Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
08-31-2022, 06:43 PM | #15 | |
Drives: 2013 FR-S Series 10
I only found 2 or 3 chargers that would hit their spec.. besides the ones Odyssey themselves manufacture. Ended up just getting their charger randomly on supersale at amazon anyways.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
08-31-2022, 10:36 PM | #16 |
Drives: car
I recommend installing a ring terminal fused SAE connector for easily connecting your chargers. This is preferable to leaving alligator clips attached to your race car. My charge connectors poke out of the hood cowl.
And I also use a 25 foot SAE extension cable. This allows me to run my cables outdoors without having my chargers exposed. Since the connections are fused, I have less to worry about with short-circuiting. The "Battery Tender" brand waterproof chargers are the best for long-term maintaining. They are waterproof, and mine has lasted 20 years outdoors. They charge at about 10 watts, and maintain your battery at a float charge. The chinese branded battery chargers are pretty great to own too. I have a Foxsur charger that can do both 12v and 24v charging, at 6 amp. Or 60-70 watts on a 12v battery. I plug my car up to this charger 30 min before starting the car every day, and it definitely puts some juice into the battery - I figure this helps somewhat so I do it routinely. Another thing to note is avoid old "heavy duty" battery chargers like the kind grandpa had in his garage he bought from Sears 35 years ago. Example is the one my grandad had, that when I plugged in it boiled my car battery at 15.5 volts. These older chargers have poor voltage regulation. and will boil your battery at 15+ volts and can hurt electronics. It almost fried my truck's electronics before I started looking into it and running a voltmeter on it. Having a good voltmeter is a handy tool for checking battery health. Last edited by radroach; 08-31-2022 at 11:24 PM. |
The Following User Says Thank You to radroach For This Useful Post: | jflogerzi (09-12-2022) |
10-17-2022, 09:39 AM | #17 |
Drives: 2017 BRZ series.yellow
The only problem I'm personally seen with a battery maintainer, was one hooked up to a pair of AGM's for an RV. the maintainer was undersized and couldn't push the batteries hard enough to switch over to the float/maintain cycle. Just cooked them after a couple months.
Shouldn't be an issue with a single small AGM. |
Similar Threads | ||||
SOLD: SEWI Shorai Lithium Battery and PTUNING Billet lightweight battery tray | timepoor | Audio/Visual, Electronics, Infotainment, NAV | 4 | 10-06-2021 10:40 PM |
Battery Brace touched Positive Battery terminal, car won't start!! | 7m28 | Issues | Warranty | Recalls / TSB | 21 | 09-24-2017 12:55 PM |
Help! Battery died, charged battery now getting all sorts of error codes! | jermyzy | Issues | Warranty | Recalls / TSB | 12 | 11-25-2015 12:35 PM |
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package | KCMachine | Brakes, Suspension, Chassis | 111 | 10-08-2014 08:26 AM |
Ridge Racing School; Lapping/school Sept 7th | rice_classic | Northwest | 4 | 09-05-2012 01:27 AM |
