Old 09-09-2019, 09:59 AM   #57
DIE1000DEATHS
TechNINJA
DIE1000DEATHS's Avatar
Drives: Whiteout MT, 87 Mustang, 09 RUCKUS
Originally Posted by Gam3rBlue View Post
Doing this swap, Is it only good for Turbos or should It also be done for SC pushing 350whp? Lemme know, If its worth it.
Thank you,
It would be fine for that application too. It will help if you have traction issues in the lower gears, and simply give you more time in them (and all gears really)
DIE1000DEATHS is offline   Reply With Quote
The Following User Says Thank You to DIE1000DEATHS For This Useful Post:
86TOYO2k17 (09-09-2019)
Old 09-17-2019, 01:15 PM   #58
MotoX16
MotoX16's Avatar
Drives: 2017 Subaru BRZ
I'm turbo'd on a 2017 with the 4.3 diff. Would it make a noticeable difference to swap to the 4.1 diff? Can I just swap internals or do I need a whole diff?
My second gear feels really short now and I'd like to drop my hwy rpms a little.
TIA
MotoX16 is offline   Reply With Quote
Old 09-18-2019, 12:15 AM   #59
Mr_Eyo
Drives: 2017 Toyota 86
TIA
Oh man I'd swap you a 4.1 diff with 37k miles for your 4.3 diff. You can just swap the ring and pinion final drive gears if you take yours off and open it up.
Mr_Eyo is offline   Reply With Quote
Old 09-18-2019, 06:20 PM   #60
norcalpb
norcalpb's Avatar
TIA
Yes that would make it feel great. I’d trade with someone local on the forums. Just make sure the 4.1 is low mile too.
I’d swap the entire housing with someone, but upgrade the bushings on the 4.1 as it seems the 4.3 came with superior front bushings. I’d do sti front and rear diff bushings but that’s just me haha.
Old 09-18-2019, 09:03 PM   #61
86TOYO2k17
Drives: 2017 toyota 86
TIA
It makes every gear 5% longer/less aggressive. Generally recommended for FI. But depends on a lot of factors.
How much power are you making?
What is your reasoning for wanting to swap?
4.1 FD assemblies are cheap. Under 400$ for low mileage. Just buy one and have the option of going back to stock or sell the 4.3 assembly for a tiny profit.
Depending on the above answers some people even go to 3.9 or 3.7 FD as its a direct swap.
For general street hooning id say
Sub 215whp 4.56
215-250whp 4.3
250-325whp 4.1
325-400whp 3.9
400+whp 3.7
But if tracking/autox/drag then its an entirely different scenario.
Old 09-18-2019, 09:55 PM   #62
MotoX16
MotoX16's Avatar
Sub 215whp 4.56
215-250whp 4.3
250-325whp 4.1
325-400whp 3.9
400+whp 3.7
I'm making about 330 on e85. The car is mostly a daily driver but it might see 1-2 track days per year. I'll look around locally and see if I can find a 4.1 diff to buy, it'd be nice to have both in case I ever want to swap back.
Thanks for the help!
Old 09-18-2019, 10:32 PM   #63
Sonic86
Sonic86's Avatar
Drives: 2017 Toyota 86 MT White Drift Spec
Exactly!
I got the spare 4.1 diff assembly from Ebay for $200 shipped! And it takes about 30 minutes to swap it. So I keep it in case I need to go to the track.
Swapping pinion/ring gear set is a pain in the neck...
PS: I'm making 260-280whp and I got 3.58 FD for a daily driving and I'm loving it cause it feels like I got the 7th speed
Sonic86 is offline   Reply With Quote
The Following User Says Thank You to Sonic86 For This Useful Post:
jeepmor (05-12-2022)
Old 03-18-2020, 05:14 PM   #64
rixter145
Sleep Chomper
rixter145's Avatar
Originally Posted by Sonic86 View Post
Exactly!
Which pinion/ring gear did you buy on Nitro gear? I'm possibly looking into a 3.91.
Cheers!
rixter145 is offline   Reply With Quote
Old 06-29-2020, 11:46 PM   #65
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
So I’m strongly considering this swap. I have a boosted (turbo) manual FRS, tuned on E85. I found an M85 LSD locally for a decent price, with 180k miles on it. My car is a DD, not tracked. I’m trying to decide between the 3.7 and 3.9 LSDs. Any big concern going with the M85?
kmbkk is offline   Reply With Quote
Old 06-30-2020, 01:00 AM   #66
86TOYO2k17
180k miles is quite a bit.
