01-25-2023, 10:48 AM | #1499 |
Well...
Ummmm... About those doors... While sanding in prep for primer I managed to snap not one, but two of those little receiver rings off. I barely touched them and BING gone. The Lindberg plastic is apparently far more brittle than I realized. So Everything has come off (pictures eventually) and I am starting all over with folded over thin styrene sheet as the receiver and fine wire as the post. On the plus side this method results in a much more scale and accurate depiction of the hinges. The bad part remains to be confirmed but I suspect they will not stand up to repeated opening and closing very well so it may end up with permanently open doors. That wouldn't be horrible since it can still be seen closed on the drivers side and the interior is really the star of the show for the passenger side anyway. I also need to get some coats of buildable primer on it to make sure I can get the slight curves of the transitions in the body creases correct. By using such thin material I sort of restricted myself to how much shaping I can do. If the primer fails I will try a very thin skim of filler putty for shaping. If that fails then I will build the doors all over again but with styrene of the next thickness up. If that doesn't cut it that will be the final nail in the coffin for closing doors since when open you cant see the outer skin anyway. I will eventually win one way or the other.
The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
01-25-2023, 12:10 PM | #1500 |
義理チョコ
I've been thinking that it wouldn't hurt to have a spare body. Would it potentially be helpful if I got you another?
01-25-2023, 12:29 PM | #1501 | |
Have you developed a model parts buying addiction? I can send a shopping list if you have!
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | soundman98 (01-25-2023), Ultramaroon (01-25-2023) |
01-25-2023, 12:39 PM | #1502 |
1st86 Driver!
Time to get that Grandson of yours to 3d print you some doors and hinges to your specifications!
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | soundman98 (01-25-2023), Spuds (01-25-2023) |
01-25-2023, 12:41 PM | #1503 |
HMMMMMM
The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (01-25-2023) |
01-25-2023, 12:47 PM | #1504 |
義理チョコ
It's not a problem. I can quit anytime.
The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (01-25-2023) |
01-25-2023, 01:12 PM | #1505 |
Hey you got any of them model parts?
The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
01-31-2023, 07:03 AM | #1506 |
I was very happy to see this kit recently as this was my Grandfather's one and only new car purchase in his life. I can still remember him bringing it by the first time and just how proud he was. It was a fully loaded model and he took such care of it that when he passed 12 years later it was still in pristine, showroom condition.
This is a curbside kit from the old promo so date back to when Hum was a young man. The molds are very nice and most of the grand total of 24 parts (including 10 parts for wheels and axles) are extremely crisp. The steering wheel sits at a weird angle and the door panel detail is a little blurred but as this was intended to be a quick weekend slap together and throw some paint and Bare Metal Foil on it weekend project as a break from my big builds I left them alone. The paint is Tamiya Italian Red lacquer and is bang on the sort of off red of the 64s. Experimenting with backgrounds in the light box so please forgive the weird white sections. EDIT: Fixed the pictures with better background and light diffusion. And since it is a promo and they actually left the base plate (not calling it a chassis) intact I decided to run with it. Pretty cool actually.
The Following 11 Users Say Thank You to Tcoat For This Useful Post: | bcj (01-31-2023), Dadhawk (01-31-2023), JD001 (02-01-2023), Kaotic Lazagna (01-31-2023), NoHaveMSG (01-31-2023), pope (01-31-2023), shiumai (01-31-2023), soundman98 (02-01-2023), Spuds (01-31-2023), Ultramaroon (01-31-2023), x808drifter (01-31-2023) |
01-31-2023, 04:25 PM | #1507 |
And here is a very faded old picture of the real thing! So very very rare to find pictures of the cars back then but the ones I have found almost always include heavy snowfalls.
01-31-2023, 07:29 PM | #1508 |
Sure stands out in the car cabinet!
The Following 5 Users Say Thank You to Tcoat For This Useful Post: | bcj (02-01-2023), Dadhawk (01-31-2023), Kaotic Lazagna (02-01-2023), NoHaveMSG (02-02-2023), soundman98 (02-01-2023) |
02-02-2023, 06:51 PM | #1509 |
Well after a brief intermission it is back to work on the Econoline.
Nice pair of late 60s/early 70s, cheap, made in Japan (when made in Japan still meant cheap) resonated side pipes and the whole three scale feet of exhaust pipe that hooks directly to the headers. No mufflers were harmed in the manufacturing of the exhaust system on the real thing nor model.
The Following 7 Users Say Thank You to Tcoat For This Useful Post: | Dadhawk (02-02-2023), JD001 (02-03-2023), Kaotic Lazagna (02-02-2023), NoHaveMSG (02-02-2023), soundman98 (02-02-2023), Spuds (02-03-2023), x808drifter (02-03-2023) |
02-03-2023, 04:41 PM | #1510 |
Reworked door hinges. Work great and hinges are very close to scale size. The will need some tweaking for size and shape once I get all the layers of paint on but that will be relatively easy.
02-04-2023, 09:27 AM | #1511 |
8 track player with 5 band equalizer and appropriate era home cabinet speakers ready to blow doors back off!
02-04-2023, 12:25 PM | #1512 |
In primer
The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (02-05-2023) |
Similar Threads | ||||
TRD ABS Plastic Kit? | Shims | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 07-19-2015 07:31 PM |
Front lip - abs plastic | _frs | Want-To-Buy Requests | 0 | 09-21-2014 11:11 AM |
Trade my black dash plastic for your silver dash plastic thread. | F3dzo | Southeast | 0 | 07-17-2012 10:06 PM |
plastic interior | lancie | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 10-16-2011 01:02 PM |
