Tracking / Autocross / HPDE / Drifting What these cars were built for! |
09-29-2013, 01:02 PM | #43 | |
That's what we use on our car. Ducting is ALWAYS good to have. We use the stock brakes in the rear. I'd suspect a set of pads should easily last you a year with the BBK, if not longer. Most of our regulars that purchased the kit from us are getting 15+ days out of a set of pads. |
The Following User Says Thank You to CSG Mike For This Useful Post: | Scooby South (09-29-2013) |
09-29-2013, 01:50 PM | #44 | |
In Test:Oil Fed SC
Drives: Vortech Prototype Test Car
Paging @JRitt |
09-29-2013, 02:19 PM | #45 | |
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
09-30-2013, 03:02 AM | #46 |
Drives: FRS
09-30-2013, 11:38 AM | #47 |
Let us know when you're ready! I'm pretty sure we stock more pad options for that caliper than anyone else, and certainly have the most experience using it on track, even Essex (if you only count the FR-S/BRZ).
09-30-2013, 01:02 PM | #48 |
Drives: White
Keep an eye on those ARP studs. I've had pretty bad luck with them stripping/siezing in the past. If you even THINK the lugs aren't going on smoothly, i would replace them with a fresh set. I got about 6-8 months out of a set before they siezed a lug.
Alternatively - use just a wee bit of anti-sieze on them. I know it's not recommended due to torque differences.. but it may help.
Because it didn't break does not mean it's track proven.
09-30-2013, 03:12 PM | #49 | |
Back on topic: anti-seize is your friend. |
10-06-2013, 10:08 PM | #50 | |
Drives: 2013 BRZ automatic
Rooducts
The Following User Says Thank You to Gearhead1 For This Useful Post: | DAEMANO (03-01-2014) |
02-28-2014, 10:32 AM | #51 |
Drives: 2013 SWP BRZ
Hey @trackjunkie , did you end up rebuilding your OEM calipers?
I got the rebuild kit and just wondering if you have any advice.
2013 SWP BRZ Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781 |
02-28-2014, 10:53 AM | #52 | |
Driving Coach
02-28-2014, 11:01 AM | #53 |
For OEM calipers on a track car I like to rebuild them once a year; cheap insurance, considering the entire rebuild kit is only $25 and is a fairly straight and easy job. Also changing to SS lines at the same time, so the fact that they'll be apart anyways I mind as well do it now.
02-28-2014, 11:09 AM | #54 | |
Driving Coach
02-28-2014, 02:56 PM | #55 | |
You spoiled the surprise! Yes, I was planning on doing a detailed write-up on it, i'll take pics and post it in the DIY section. EDIT: Here it is http://www.ft86club.com/forums/showthread.php?t=60896
2013 SWP BRZ Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781 Last edited by smbstyle; 03-19-2014 at 07:48 AM. |
02-28-2014, 06:08 PM | #56 | |
Drives: Nevermorange FRS
I don't even do that on my wildly under-braked race car. The only time I've "rebuilt" a caliper is when the refurbed unit I bought came with a bad seal (out of round) or I've had a caliper piston seize (melted the seal to the side of the housing!). Do you want to know a little racer secret? When rebuilding the caliper, rub just a little bit of dielectric grease on the seal before you slide the piston in the housing (instead of using brake fluid) and it will keep it from seizing on you at the track, especially at tracks that are really hard on brakes. Oh yeah, don't forget to re-lube the guide pins. You're welcome.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post: | smbstyle (02-28-2014) |
Similar Threads | ||||
A warning about wheel studs | post_break | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 41 | 05-05-2015 03:07 PM |
non-extended wheel studs | BadCompany235 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 05-14-2013 08:02 AM |
86 brake calipers | Hardrock4445 | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 03-17-2013 09:04 PM |
broken wheel studs | Matt Andrews | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 11-06-2012 12:47 AM |
Small wheel studs | PrinzJ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 10-10-2012 04:47 PM |
