Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
10-29-2020, 09:53 PM | #1 |
Drives: 2019 BRZ PP
Is this frame damage?
I got side smacked taking a ride turn. Does this damage look like it possibly may have deformed or bent the frame? The door closes but there is a slight indentation in the door jam but the door closes just fine with a small gap. And will the side be repaireable without any weakness to original body?
Sent from my SM-N960U using Tapatalk |
10-29-2020, 11:12 PM | #2 |
Drives: 2017 Toyota 86
I think you might have gotten away safe and sound. Check out this pic of the unibody, is there any visible damage to the B pillar or surrounding metal?
You can also do a coarse straightness check by comparing the distance between two points diagonal from each other with the same points mirrored (I.e. front left to rear right, front right to rear left). If the measurements are the same the frame is probably straight or barely tweaked. It's an old carpentry trick so it's not perfect, but that's because the machines can get a much more accurate measurement with lasers and computers than your average tape measure. |
10-29-2020, 11:39 PM | #3 |
[insert cool phrase here]
Drives: BRZ Premium
No frame damage. But it's a costly repair. Any rear quarter body damage like that can be fixed. You are looking at $10k.
They way they fix it is pretty simple. New door skin and new rear quarter panel. They just weld that in blend in and paint. Good luck.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
10-29-2020, 11:52 PM | #4 | |
Drives: 2019 BRZ PP
10-30-2020, 12:50 AM | #5 |
ProCrastinationConsultant
that's what he means by 'blend'. they fade the new paint into the old paint on the non-replaced panels to keep the overall appearance the same.
talk with your insurance. they're quite apt at explaining the entire process and it's associated techniques to people of all technical or non-technical backgrounds. the main thing is to make sure that you schedule time to pick up the car, and take the time to properly look it over upon completion under good lighting, and if any of it isn't acceptable to you, to decline the vehicle for [reasons] until it is repaired to pre-collision condition.
10-30-2020, 12:25 PM | #6 |
Drives: 2014 Subaru BRZ SC & 2018 Tacoma
(Repair Manager at a body shop here)
- You'll get a quarter panel sectioned in and painted - then scuff and blend/tint whatever area on quarter/pillar isn't painted to match - Rocker panel will either be repaired or sectioned, depending on damages in the dogleg/rocker area - New door shell (they don't do out skins anymore, plus it looks like your intrusion beam is wrapped, so new door for sure. - Blend front fender to match new paint on door and quarter - TONS of R&I's (remove/install) like the front bumper, front headlight, rear bumper, rear tail light, belt molding, appliques etc... They will try and find LKQ door, which is fine. Quarter panel NEEDS to be OEM, if any shop tries to use LKQ quarter for sectioning, don't go there. I'm guessing....$5,500k give or take all said and done with shop supplies, etc... You will not notice any difference in the vehicle when driving it. There is no structural damage I can see from any of those pics except to the door (see intrusion beam comment).
The Following 7 Users Say Thank You to ArrrBussiere For This Useful Post: | alphasaur (10-30-2020), anticubus (10-30-2020), DAEMANO (10-30-2020), soundman98 (10-30-2020), Spuds (10-30-2020), Tcoat (10-30-2020), Ultramaroon (10-31-2020) |
10-30-2020, 04:27 PM | #7 |
The Dictater
Drives: '13 Red Scion FRS
They might not even need to do any paint blending since it is a 2019. My other car (MY 2018) had to have a tailgate and bumper replaced earlier this year and the paint matched perfectly without blending.
But it should be fine either way I see nothing that indicates frame damage. I would make sure it gets an alignment though. After that, if it drives differently, it's probably in your head. |
10-30-2020, 05:11 PM | #8 | |
friendly
Drives: 17' 86
Seek comfort in discomfort.
10-30-2020, 05:52 PM | #9 | |
Drives: BRZ Premium
Yes on the paint. We who have little experience on automotive paint, they can blend anything. It's all skill.
10-30-2020, 06:47 PM | #10 |
Barred
Drives: My18 wrxsti My19 brzts
A used door replacement is what I prefer. It will be off a late model write off. This makes it exactly the same ie all seam sealer. Makes it almost impossible to pick, even with a trained eye especially if it was the same color
Similar Threads | ||||
Frame damage? Scam? | Nottcute | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 09-16-2019 06:04 PM |
frame damage? | zenithnim | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 14 | 08-24-2017 11:37 PM |
How bad is this frame damage? | loshaknazar | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 06-29-2017 09:16 PM |
Do you think this is frame damage? | wrxdrifter | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 06-15-2016 01:51 PM |
Does this look like frame damage? | frsinpa | Issues | Warranty | Recalls / TSB | 15 | 04-24-2014 11:29 AM |