What is your expected reasoning for wanting a 3.7 or 3.9?
Is there a speed you normally pull to on hwy pulls? Or would like to be able to pull to? You want the top of your 1-1 gear (5th) to be right at or slightly over whatever speed you want to go to as fast as possible to that speed, but the less aggressive (numerically lower) will be slower at any given speed below the more aggressive (numerically higher) ratio top of 1-1 gear (5th).
assuming stock 24.6 tire diameter.
A 4.1 will be fastest to 130mph
A 3.9 will be fastest to 137mph but slower than 4.1 to 130mph
A 3.7 will be fastest to 144mph but slower than 3.9 to 137mph and 4.1 to 130mph.
This is also assuming starting speed of 0mph and not factoring any traction advantages or disadvantages one has over the other, just purely potential mechanical torque. Also each will have specific speeds in which they are faster. Like a 3.7 in 3rd will be faster than a 4.1 once it’s shifted to 4th but then lose the advantage once the 3.7 also shifts to 4th etc. so it can get pretty technical and complicated if you want to pick the exact best one for your needs.
Personally to simplify it i just go off what i want my 1-1 gear to hit so i can do pulls to that speed as fast as possible. That’s why i chose a 4.3 with my 25” diam tire i can hit 126mph in 1-1 gear for fun 40/60mph - 120/125mph pulls as fast as possible.
You could technically calculate all of this off your 4th gear and then sort of treat 5 as an overdrive in a sense.
Which would be
4.1 - 107mph
3.9 - 113mph
3.7 - 119mph with a taller tire could be really good for 120mph pulls.
Old 07-28-2020, 08:45 AM   #67
mhiscott
Drives: 2013 FRS
I'm looking to swap R&Ps as I will already have my differential apart to install an OS Giken 1.5way. I want 3.90s, and the best option I've come across thus far are these:
https://www.nitro-gear.com/Toyota-8-.../t8-390-ng.htm
Now the above link retains 27 spline setup, so I think this should be a drop in install using the oem yoke flange and a new seal/crush sleeve.
There's also this one which upgrades you to a 29 spline setup, which means you'd need their yoke kit. Unsure on if this would be a bolt in install, or if there'd be spacers/shims required.
https://www.nitro-gear.com/Toyota-8-...-390-29-ng.htm
I would be interesting to have the 3.90/3.91 OEM is300 part numbers to check dealer pricing on new R&Ps as another route to explore.
mhiscott is offline   Reply With Quote
Old 07-28-2020, 08:49 AM   #68
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
If anyone interested, I have an OEM 3.7 diff in the member classifieds section.
https://www.ft86club.com/forums/showthread.php?t=141509
Old 07-29-2020, 07:34 AM   #69
mhiscott
Drives: 2013 FRS
After some more researching, it looks like the following items would be needed to do the swap if you're going with nitro gears:
https://www.justdifferentials.com/To...-390-29-ng.htm
https://www.justdifferentials.com/To...tlc100-ifs.htm
https://www.justdifferentials.com/YO...yfitkit-29.htm
https://www.justdifferentials.com/SKCSTV6-p/skcstv6.htm
Was more than I had expected with all the install parts included, but if you're already cracking the case to install a clutched aftermarket diff, I'm not sure there are any more cost effective solutions. Total is ~ $750 USD
Old 07-29-2020, 02:27 PM   #70
86TOYO2k17
Pretty sure it’s already a 29 spline so don’t need the “fit kit”
You dont need the solid spacer, but it’s recommended uogrsde imo.
And don’t need the seal/bearing kit if your diff is low mileage can reuse. You do need a set of shims but a shop will generally have an assortment available.
M98 rear diff is the oem LSD factory 3.91 FD.
It adds a lot of labor time/expense to swap ring and pinion and crush sleeve and re-shim and set lashing/spacing vs just doing a new LSD. Could even just DIY the LSD swap is giken claims to not mess with spacing/lashing and need re-shimming.
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
jeepmor (05-12-2022), mhiscott (07-30-2020)
IS300 M85/M98 rear diff - does it fit? PantsDants Engine, Exhaust, Transmission 39 03-28-2017 08:28 PM
Lexus is300 diff swap M98 3.91 ogrowup Engine, Exhaust, Transmission 5 02-28-2017 10:45 AM
Lexus IS300 Second Car - Thoughts? somecrazyazn Other Vehicles & General Automotive Discussions 48 05-05-2014 05:47 PM
vs Lexus IS300? SteelReign FR-S / BRZ vs.... 38 03-27-2012 11:48 AM
