Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
02-07-2019, 08:01 PM | #43 |
Drives: 2013 Scion FRS
Everything is stock.
Sent from my SM-G955U using Tapatalk |
The Following User Says Thank You to bsco For This Useful Post: | Tcoat (02-07-2019) |
02-07-2019, 08:17 PM | #44 |
OK. I ask because when heading into step two and checking wiring we have seen numerous cases where a ground wire was off.
The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (02-07-2019) |
02-07-2019, 08:18 PM | #45 |
I've checked the ground already. I'm not skilled with cars at all, I'm a computer nerd, but did work for Toyota for a little bit, so I have basic knowledge on things
02-07-2019, 08:21 PM | #46 |
Drives: FRS 2013
Fail on everyone saying it's the battery. OP could have just hooked up jumper cables from a running car with help from a friend/family/neighbour and easily concluded if it's the battery or not.
Is your fuel tank full? Do you have engine oil in? Is your car an automatic or a manual? If automatic, make sure the shifter is in P or N or else it won't start. If manual, make sure clutch pedal is all the way down. It is possible the clutch position sensor is out of alignment or failed. Have any recent repairs or mods been made to the car? |
02-07-2019, 08:26 PM | #47 | |
Is your fuel tank full? Yes Do you have engine oil in? Yes Is your car an automatic or a manual? Manual If manual, make sure clutch pedal is all the way down. It is possible the clutch position sensor is out of alignment or failed. I'll check on this. Have any recent repairs or mods been made to the car? No Sent from my SM-G955U using Tapatalk |
02-07-2019, 08:27 PM | #48 | |
Not a fuel issue it doesn't crank. Not an oil issue or it would have a dramatic end the last time it ran. I would hope he knows to check an auto. Clutch was a good mention that none of thought to mention. Already asked if anything was changed 3 posts up.
02-07-2019, 10:22 PM | #49 | |
02-07-2019, 11:02 PM | #50 | |
If so, what does your new battery read? humfrz |
02-08-2019, 12:18 AM | #51 |
If its srock amd you have not messed with anththing amd battery is ok
Check car security is de activating ie the red flashing lock symbol disapears or key symbol goes green. Try your spae key or prox key if push start hold key to start button. If you manual check clutch safety switch If auto check park switch Much beyond that your going to need specilist tools and idagnostics like techstream or at least and obd code reader |
The Following User Says Thank You to steve99 For This Useful Post: | Tcoat (02-08-2019) |
02-08-2019, 06:21 AM | #52 | |
$30K car, a can of Coke is $2 and breakfast at Dennys will run you $18. It only looks bad to people used to US prices. In the long run it is about the same value as there.
02-08-2019, 06:40 AM | #53 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Oh hey, so I've neglected this for a few days.
At 11.8 the battery was either toast or needed a full charge, not a boost. Either way something needed to be done about that. It could have been "eliminated" as a possibility with a boost, but once the car ran, it would have been the next step (relying on the alternator, you'd need to drive all day to recharge a battery that far discharged) Now, since it doesn't crank, use a jumper cable to hook the crankcase to the battery negative, if it cranks you've got a busted ground wire between the engine and battery. If it doesn't crank, go down to the nearest auto parts store and grab a cheap 12v test light (if you dont' have one). Put the clamp on the engine block and use the pointy bit to poke the bolt with the big wire on the starter. Is there light? Yes = next step, no = issue between battery and starter. Now use the pointy bit to poke the terminal of the small wire while a helping hand sits in the car and cranks it. does the light turn on? Yes = bad starter, no = electrical issue between the key and starter. |
02-08-2019, 04:29 PM | #54 |
My video is only 6 secs but it still won't let me upload it here. So I don't know how to show you what my issue is to further explain, but I'll start troubleshooting some more
02-08-2019, 04:47 PM | #55 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Upload to youtube and post the link
02-08-2019, 04:57 PM | #56 | |
humfrz |
Similar Threads | ||||
Turn as tail timing not matching with the front turn signals | NahumCC | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-03-2016 10:40 PM |
Steering wheel issue---left turn lighter than right turn!!! | xingxingtjf | Issues | Warranty | Recalls / TSB | 12 | 10-14-2015 06:47 PM |
Voice Commands with new turn by turn in IOS6? | jadewbj | Electronics | Audio | NAV | Infotainment | 0 | 09-21-2012 10:11 AM |
