Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
Drives: 2015 Scion FRS - Raven
KW Clubsport 3-way Valving
Hey everyone,
I'm looking for some recommendations as to the shock valve setting on my KW Clubsport 3-way's. I have them installed on the car now, corner balanced and aligned. The shop asked me how I wanted the valving set and I said I wasn't sure so they left everything at full soft. Does anyone have an suggestions as to what the valving should be set at and how I should go about tuning it? Thanks |
#2 |
Drives: '13 FRS
Start with users manual suggestions, which I believe for KW is typically dead middle or a few clicks one way or the other off of middle. You can usually download the users manual with some light googling. Going soft for street comfort is an area where KW does well.
Edit: well online manual doesn't have suggested damper settings darn, they may have another booklet in the box about adjusting the dampers but it's not attached to the CS 3-way product listing online That's a slightly uncommon damper, you may get lucky someone might drop in with experience but its a shot in the dark unless someone has an extremely similar car setup to yours (wheel size, tire size, tire compound, non-oe bushes, etc.) You'll be better off googling some shock tuning advice articles/manuals and fiddling with them yourself, they're meant to be adjusted, be gentle and you won't damage them. Last edited by strat61caster; 12-17-2019 at 04:50 PM. |
The Following User Says Thank You to strat61caster For This Useful Post: | TRAKRAVN (12-20-2019) |
#3 |
Wes
What shop is this btw?
Instagram: @gt86ws
#4 | ||
2022 BRZ Build 2013 FR-S Build |
The Following 4 Users Say Thank You to DarkSunrise For This Useful Post: |
#5 |
Drives: 2013 Raven FR-S
Add +5mm to those ride height measurements. The author of that article told me he raised it up by that much sometime after it was originally published. The original comment section got wiped out when they upgraded the website for some reason.
The Following User Says Thank You to smg1138 For This Useful Post: | TRAKRAVN (12-20-2019) |
#6 |
Drives: #337 2017 Toyota 86
Call KW directly, they should be able to help you.
Sean Thomson | Instagram: @the_drivers_perspective / YouTube: The Driver's Perspective
Back To Basics Toyota 86: STX & 86 Cup Street Build |
#7 |
Thanks for the advise. My corner weights are similar overall the car is a little lighter then the MotoIQ one. I’ll have to double check the ride height measurements. I know it’s not lowered too much lower than stock as I asked to not mess up the stock geometry too much.
#8 |
The lowest I go is 13" from hub center to fender. Any lower than that I feel like suspension geometry starts to become compromised. Some people go a lot lower, but I wouldn't do it without taller ball joints and differential riser to compensate.
Custom Valving Coilovers: How to gauge shim stack and shock force graphs | FeRS | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 08-16-2019 05:46 PM |
Penske regressive valving | mokinbird87 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 32 | 09-23-2015 05:05 PM |
BRZ/FRS ABS Module/Pump/Valving | Grambi | Brakes, Suspension, Chassis | 4 | 08-22-2015 02:59 PM |
Eibach R2 valving and spring rate question | owenxguo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 06-10-2014 07:43 AM |
