Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
05-21-2021, 02:58 PM | #1 |
Drives: 2014 FR-S
Suspension refresh
Hi all!
I'm hoping to pick your brains and get some advice on suspension. I recently repaired a blown strut after noticing it leaking. I was hunting down a squeak coming from my rear drivers side that would happen after driving over every minor imperfection in the road (sounded like a box spring). Got the new strut installed, keep in mind I'm lowered on RSR superdown springs, and the squeak still persists. The squeak is now happening when I turn the wheel, but not straight-on. I am very, VERY, new to the technical aspects of working on cars. That being said, the car is very much a street-driven daily with the occasional spirited drive on a backroad (85,000 miles). I've been taking it to shops for the bigger ticket items to get it done right the first time. I figured the B8 was a good little upgrade over OEM without throwing money away on a cheap set of coils; hopefully, this will save me the headache of more blown struts and possibly fixing this new squeak. Will pairing the B8s with the RSR springs fix suspension geometry, or should I be looking at anything else to maybe address this (endlinks, LCAs, swaybars, tophats, bushings, etc)? I'm hoping the squeak works itself out or I become deaf to it. I plan on taking the rear strut tower brace off to look further into it.
Professional Car Breaker
05-23-2021, 11:50 PM | #2 |
Drives: 2014 GT86
Sometimes it's not struts themselves that squeak. For example, for me it was at one point not secured properly braided brake line in rear, that squeaked on most deeper potholes.
What kind of squeak your is? Continuous sound or "skipping" sound of possibly binding topmount bearing? Also why not B6 instead of B8? |
05-24-2021, 02:12 AM | #3 | |
Drives: 2014 FR-S
I'm thinking it may be my endlinks that could be worn down. Previous owner was the one to tamper with the suspension so now I'm trying to follow the breadcrumbs of what they've done. As for the B8 vs B6, I was leaning towards the B8 because the strut is shorter to accommodate for lowering springs. To quote Bilstein themselves, "The B8 is designed to be used exclusively with lowering springs or vehicles that are fitted with a lowered suspension from the manufacturer."
05-24-2021, 07:55 AM | #4 | |
Drives: 2014 GT86
AFAIK only change B8 has over B6, IIRC is shortened droop travel. So if rest is same, see no reason for having one of features/functionality reduced.
Don't mind much advertisement slogans. Choose according what they really are (at least for specific car model). Quote:
The Following User Says Thank You to churchx For This Useful Post: | rbfr.s (05-24-2021) |
06-02-2021, 09:22 PM | #5 |
Drives: 2014 FR-S
Ordered the whiteline sway bar kit with endlinks and subframe bushings. Hopefully this will fix my box spring squeak!
06-11-2021, 04:23 PM | #6 |
Drives: 2014 FR-S
I'm not sure if this is an issue or if it's normal. I had the whiteline kit installed along with the positive traction subframe insert kit. The front is set to stiff and when going over bumps, the front passengers side doesn't feel like it's absorbing anything - feels more like a crash. If something is wrong, is it the endlink or should I be looking at the strut?
Similar Threads | ||||
Suspension refresh help | norcalpb | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 12-17-2017 02:21 AM |
1987 E30 BMW 325is, full suspension refresh, GC coilovers, much more | PR138 | Cars for Sale/Trade | 2 | 11-26-2016 08:22 PM |
Does the BRZ get same refresh? | snezze21 | BRZ First-Gen (2012+) -- General Topics | 74 | 03-24-2016 01:51 PM |
My 2 year old FR-s suspension refresh | Grateful Dave | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 08-26-2014 04:27 PM |
