Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
01-07-2022, 11:33 AM | #29 |
義理チョコ
Most likely it's aluminum
01-07-2022, 05:45 PM | #30 |
Drives: 2013 frs base
The Following User Says Thank You to blsfrs For This Useful Post: | Ultramaroon (01-07-2022) |
01-08-2022, 05:07 AM | #31 |
Drives: 2015 BRZ Limited
Oh duh. That's right. The whole radiator fluid thing is the temperature control. I was so enamored with the setup, I was thinking off the top of my head.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
The Following User Says Thank You to FunnyGopher For This Useful Post: | blsfrs (01-08-2022) |
01-08-2022, 07:45 AM | #32 |
Its not a problem though, you can very easily just run an inline thermostat like this
The Following User Says Thank You to grumpysnapper For This Useful Post: | blsfrs (01-08-2022) |
01-08-2022, 01:26 PM | #33 |
A hybrid system would be interesting. Keep the fluid cooler and have the air cooler on a thermostat. That way you get the best of both.
01-08-2022, 05:59 PM | #34 |
Drives: 2017 toyota 86
I ran the oem forester cooler in tandem with a mocal thermo sandwich plate to oil cooler w/ fans. Worked great for getting temps up quickly and then keeping them down once they got up.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | blsfrs (01-09-2022) |
01-08-2022, 09:19 PM | #35 | |
Drives: '17 CWP Limited w/ PP
This thread has inspired me to run a front mounted oil-to-air exchanger in parallel with my JSRC dual oil cooler radiator if/when I go FI. Last edited by Jo0; 01-08-2022 at 09:30 PM. |
The Following User Says Thank You to Jo0 For This Useful Post: | blsfrs (01-09-2022) |
01-09-2022, 09:34 AM | #36 |
In your planning for FI, research positioning of the ducting, mounting of the charger, and where you oil cooler lines will run. I'd guess the thermostat needs to be reasonably close to the engine to operate correctly.
01-09-2022, 12:55 PM | #37 | |
I want to assume that my current 2017+ Jackson Racing sandwich plate is thermostatic, unless I'm reading their product page wrong. If not I'd just swap it out for the greddy plate like grumpysnapper is using. |
01-09-2022, 02:04 PM | #38 | |
Another question: Will the FA20 oil pump provide enough volume and pressure to support the additional cooler? |
01-09-2022, 10:48 PM | #39 | |
I have the dual radiator. That was also something that crossed my mind, will the stock oil pump still provide enough for both. My oil pressure gauge right now seems to cap out at 50-55psi at 6k-red line daily driving. Currently using 0w-40 Castrol Edge Euro Formula |
01-10-2022, 09:02 AM | #40 | |
01-10-2022, 10:11 AM | #41 | |
Sent from my ONEPLUS A5010 using Tapatalk |
The Following User Says Thank You to Ashikabi For This Useful Post: | blsfrs (01-10-2022) |
01-11-2022, 08:38 AM | #42 | |
But they are two "conventionaly" sized coolers so I'm not sure how large the Jackson water/oil is by comparison, and how that might alter things. |
The Following User Says Thank You to grumpysnapper For This Useful Post: | blsfrs (01-11-2022) |
Similar Threads | ||||
Fitted car cover FS | FRSfan111 | Cleaning and Detailing | 7 | 06-21-2013 06:23 PM |
DBA T3 rotors fitted | AVOturboworld | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 04-16-2013 02:28 PM |
BRZ fitted with LS2 V8 | Tman08 | Engine, Exhaust, Transmission | 9 | 12-13-2012 06:28 PM |
1st FR-S TRD Kit fitted w/jdm lights | SpecPer | Cosmetic Modification (Interior/Exterior/Lighting) | 160 | 09-08-2012 12:32 AM |
Anybody fitted any STI bits yet | ICantAffordAnLFA | BRZ First-Gen (2012+) -- General Topics | 4 | 07-12-2012 07:59 PM |
