Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
View Poll Results: Do you have the described AT issues? | |||
Yes, but I've ignored them | 41 | 34.17% | |
Yes, TSB fixed it | 14 | 11.67% | |
Yes, dealer fix did not help | 12 | 10.00% | |
No everything is fine | 53 | 44.17% | |
Voters: 120. You may not vote on this poll |
03-11-2016, 11:14 AM | #113 |
Cognite
Drives: 2013 Whiteout FRS
03-11-2016, 11:16 AM | #114 |
Drives: 2005 SLK350, 2015 RS 1.0 FRS
Currently at sf Toyota... Hopefully they'll go forward with the tcm update. Went on a test drive with a tech and couldn't duplicate the issue...tech will be doing another test drive after they replace my cigarette lighter (broken tabs covered under warranty).
Sent from my A0001 using Tapatalk |
03-11-2016, 06:42 PM | #115 | |
Contract? /人◕ ‿‿ ◕人\
If they refuse to update the TCM for whatever reason, go to a different dealership and ONLY say you are dealing with idle fluctuation. Don't tell them about the transmission issues, it will probably confuse the hell out of them. I went in with idle hunt TSB in hand, told them about what I was experiencing sans trans issue, then they looked in computer, said they indeed found TSB in database. 1 hour later, they flashed the TCM and haven't had an issue since! As always, YMMV |
The Following 2 Users Say Thank You to soulreapersteve For This Useful Post: | FRSBRZGT86FAN (03-11-2016), MechEGR (03-15-2016) |
03-11-2016, 07:06 PM | #116 | ||
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | MechEGR (03-15-2016) |
03-11-2016, 07:11 PM | #117 |
The cigarette lighter that I came in originally for came in damaged. FML. So I basically had to come back another time for that - they won't let me install it myself. And yeah they "test drove" the car and apparently they didn't "see" any of the same issues I was experiencing (I call bullshit). All they said was they documented the test drive and will keep the Repair order open until I come back next time for the cigarette lighter.
03-12-2016, 12:40 AM | #118 |
Drives: 2015 Subaru BRZ
For anyone with the BRZ in Canada, ask your dealership to look at bulletin SB.07.01.16 and reflash the TCM. Just as soulreapersteve said, the transmission talk confuses them... Now with the TCM reflashed, there have been absolutely no transmission issues. Feels like a brand new car!
The Following User Says Thank You to Hoggensteen For This Useful Post: | MechEGR (03-15-2016) |
03-12-2016, 02:34 AM | #119 |
Drives: BRZ Limited; GR86
anyone know the usb for a 2013 brz automatic?
03-12-2016, 10:10 PM | #120 |
USB!? You mean TSB, also this doesn't apply to 2013 cars however the tcm logic should honestly be flashable to older cars....
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | shaynek (03-13-2016) |
03-13-2016, 12:04 AM | #121 |
03-18-2016, 04:06 PM | #122 |
Drives: 2015 BRZ Limited
Anyone have access to the subaru TSBs? I see 16-96-15 which seems really similar:
TCM Reprogramming File Availability for Engine Idle RPM Fluctuation on 6AT- Equipped Models |
03-18-2016, 04:07 PM | #123 |
Will be going back tm to my local dealership for the update .
03-28-2016, 11:33 PM | #124 |
Alright, finally had a chance to take it out for a proper drive after the 16-96-15 flash. IT'S FIXED! YAY!
The Following 3 Users Say Thank You to inio For This Useful Post: |
04-06-2016, 11:55 AM | #125 |
Drives: 2015 Scion FR-S
I found this thread last night after stressing the hard shift for over year, and being told by three different Toyota dealers "it's a characteristic of the vehicle"
I took it in this morning for my key recall, and asked them to do the TSB reflash of the TCM, and fingers crossed, it seems good so far. The transmission is shifting like it never shifted before, smooth and fast in manual mode, and almost unnoticeable in auto. I only drove about 6 miles since the reflash, but that included WOT starts up hill, shifting to 2 - 3- 4, straight line pulls up and down through 2, 3, 4, 3, 2 and upshifts out of hard corners. I'm hoping this is it. |
The Following 4 Users Say Thank You to punisherfan For This Useful Post: | aa_chow (04-06-2016), FRSBRZGT86FAN (04-07-2016), KalbiCool88 (04-07-2016), soulreapersteve (04-06-2016) |
04-07-2016, 02:59 PM | #126 | |
It's definitely it, I really wish Toyota would've just extended the TSB to others as well in fact the entire 2015 VIN range would probably do good with this TCM logic, the transmission shifts much better with it.
Similar Threads | ||||
AT Transmission Hard Shifting | MechEGR | Issues | Warranty | Recalls / TSB | 95 | 05-21-2017 11:54 AM |
AT transmission hard shifting issues | calic | Issues | Warranty | Recalls / TSB | 44 | 11-09-2015 06:17 PM |
3 min fix for 2nd gear hard shifting | Black Tire | Engine, Exhaust, Transmission | 22 | 03-23-2014 12:13 PM |
Transmission noise when up shifting after hard rev | 1Cor10:23 | Engine, Exhaust, Transmission | 2 | 09-03-2013 03:22 PM |
Hard shifting into 2nd gear when cold | BMWDavid | BRZ First-Gen (2012+) -- General Topics | 35 | 06-24-2012 02:22 PM |
