Old 09-29-2022, 12:53 AM   #4243
ric342
FR-S driver
ric342's Avatar
Drives: ULTRAMARINE Scion FR-S
specs before specialty shop
mod on
ric342 is offline   Reply With Quote
Old 09-29-2022, 10:25 AM   #4244
Racecomp Engineering
Originally Posted by ric342 View Post
1. It seems that even though I have all these adjustable parts the camber cant be put to oe specs. Not that im going to leave the camber at 0 degrees or -1, but my worry is that if I cannot adjust to oe that there is something wrong with the install.
2. The car is daily driven with some track and autox, I went with aftermarket tie rods after reading am article that Moto miwa posted talking about how after 5 years regardless of miles a person should swap them out to keep the steering wheel feeling tight. With that said I opted to go with an upgrade instead of keeping the oe.
3. Ya I know, but I wanna do it right.
4. I have the car at Chewerks right now, hopefully they get it back to me in better shape.
thanks for the quick response btw. Any input on the end link length, was looking everywhere for info and found nothing.
1. Forget OE specs, your car is far from OE now.
2. Aftermarket isn't always an upgrade. Those parts aren't necessarily bad but they're adding complexity that you don't need. They won't last as long as OE.
3. Understandable. Corner balancing is nice to have.
For endlinks, you want the studs to just line up with the mounting holes with the car on the ground. So don't set them with the car in the air.
This is not the final alignment right? Front is not good.
- Andrew
Old 09-29-2022, 10:43 AM   #4245
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Do you have a picture of how the camber plates are installed?
dragoontwo is offline   Reply With Quote
Old 09-30-2022, 11:40 AM   #4246
juanjgarcia
Drives: 2016 Subaru BRZ
Hey guys, which set up would you choose for a daily driver and about 5 track days per year:
Bilstein B6 with lowering springs
Tein Flex Z or Flex A
juanjgarcia is offline   Reply With Quote
Old 09-30-2022, 12:20 PM   #4247
Pat
Pat's Avatar
Drives: 2023 BRZ
All good options. Personally I'd go Bilstein.
The Following 2 Users Say Thank You to Pat For This Useful Post:
DAEMANO (09-30-2022), strat61caster (09-30-2022)
Old 09-30-2022, 12:21 PM   #4248
Originally Posted by MyHybridBurnsGasAndTires View Post
Hey RCE when are the 22 GR/BRZ yellow springs coming out? im ready to buy
Still working on it! No ETA...tons of projects right now but things are moving forward.
- Andrew
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
flippy (09-30-2022), MyHybridBurnsGasAndTires (09-30-2022)
Old 09-30-2022, 10:01 PM   #4249
juanjgarcia
Why? If you don't mind me asking
Old 09-30-2022, 10:04 PM   #4250
Pat
Pat's Avatar
Drives: 2023 BRZ
They handle bigger bumps at high speeds better in my experience.
Old 09-30-2022, 10:17 PM   #4251
jflogerzi
jflogerzi's Avatar
CSG spec or off the shelf ones? 5 track days are enough your gonna want front camber alignment and 17x9 track wheels which you want camber coming from plates vs bolts... Just my 2 cents
2013 Series 10 FRS #553
jflogerzi is online now   Reply With Quote
Old 10-01-2022, 06:26 PM   #4252
juanjgarcia
That's good to know. In terms of daily driving, how do thay handle bumpy roads compared to stock shocks and lowering springs?
Old 10-01-2022, 06:28 PM   #4253
juanjgarcia
Off the shelf. I currently have 17x9 +35 wheels and camber bolts, my tyre is VERY close to the shock, but no rubbing. I'm considering camber plates if I go with the bilsteins.
Old 10-01-2022, 11:25 PM   #4254
ric342
FR-S driver
ric342's Avatar
aligned and corner balanced
final specsName:  3333333.jpg
mod on
Old 10-02-2022, 12:49 PM   #4255
That should be fun.
- Andrew
Old 10-03-2022, 09:32 AM   #4256
Pat
Pat's Avatar
Drives: 2023 BRZ
Slightly firmer and more composed.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
