Old 05-01-2019, 06:35 AM   #127
ermax
ermax's Avatar
Electric Power Steering (EPS) noisy
Originally Posted by frsfrs View Post
I have 2013 FRS. Not a mechanic so for some even with a suggested introductions it's a little tough. It would be awesome if Toyota also creates TSB as Hyundai did. A dealer near me has suggested steering intermediate shaft replacement. Would that also fix the problem?
No that wouldn’t fix the problem.
Old 06-01-2019, 05:39 PM   #128
Jvabhi
Drives: Toyota 86 2013 copper colour, TRD t
Guys just check out this link there is a person who solves this issue with a step by step procedure.
http://www.ft86club.com/forums/showthread.php?p=3199017
Jvabhi is offline   Reply With Quote
Old 06-21-2019, 11:20 PM   #129
frsfrs
Drives: FRS Manual, Asphalt
It’s fixed now with instructions suggested here. If anyone have the same problem and need a fix, I could refer you to someone in Raleigh, NC area.
frsfrs is offline   Reply With Quote
Old 11-20-2020, 06:24 AM   #130
kkronja
Drives: gt86
A month ago I have crashed my GT 86 and had to replace the complete EPS steering column, because it was broken, please see here:
https://www.ft86club.com/forums/showthread.php?t=143043
I have found an used EPS for a fraction of the price of the new one, but now I have the same problem like most of you here...it is not as pronounced like on some of these videos, and is mostly noticeable when I go really slowly on cobblestone road...I can hear the electric motor/worm gear switching on and off....if I push the car faster I cannot recognize it...
the thing is that before installing it on the car(and after consulting this great forum) I did check the plastic/rubber coupler, and it was like new....
I also have to add that my steering position sensor was also damaged in the crash, I have ordered it and am waiting it to be delivered, but for now I am driving with ABS/ESP lights on....could it be that the absence of the sensor is making it become noisy at low speeds?
In the meantime I have dissasembled my old broken EPS unit and have removed the plastic gear and worm gear, and they look like new too....if my new steering position sensor doesn't fix the problem I guess I should make a combination of parts that I have...I am only not sure how to remove the plastic gear from the broken shaft (please see the pictures) it seems to be a really tight press fit and it doesn't move when i tried to remove it with the help of the vise....I would like to know if anybody has some experience with removing it, before I become more aggressive and put it under hydraulic press...
kkronja is offline   Reply With Quote
Old 02-16-2021, 05:36 PM   #131
kenkho
kenkho's Avatar
Drives: Subaru BRZ
I have the same problem. the Subaru casa will cost me $2,700 estimate cost to fix this problem. I will try this hope i can do it.
kenkho is offline   Reply With Quote
Old 02-17-2021, 01:30 PM   #132
kenkho
kenkho's Avatar
Drives: Subaru BRZ
Originally Posted by CK155 View Post
Wondering if this Toyota part will fit instead of the coupler from Hyundai.
did anyone try this? i will about to buy this part no on japan:
https://item.rakuten.co.jp/suzukimotors/klrm192977/
any advice?
Old 02-18-2021, 05:32 AM   #133
ermax
ermax's Avatar
any advice?
Toyota doesn’t sell the part individually for the 86 so I used the Hyundai part but later on someone discovered that the coupler from the Corolla is identical to the part in the 86 so you can order it that way. My DIY instructions list the Hyundai and Toyota part numbers:
https://www.ft86club.com/forums/showthread.php?t=133606
Old 02-22-2021, 02:20 PM   #134
kenkho
kenkho's Avatar
Drives: Subaru BRZ
thank you, brother! great tutorial appreciates your effort on this will try this soon.
also, can you identify the youtube clip I posted if that sounds the same to your car problem?
Old 02-22-2021, 08:30 PM   #135
ermax
ermax's Avatar
Yeah sounds about right. Much worse than mine was but I’m not sure what time of road surface you are on. It is worst at low speeds on roads with small bumps like a dirt road or a road that has layers of asphalt crumbling.
Old 09-17-2021, 09:41 PM   #136
TheIllistPhysicist
New Guy
Drives: 2013 FRS Boosted, Hot Lava
Originally Posted by darksnyder View Post
While we wait for a fix, I recorded a few videos of my rattling EPS and just curious to know if you guys are experiencing the same rattling or less or worse:
(you can here it from 3 secs onwards)
Just wanted to give a shoutout to everyone on this thread who contributed to documenting, finding, and posting a fix to this EPS rattle issue. Had this same thing in my car (even worse than in the quoted videos) and was going crazy. Eventually had my mechanic replace this EPS coupler bushing with Toyota OEM part (after he had some trouble diagnosing) and it 100% fixed the rattle, car sounds and drives like new. You guys are the true MVPs and felt it my duty to give credit where it's due. Hopefully others with the same problem will find this thread and it will help them as well. Here's a picture of the garbage that was taken out of my EPS coupler, green rubber inside totally shredded.
Cheers!
TheIllistPhysicist is offline   Reply With Quote
The Following 3 Users Say Thank You to TheIllistPhysicist For This Useful Post:
bcj (09-18-2021), HRTROB (10-25-2021), Yoshoobaroo (09-17-2021)
Old 10-20-2021, 10:57 AM   #137
dexterchock
Drives: Toyota 86
Originally Posted by QuickieSilver143 View Post
Is this a part that we could possibly print with a 3D printer?
https://cults3d.com/en/users/mikasalim/creations i found this
dexterchock is offline   Reply With Quote
Old 10-20-2021, 11:12 AM   #138
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by dexterchock View Post
Should work well out of PETG, just make sure you print with all perimeters, no top/bottom infill at all. It’ll be the strongest in the load direction that way.
Old 10-29-2021, 10:26 AM   #139
ermax
ermax's Avatar
But why print the part if you can buy the real thing for under $10?
Old 10-29-2021, 12:46 PM   #140
Racecomp Engineering
Anyone besides @Opie see a busted coupler on a 2015 or later car?
- Andrew
FS: OEM Electric Power Steering Column, with Motor and Module MicheleAbbate Interior Parts (Incl. Lighting) 12 12-31-2018 03:47 PM
Recall for Electric power steering (EPS) tm86 AFRICA 36 05-16-2017 07:04 AM
Electric Power Steering ArtS Electronics | Audio | NAV | Infotainment 0 10-31-2016 08:19 AM
Electric Power Steering control module? slicktop Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 11-21-2013 08:38 PM
Electric power steering madfast Scion FR-S / Toyota 86 GT86 General Forum 33 10-13-2011 10:11 AM
