always just torque it down until the head twists off, then spend an hour getting the bolt out, find a replacement, and then realize I've lost the sense memory of how force I applied that was too much, try to remember where I put my torque wrench...
Probably don't do it that way, though. |
The Following User Says Thank You to Spektyr For This Useful Post: | soundman98 (08-31-2022) |
08-30-2022, 04:15 PM | #19 | |
The Following User Says Thank You to KillerBMotorsport For This Useful Post: | soundman98 (08-31-2022) |
08-31-2022, 09:10 AM | #20 |
Drives: GR86
Yeah, learned to never ugga dugga nuts - only bolts (and even then, that's a dumb idea). Naturally I learned that the hard way: water pump on a 2.8L Fiero GT. The number of bolts you can sheer off at the block and still get it tight enough not to leak is zero.
09-13-2022, 06:59 PM | #21 |
Be Kind
Drives: 2020 86
It clears the STI strut bar, just tried it tonight.
The Following 2 Users Say Thank You to Wally86 For This Useful Post: | KillerBMotorsport (09-14-2022), Racecomp Engineering (09-13-2022) |
09-13-2022, 10:20 PM | #22 |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | KillerBMotorsport (09-14-2022) |
09-14-2022, 06:50 AM | #23 |
Be Kind
Drives: 2020 86
I have a 2020 so I've got a different issue on why the bar isn't on right now. I'll post a pic.... tomorrow afternoon after some stuff gets here
The Following User Says Thank You to Wally86 For This Useful Post: | Racecomp Engineering (09-14-2022) |
09-14-2022, 09:53 AM | #24 |
Drives: '23 BRZ Limited
I'm confused. You're posting about the fit of part for the previous gen in the section about the 2nd gen? Or do you also have a '22+?
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
09-14-2022, 10:00 AM | #25 | |
Be Kind
Drives: 2020 86
Two different fitment questions and answers. Does it fit under the STI strut bar? Yes. 100%. Do the nuts for the mounts fit on the inner bolts for my 2020? No, due to some slight tapering on the mounts. I've ordered some new smaller flanged nuts to test fit the bars on so I'll be trying that when they get here tomorrow. EDIT: Yes, I'm trying to fit this on my 2020, not a second gen.
The Following User Says Thank You to Wally86 For This Useful Post: | soundman98 (09-15-2022) |
09-14-2022, 10:02 AM | #26 | |
09-14-2022, 10:06 AM | #27 | |
Be Kind
Drives: 2020 86
(I'm definitely lost)
The Following User Says Thank You to Wally86 For This Useful Post: | OkieSnuffBox (09-14-2022) |
09-14-2022, 10:07 AM | #28 |
Although to be fair, with everything else. I suspect the fit for stuff like this is going to be exactly the same between Gen 1/2.
Similar Threads | ||||
Strut Bar Testing | KillerBMotorsport | BRZ Second-Gen (2022+) -- General Topics | 5 | 08-30-2022 04:12 PM |
WTB Cusco Strut Tower Brace and/or Strut Bars | nwgabrz | Want-To-Buy Requests | 0 | 12-09-2019 10:19 PM |
Strut Bar Review: AEM Strut Bar Thoughts and Experiences | wu_dot_com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 03-08-2019 04:33 PM |
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More | SOURCE,LLC | Brakes, Suspension, Chassis | 445 | 05-11-2015 05:41 PM |
