Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 01-20-2021, 06:13 PM   #18901
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
WHAT DID YOU DO TO YOUR BRZ TODAY?
Alignment and new shoes!
tintumz22 is offline   Reply With Quote
The Following 9 Users Say Thank You to tintumz22 For This Useful Post:
beltax90 (01-25-2021), Busybee (03-17-2021), Clipdat (01-21-2021), D20Z (01-27-2021), juenedgi (01-20-2021), Lonewolf (01-31-2021), ripper (01-31-2021), Wally86 (02-01-2021), weederr33 (01-22-2021)
Old 01-23-2021, 11:25 PM   #18902
spike021
spike021's Avatar
Went out for some fresh air before it rains for the whole week (supposedly) and decided to take some photos of the car. Here are a couple:
Instagram: @spike.brz
spike021 is offline   Reply With Quote
The Following 11 Users Say Thank You to spike021 For This Useful Post:
Clipdat (01-24-2021), DarkPira7e (01-24-2021), Lonewolf (01-31-2021), new2subaru (01-24-2021), NoHaveMSG (01-24-2021), tehShirt (01-26-2021), therealstoly (01-24-2021), tintumz22 (01-24-2021), weederr33 (02-01-2021), Willpower (01-24-2021), wolffbite (01-25-2021)
Old 01-24-2021, 02:29 AM   #18903
albert
albert's Avatar
Smile
I mean at that point why use Carplay at all when you can set Bluetooth up on your phone and have a holder on your dash or vent?
Lol.
I was so close to getting an Alpine unit to get the Apple CarPlay and Android Auto... but one day looking at my phone mounted on the vent, an inch away from the head unit and felt a bit silly. Decided maybe later.
Originally Posted by gen3v8 View Post
And just play music from your phone because apparently the factory sound is crap unless size matters
The BRZ sound system is actually pretty good... ever played it while the engine is off? I think the audio problem is the lack of sound insulation and the interior acoustic design.
albert is offline   Reply With Quote
The Following 2 Users Say Thank You to albert For This Useful Post:
jcw99 (02-12-2021), vintagemxer (02-04-2021)
Old 01-25-2021, 10:55 AM   #18904
Matt93SE
Drives: 2013 FR-S, 2017 BRZ
1. Dropped the rear subframe to install some PBM diff/spacer bushings. hopefully this will help axles live longer.
2. rebuilt axles w/ Redline CV grease, vented boots.
3. replace 4.1 diff with 4.3 diff from a 2017
4. rebuild coilovers w/ new bumpstops, lube bearings, etc.
5. whiteline front bumpsteer kit
6. Front camber bolts to get just a lil more grip out of the front end.
Matt93SE is offline   Reply With Quote
The Following 6 Users Say Thank You to Matt93SE For This Useful Post:
dpfarr (01-25-2021), Lonewolf (01-31-2021), MrSkubi (01-30-2021), new2subaru (01-25-2021), norcalpb (01-26-2021), therealstoly (01-25-2021)
Old 01-26-2021, 01:49 PM   #18905
norcalpb
norcalpb's Avatar
Switching from 4.1 to 4.3 is one of the best things I’ve ever done to this car, would recommend it to anyone.
The Following User Says Thank You to norcalpb For This Useful Post:
Matt93SE (01-26-2021)
Old 01-26-2021, 02:34 PM   #18906
Matt93SE
My S/C car is getting pulled on corner exit by an MX5.. just punch me in the ballz why dontcha?! I gotta do something! LOL
The Following User Says Thank You to Matt93SE For This Useful Post:
Old 01-31-2021, 07:22 PM   #18907
therealstoly
therealstoly's Avatar
Drives: 2020 BRZ Limited
Installed the Maxton Design Racing V2 Splitter.
therealstoly is offline   Reply With Quote
Old 01-31-2021, 11:56 PM   #18908
Gungriffon
Drives: 2018 Subaru BRZ
Sti side skirts:
Gungriffon is offline   Reply With Quote
Old 02-01-2021, 02:08 PM   #18909
RFB
RFB's Avatar
Drives: FRS
Even better if its for an auto twin !
Perfect for max acceleration on our local racetracks without overrevving on the highway.
RFB is offline   Reply With Quote
The Following User Says Thank You to RFB For This Useful Post:
norcalpb (02-01-2021)
Old 02-01-2021, 03:04 PM   #18910
Matt93SE
This weekend's fun:
1-6. Finished all the details in the above list.
7. Installed new Accusump
8. Changed the oil
9. New trans fluid
Tonight's after-work fun is setting up scales to do alignment and corner balance.
Old 02-04-2021, 12:27 AM   #18911
therealstoly
Verus Engineering all the things!
Been a bit of a process experimenting with all the variations of Tiffany Blue out there and these RPF1 inserts were worth the wait. revlimiter.net is a new kind of perfectionist.
The Following 8 Users Say Thank You to therealstoly For This Useful Post:
beltax90 (02-04-2021), Breezio (02-04-2021), Kiske (02-06-2021), marky (02-13-2021), MJones_RB (02-12-2021), MrSkubi (02-04-2021), norcalpb (02-04-2021), wolffbite (02-04-2021)
Old 02-04-2021, 02:34 PM   #18912
albert
albert's Avatar
Does this basically make the engine spool up faster, having a better ratio? Is the difference noticeable vs. the older 4.1?
Old 02-04-2021, 02:59 PM   #18913
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
I hit my front lip at the parking lot last night, so check to see if it broke or not. Thankfully didn’t broke off or have any crack.
norcalpb (02-05-2021)
Old 02-04-2021, 03:16 PM   #18914
Matt93SE
spool up faster? depends on what you mean.. but yes, the car will accelerate faster in each gear. For the same vehicle speed, you'll be at a higher RPM and these engines make more power the higher they rev. so the faster you can spin it, the faster you'll accelerate.
in my case, it comes down to gearing and min corner speeds on track. There are a few corners where I'm down to about 50mph. that puts my right at the top of 2nd gear (two more shifts in the turn), or bogging at 4500rpm in 3rd- below the power band.
so with the 4.3, I'll be roughly 4700rpm at the same spot on track, a little higher in the powerband, and a little more power coming out of the turn so I get back into the power band quicker.
At the end of the straights, I was hitting redline in 4th about 2-300ft before the braking zone. instead of holding it at the rev limiter, I'll now have to shift to 5th well before that same spot and I'm hoping it will reduce lap times and strain on the engine running it near the rev limiter.
The Following 2 Users Say Thank You to Matt93SE For This Useful Post:
albert (02-04-2021), norcalpb (02-09-2021)
Got my VIN today... Enemies BRZ First-Gen (2012+) -- General Topics 63 04-12-2012 10:19 PM
sat in a BRZ today NESW20 BRZ First-Gen (2012+) -- General Topics 8 03-31-2012 08:53 AM
