07-20-2020, 10:46 PM | #225 | |
Yup. Also realize that shoulder wear WILL happen at autocross. It’s the nature of the beast and even at -5* you’ll see shoulder wear. Rotate front/rear as you see fit to get even shoulder wear. Don’t get concerned until this happens lol Sent from my iPhone using Tapatalk
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post: | BlueWhelan (07-21-2020) |
07-21-2020, 12:34 PM | #226 |
Drives: Miata
07-22-2020, 08:24 PM | #227 |
Drives: 2017 BRZ w/PP
well i fixed my 1 messed up crash bolt and maxed out my camber plates. if my shitty electronic level is to be believed im between -3.9 and -4.1 my garage isnt level so im probably -4.1 both. went into an empty parking lot and i dont rub either
07-23-2020, 08:11 PM | #228 |
Drives: 2017 BRZ series.yellow
07-24-2020, 08:43 AM | #229 |
Not bad at all. They're still quick to cords.
I was lapping the car at Gingerman, Corded those tires, threw on BFGs and ran the same time. So yeah, maybe 0.5 second slower over 1:44 course? Not the worst thing. When I corded my previous set of BFGs, they were over 2 seconds slower a lap.
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post: | Breezio (07-28-2020) |
07-24-2020, 11:11 PM | #230 |
Hey Guys - I think I am due to for some upgrades/maintenance on the front end of my 2013 BRZ. I think I have a bad bushing/tie rod/etc. I am getting excess wear on the inside edge. After a recent track day, all of my tires look like they should as far as coming off track, minus the inside 3/4-1inch at most is completely smooth. The car drove off track and right on the trailer last event. Looking for ideas for what could be causing what seems to be excessive toe wear on the inside? Drivers side is the primary offender.
I am planning on replacing the FLCA Bushings - Are the SuperPro legal parts? Or are the SuperPro/Buddy Club/or SPL control arms at all legal? Guessing no on the buddy club due to the ball joints. https://www.suspension.com/superpro/spf3878k Alignment Specs: F/R -3.3/-2.2 camber 0 toe / 1/16th inch toe in per side rear ?/? Caster - maxed with Ground Control Top Hats. Suspension: RCE T2 W/500 # springs Hotckis Sway Bars |
07-24-2020, 11:25 PM | #231 |
The second thought on my mind, I found my RCE T2 coilovers came with 500# springs on them vs 400# like they normally do. Think its a good idea to swap to 400?
07-27-2020, 10:09 AM | #232 | ||
- Andrew |
07-27-2020, 05:13 PM | #233 | |
But, seems just to not have the grip(front and rear) I think I should for autox and very loose on tighter stuff, not sure if maybe its too stiff. The car does amazing in slaloms. My other thought is maybe my front coils are starting to wear out/have an issue, but that shouldn't lead to oversteer(I don't think). Rears were rebuilt 2 years ago. |
07-27-2020, 05:50 PM | #234 | |
the harder i drive the more i notice how loose my back is. my back came out from me last this weekend and i will be setting my front sway from soft to stiff to try and get some more understeer |
07-28-2020, 07:21 AM | #235 |
Typically, I've experienced that good in the slaloms (stable) tends to be a little pushier in the tight stuff. Is it loose on throttle on exit? If so, it might be on the pushy side and you are getting back on the throttle with a lot of steering input. I describe that as "pushy loose". You could also be dealing with sway bar bind.
Anyway, going with softer rates and adding front camber should help with grip. |
07-28-2020, 12:06 PM | #236 | |
Sounds like you could benefit from a step down in rates or a swaybar adjustment. BUT...if you've had your rears rebuilt 2 years ago and your fronts never, they could have some decent wear. That's a pretty darn good run. I'd evaluate that and your suspension bushings first. Feel free to PM me to talk more! - Andrew |
07-29-2020, 09:22 PM | #237 |
well after this weekend, after fixing my stuff, i set my perrin to stiff to try and get some understeer. also i need to stop driving like a complete jackass
07-29-2020, 09:40 PM | #238 | |
Corner exit oversteer for sure is a thing, especially in tight courses(we have small venues and 1 medium venue only). I sometimes thing the car pushes, but I've had a couple of the better drivers in the area drive the car at autox and they both said its tail happy(1 is AWD guy, but can get in a S2k and set FTD in 2 runs). Last edited by ka-t_240; 07-29-2020 at 10:31 PM. |
Similar Threads | ||||
SSC setup thread | conehead | Tracking / Autocross / HPDE / Drifting | 26 | 06-06-2023 02:21 PM |
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
STX setup sharing thread (2019) | CoolHandMoss | Tracking / Autocross / HPDE / Drifting | 110 | 02-17-2020 11:27 AM |
STX Set-Up Sharing & Results Thread | race2win | Tracking / Autocross / HPDE / Drifting | 76 | 02-16-2017 11:30 AM |
Official Roll Cage/Bar Thread **Show off your setup!** | slava | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 01-02-2015 10:05 PM |
