Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
#15 | |
Drives: Crapcan
#16 |
Drives: 2015 FR-S
2015 FR-S MT
#17 | |
Wes
Instagram: @gt86ws
#18 |
Seņor Member
I'd wait for Verus to come back to you before stressing too much.
Ok, story time! I bought a 2nd hand CF Driveshaft Shop one and had vibrations from the start. I ended up taking it to be balanced, which was difficult as here in Aus no one I spoke to had balanced a Cf driveshaft before. The first place just shimmed the unis which helped a little but I still had vibrations. The next place I found did a much better job but they weren't sure on how to attach the balance weights. They ended up just taping them on the shaft, leaving it to me to attach them permanently. I was ok with this as they didn't even charge me, in fact they nerded out quite a bit about the CF. I contacted Loctite about gluing steel to CF, bought the product, borrowed an applicator from work and here I am 3 years later with a light ass drive shaft that is as smooth as silk at any speed that I have been brave enough to drive at.
1974 TA22 Celica
2013 86 GT |
The Following 2 Users Say Thank You to Turdinator For This Useful Post: | Ohio Enthusiast (08-27-2021), Thefalls (08-27-2021) |
#19 |
Drives: 2018 BRZ
Is the driveshaft clearcoated in some way? Or is it bare CF? Did you sand/scuff the CF before gluing?
#20 | |
I have one that may be a culprit of a harmonic vibration at around 130. Talked with Verus on it and with my gearing it was balanced at a speed of 165 mph. Have not worried about it, all the tracks I drive on 110 is about the max speed. |
#21 |
Drives: 2017 Toyota 86
#22 |
Drives: Halo
In the 2nd picture the flange looks bent right where you see that burnt blemish mark. I suspect that if the mating surface isn't flush then that would cause severe vibration issues.
#23 | |
I believe that is an optical illusion, due to camera lens angle. The outside of the flange is scalloped, so anything other than 90° appears as less than flat. Surface checked perfectly flat prior to install. |
#24 | |
Drives: 2015 FR-S
You can try to back out your mounts/bushings and inserts to see if the vibrations shift or go away. I suspect that it will but could be PITA to do again. if it does alleviate the problem, have to decide which of the two things you want to keep
#25 |
#26 |
Drives: Bone stock
Did you do the install or shop with experience did?
Sent from my SM-G998U using Tapatalk |
#27 |
Wes
Problem is - which bushing/insert do I target. And yeah the diff bushings, I'm not sure what those do, but the trans insert, shifter bushing and engine mounts I like a lot.
Instagram: @gt86ws
#28 |
SOLD Please Remove. (Dallas, TX) Driveshaft Shop Carbon Fiber 6MT Driveshaft | Brzzee | Transmission and Driveline | 1 | 09-14-2018 09:22 AM |
Driveshaft Shop Carbon Fiber Driveshaft (MT) $650 [SOLD] | acj47 | Transmission and Driveline | 2 | 10-25-2017 05:07 PM |
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft | Evasive Motorsports | Engine, Exhaust, Transmission | 1 | 09-24-2013 02:27 PM |
