08-22-2013, 09:26 AM | #1499 | |
Drives: 2013 Firestorm FR-S
Also, syncing 2 videos is not a valid comparison, put both cars on the road next to each other so they actually race, sick of this virtual dyno/virtual dragstrip bullshit. Sent from...somewhere? |
08-22-2013, 09:52 AM | #1500 |
Drives: 2013 FR-S Argento
Yah, seems to me the mud slinging is going both ways. Nobody can bash the Innovate system as it's a solid choice for those just looking for a substantial increase in power as well as driveability across the curve. 225+/- whp is nothing to sneeze at in a 2700lb car.
I agree it's hard to compare tachs in a video, too many variables, but in this thread there's a direct comparison between a mostly stock AP1 S2000 and an FR-S with this system (both ESC off and on). Off, the S2000 pulls about how you'd expect with an extra 30-40 whp in the VTEC power band. With the system on, the FR-S pulls on the S2000 like the S2000 pulls on the FR-S without the ESC, pretty encouraging in my book. Very rough estimate looking at that and knowing what an S2000 can do, you're talking a car capable of upper to mid 13's with a good launch... and that's on a system that is still very much in development. As this thing gains momentum (as I'm sure it will), the interest will drive this type of setup further and close the gap between it and other low cost FI solutions. I'm definitely psyched this project has surfaced, and will continue to watch it closely. Good job guys |
08-22-2013, 10:06 AM | #1501 |
Atoning Unifex
Drives: '13 BRZ Premium, WR Blue
@RedLeader: I'll have one of the ESC kits ready in a week or two. You may remember me from getting one of the badass heel plates. Sometime when we're in the same city (and the install and tune is done) you'll have to try my car and see what you think.
08-22-2013, 10:08 AM | #1502 |
Drives: FR-S 10 #103 AT
It's a pity there isn't a reliable, affordable way to significantly bump up the max rpm on the electrocharger. It is a nice piece of equipment as is, but if it could deliver at higher rpm...
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
08-22-2013, 11:23 AM | #1503 | |||||||
Thank you! Im very glad to be a part of this development. Dollar to HP ratio is king when talking about the phantom supercharger system. Quote:
If nothing else it should prove to you that acceleration is "virtually" the same. |
The Following User Says Thank You to fenton For This Useful Post: | DAEMANO (08-22-2013) |
08-22-2013, 11:58 AM | #1504 | |
This system effectively doubles the charge to the engine. That's a max of 8 psi with 4psi of NON PARASITIC boost. 4 psi at redline will be well over 250rwhp. This system could be limited with the drag reduction sensors to keep the charge as close to 5psi as possible by pulsing the motors very fast at low rpm and basically running them flat out at higher rpm. 8 psi is probably not be a good idea at 2000rpm! Haha Keep in mind you would need twice the juice to run this however.... but it does show there is a upgrade path in the future! There is also a couple other things we are testing out and more information will be shared after next weeks dyno. All I can tell you now is im excited!! AND YES, it does fit Sent from my HTC One using Tapatalk 4 |
08-22-2013, 12:03 PM | #1505 |
Drives: 2013 Raven 86
Cot damn it I demand an ETA on this!
08-22-2013, 12:06 PM | #1506 | |
Hail Magnet
08-22-2013, 12:22 PM | #1507 |
Driveway labs.
Drives: '13 BRZ Limited, 6sp, SWP
:facepalm:
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list) -'13 Town and Country Limited (Mods: too many kids) |
08-22-2013, 12:44 PM | #1508 |
Limitless potential! (sorry I had to )
08-22-2013, 12:45 PM | #1509 |
Driveway labs.
It's what we were all thinking.
08-22-2013, 12:50 PM | #1510 | |
Drives: 2013 Scion FR-S, Nissan Pathfinder
The Following User Says Thank You to Bu-Tang For This Useful Post: | DAEMANO (04-06-2015) |
08-22-2013, 01:12 PM | #1511 |
Hail Magnet
Ok, my engineering mind has a suggestion. Instead of putting them in series, which would seem to limit the the amount of boost the first snail will provide, why not port them into the intake in parallel? I'm envisioning a butterfly type setup (horizontally opposed), or a mirror setup (with motors on the outside). Only thing to figure out at that point is fit and how the air would be ported in there
08-22-2013, 01:16 PM | #1512 |
@HunterGreene, just as you are saying that you can see how the complexity has just expontentially increased.
This system takes Pressure Ratio x Pressure Ratio, the first does not limit the second as you have suggested. |
The Following 2 Users Say Thank You to fenton For This Useful Post: | DAEMANO (04-06-2015), HunterGreene (08-22-2013) |
Similar Threads | ||||
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
